  1. May 20, 2015 at 10:50 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Looks good, and welcome to the club lol! I've had my premium for about 3 years now and it's been great!
    KrzyKjun512[QUOTED] likes this.
  2. May 20, 2015 at 10:52 PM
    taco terror
    USA
    Do the 5125s really make the ride better? Going over speed bumps in the rear with any sort of speed is a real killer.
  3. May 20, 2015 at 10:56 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They do if you have a lift above 2.25in, I had 4.25-4.5 which is literally the 5100s max extended amount. The 11" 5125s fixed my issue, I probably could have gotten away with 10" 5125s, but I was right in between measurements for either one so I went more droop less up travel.
  4. May 21, 2015 at 6:04 AM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    I had my stuff installed at my local off road shop. I had asked how the brake lines looked, and if they recommened extended brake lines. They had said no to that, I know most everyone on here has extended brake lines, but just wanted to see what you guys had to say?
  5. May 21, 2015 at 6:34 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Currently I don't have front extended brake lines, I do have rear, but when I upgrade my brakes I'm getting SS brake lines. I'd get the rear for sure tho
  6. May 21, 2015 at 6:38 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Rcd5100s cs 5125s are different slightly. They do differ in valving though.
    Unless your long travel up front. You don't need front ones.
    Depending on how much lift you have the rear could be needed.
    Overall. New steel lines will make the brakes harder and more responsive.
  7. May 21, 2015 at 7:11 AM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    Gave it a bath.
    m3bassman likes this.
  8. May 21, 2015 at 7:44 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I also had an OEM bedliner for about five years before I had the LineX done. The bed was still very clean but there were some paint rubs. I would just make sure that you have the LineX put in the same day that you take the drop-in out. That way the rubs don't have time to oxidize.
  9. May 21, 2015 at 7:47 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Do you have a pic? I'm thinking of doing the same but I was hoping I could still carry the spare in the same place.
  10. May 21, 2015 at 8:00 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    actually did last night... repainted my grill (it was fading) and mounted the Rigid SAE Fogs
    Before
    After
    tibblits920 and BYJOSHCOOK like this.
  11. May 21, 2015 at 10:33 AM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Spindle lift on a first gen?? What brand is it? I wasn't aware of any for a first gen unless you were a prerunner and had uniballs on uca and lca?
  12. May 21, 2015 at 10:48 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Selling these if anyone interested. Made for another member then he sold his truck. They are brand new and never used. The cutoff picture is just one of the projectors lit
  13. May 21, 2015 at 10:55 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I lifted my rig only about 1.5" and installed an extended rear brake line. The stock line was stretched fairly tight when I was installing the lift. Now, no worries about popping that rear OEM rubber line.
  14. May 21, 2015 at 11:07 AM
    DesertDigger
    DesertDigger Well-Known Member
    Eric
    Whittier CA
    '00 Prerunner Reg Cab
    TC +3.5 with Kings, BFG KO2 285s on Bronze NVs, Tube bumpers with Hella 4000 converted to HID
    What headlight shroud is that? Been eating to retrofit but not sure what would look good in the 98-00 headlight style.
  15. May 21, 2015 at 11:26 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Pamara (sp?). My Halos burnt out or I'd give you a pic of the halos. they looked good when they were lit though LOL... maybe I can find an old pic...
  16. May 21, 2015 at 11:37 AM
    LSC15
    Logan
    2008 TRD D-Cab
    Here is the panamera shroud
    ebbs15 likes this.
  17. May 21, 2015 at 11:39 AM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Cut some rust out of my bed a couple weeks ago and finally got it welded and sprayed...
    Considering getting the bed Rhinolined, either that or just wire brushing and spraying and surface rust that's left.
    Any advice on the Rhino lining front?
  18. May 21, 2015 at 11:57 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I used gatling guns in mine
  19. May 21, 2015 at 1:03 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Heyyyyy I know those lights ;)
    If you look through my posts in the last month or so there are some pics with the switchback halos running on the truck and a video too.
    Edit: Here is the vid. The Panamera shroud is my favorite.
    1st Gen Retrofitting Services
  20. May 21, 2015 at 4:12 PM
    KrzyKjun512
    KrzyKjun512 Well-Known Member
    Chad
    2000 TRD, Original Rust-Free
    I want to do the exact same thing with my grille (I have a 1978 yota emblem for the center). Did you cut the insides and fiberglass it (w/body filler) to cover the holes?
