  1. Jun 23, 2015 at 9:11 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    How do the 700 lb coils ride?
  2. Jun 23, 2015 at 9:29 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Does anyone have pics of a 1st gen with 1.25" spacers, stock wheels, and 285/75/16's?
  3. Jun 23, 2015 at 9:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I like them a lot. Firm but not harsh. Some of that is the valving I'm sure. I do carry a whole lot of extra weight up front tho. Maybe as much as 300 lbs + over stock. It was a little too much for 650 lb Eibachs.
  4. Jun 23, 2015 at 10:31 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Nvm, thought your headlights were new haha
  5. Jun 23, 2015 at 10:54 PM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Seriously there is no comparison, these are my first suspension seats I wasn't sure what to expect. They help soak up a lot of bumps in the road, fabric feels thick and heavy duty. The seat frame is 3/16 plate, the reclining mechanism is crazy smooth too it's hard to even explain how it feels. I got the optional lumbar support I would recommend that as well it's nice and just feels amazingly supportive. Plus it's a perfect match to the interior. Don't cheap out on other brands, the Mastercrafts are quite a bit more but worth every penny.
  6. Jun 24, 2015 at 4:47 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Ah no I've had retros for about a year or so now
  7. Jun 24, 2015 at 6:55 AM
    EastBayTaco
    EastBayTaco Well-Known Member
    Carlos
    Bay Area, CA
    96 Tacoma 4x4 SR5
    OME Everything! (883 coils with Dakars), Light Racing UCAs, Wheelers SS brake lines, Toytec 1" lift shackles, Magnaflow muffler, CKMA12 ARB On-Board Air Compressor, Custom 80' Sliders
    I was looking into the seats as well.. What about the mounting? Is it direct fit?
  8. Jun 24, 2015 at 8:48 AM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Yes direct fit after you chop, bend, drill, weld and swear at it, bolts right up.
    Mastercraft only makes seat brackets for the single cab, the front bracket is perfect, the rear one needs the modification. The corners closest to the transmission tunnel aren't even close, it appears that the single cabs mount flat on the floor instead of on the side of the tunnel like ours. You or someone will need to modify that bracket unless you only want 3 of 4 bolts.
  9. Jun 24, 2015 at 9:35 AM
    A_lew14
    A_lew14 Member
    Andrew
    Sorry didn't know $90 & $110 were the same number guess I missed that class in school lol
  10. Jun 24, 2015 at 9:43 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  11. Jun 24, 2015 at 10:01 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Alrighty guys, I have been waffling between wheel specs for a while now, can't decide if 3.5 or 4.5 BS is what I want. Pros and Cons of each? I'm gonna be running 265/75/R16 BFG KO2s just in case that makes any difference
  12. Jun 24, 2015 at 12:01 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Good to hear they are good quality and very comfortable.
    I wouldve thought they would bolt right up. Did you get seat sliders for them or do they just not slide?
  13. Jun 24, 2015 at 12:03 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    X2. i love my ko2's. Tts the first all terrain ive had and im very impressed.
  14. Jun 24, 2015 at 1:38 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    put a smaller alt pulley on and then drove to see the icebergs roll in. D940EB3F-6FDA-4789-9D52-B80D8F6C99E9_zps_b4793d6fc347d64b4552be75e231add729e018ba.jpg
  15. Jun 24, 2015 at 1:57 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Yea, I have those tires as well in 31" and I love them
  16. Jun 24, 2015 at 1:59 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Has anybody ever tried to do a solid mount on the steering rack? Or is this just asking for a cracked rack?
  17. Jun 24, 2015 at 2:03 PM
    joemauma
    joemauma Well-Known Member
    Oregon
    Double Cab
    Those look pimp!
  18. Jun 24, 2015 at 2:10 PM
    joemauma
    Oregon
    Double Cab
    Dude, that light bar is sick! Those brackets stick up so high you should mount a couple more light bars above your cab!
  19. Jun 24, 2015 at 2:18 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thinking of converting my steering wheel to one from a '76 pickup. For 10 bucks I figured I could grab it now and decide later. :anonymous:
  20. Jun 24, 2015 at 2:28 PM
    SWYPER
    SWYPER Well-Known Member
    Dylan
    South Carolina
    1998 Tacoma 2.7L 4x4
    image.jpgStarted to put some stickers on the inside of my tint strip.:cool:
    45acp likes this.
