  1. Jun 15, 2015 at 7:38 AM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Dang.. Over the weekend my engine randomly cut out on me while I was waiting for a light. It was idling fine then just cut out on me. But it started up fine right after.
    Now it starts right up but then dies like 5-10seconds later
    edit: Derp I left the intake tube detached lmao.. Man I was like wtf..
    alee891, Silver02Taco and tibblits920 like this.
  2. Jun 15, 2015 at 9:22 AM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    fixed my glare problems
  3. Jun 15, 2015 at 9:42 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Mean Green gear reduction starter came in today :D Also getting ready to install the BamaToy Stage I wiring kit.
  4. Jun 15, 2015 at 9:45 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    If that really is a 1/3 smaller than stock, it might actual be possible to get it in and out without to much trouble. Standing by for more info.
  5. Jun 15, 2015 at 9:49 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I'll post back when I get the old one off. Just eyeballing it I'm not really sure it is any smaller. Also I wish they published a spec sheet for the MG starter. I'm wondering what the actual torque and spin rate and battery load will be. Some others on TW have the same starter and seemed to be pretty impressed with it.
    TashcomerTexas likes this.
  6. Jun 15, 2015 at 9:50 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Installed the @CBI Offroad Fab drivers side antenna mount (same as the ditch light mount).
    Instructions were perfect from the website.
    1.5hr solo.
    Hardest part was pulling the fender back far enough to reach the hood hinge bolts.
  7. Jun 15, 2015 at 9:51 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Any details about rebuilding it yourself? Like which contacts and plunger to replace it with. I have just rebuild mine when every they go bad. $7 is way better that $200-300 for a new starter.
  8. Jun 15, 2015 at 10:46 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Mine is actually working fine I think. It just seems to be a bit gutless in the winter. I getting an AGM battery and HO alternator which I hope will beat it.
    Also I'm having occasional warm start issues which are probably more related to a fuel line problem. Tracking down a warm start issue is a bit of a rabbit hole I'm finding.
  9. Jun 15, 2015 at 11:28 AM
    PedroH
    PedroH Well-Known Member
    First of all, disconnect the negative plug of your battery, you don't want a short when your starter fall off the place and make contact with the frame.
    Once you remove the two bolts, discnnet the wirings, remove the dipstick ( just pull), loose the brake line bracket that is in the way and pull it backwards. You must flip the starter to clear the manifold and the upper control arm.
    alphabravo[QUOTED] likes this.
  10. Jun 15, 2015 at 11:54 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Jesus lol
  11. Jun 15, 2015 at 1:12 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    I think it's safe to say you just dropped about 10 lbs.
    Wait, people live in Arkansas? :confused:
    Where can I find one of these?
  12. Jun 15, 2015 at 1:16 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  13. Jun 15, 2015 at 1:19 PM
    TashcomerTexas
    Oh sweet. Thanks man
    Another thing to add to the bookmarks
  14. Jun 15, 2015 at 1:29 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I was curious and clicked on it earlier :anonymous:
  15. Jun 15, 2015 at 2:39 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Well I modified my snorkel tubing, and it is still sucking itself shut... Time to go to my plan C, which will be very tedious.
  16. Jun 15, 2015 at 2:44 PM
    jaferrin
    jaferrin Member
    Minnesota
    2002 Reg Cab 5spd 4x4
    Complete OME lift with Dakar leafs.
    Installed OME complete kit with 881 up front and Dakar rear leafs with grease able shackles.
    alee891 and MatthewMay1 like this.
  17. Jun 15, 2015 at 2:46 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Pics or it didn't happen
  18. Jun 15, 2015 at 2:51 PM
    jaferrin
    jaferrin Member
    Minnesota
    SWYPER, Jiveydude, alee891 and 2 others like this.
  19. Jun 15, 2015 at 2:52 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    That's better. Looks great!
    jaferrin likes this.
  20. Jun 15, 2015 at 3:14 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    just curious do you have a pic of the piece thats sucking itself shut?
