  1. Jul 11, 2015 at 3:02 PM
    Madjik_Man
    Colorado Front Range
    FYI: Mine is very gritty and stiff.
    But I don't care, I don't really ever touch it.
  2. Jul 11, 2015 at 4:13 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Got some HP today :stirthepot:
    SWYPER and Silver02Taco like this.
  3. Jul 11, 2015 at 4:22 PM
    Tanner757
    Tanner757 Well-Known Member
    Tanner
    virginia beach
    2003 tacoma v6 4door 4x4 swap
    new radio removed mudflaps weld typhoons bed lined bumper Cb radio air resenator removal flowmaster outlaw
    If i were you and youre eventually lifting it id just get some 882 or 883 ome coils and an add a leaf and then save for new leaf packs when your add a leaf eventually wears out
  4. Jul 11, 2015 at 4:22 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    brought my bike to the pit. 175F95EF-C597-4211-B99C-241A9822E492_zps_af4db7e8c664acde219685acfeb7864434f18ca8.jpg
    SWYPER likes this.
  5. Jul 11, 2015 at 4:40 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Are the ome coils for extended shocks? Will it fit on a stock length shock? Im currently at 1.5" lift with the adjustable bilstiens. But with the current coils sagging, its basically at stock height.
    Will a new set of stock OEM ( not ome ) coils suffice?
    Really dont want to lift anything yet. And when i do lift id like to go with a nice fox set up, so everything would get replaced.
  6. Jul 11, 2015 at 5:19 PM
    Stone Cold ET
    Stone Cold ET Well-Known Member
    Adam
    Louisiana
    2003 DCSB TRD PRERUNNER
    I just plasti-dipped them. Figured once they look like shit again I'll peel it off and respray.
  7. Jul 11, 2015 at 5:23 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Replaced my timing belt/water pump etc. got most of it back together before I had to quit. First time doing one and it's been exhausting.
  8. Jul 11, 2015 at 5:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Ah, IC. The up travel does appear to be quite similar tho I suspect you are running longer shocks than me. 10s? 12s?
    Which leaf pack is that?
    Do it right the first time if you can afford it. 2.5" diameter adjustable COs with 3" ID coils like Foxes or Kings are sweet for several reasons but mostly because the are adjustable and rebuildable.
  9. Jul 11, 2015 at 5:47 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I had something similar and all I needed was new spark plugs.
  10. Jul 11, 2015 at 5:49 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    This.
  11. Jul 11, 2015 at 6:10 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Holy fawk! You cut the side outta yer box?!? To what end?!?
  12. Jul 11, 2015 at 6:31 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Pics with my tent on. I love it. Doesn't sit too high and i can still access my bed easily. Went to take pics and forgot the sd card for my camera :frusty:
    stupid crappy cell phone pics.
    I think im gonna need some all pro expo leafs though. My j59s just arent up to holding much weight.
  13. Jul 11, 2015 at 6:48 PM
    paquu
    RI
    42" LED bar
    I hear you but im not ready for that yet. I might give wheelers a call and see what they suggest.
  14. Jul 11, 2015 at 7:04 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I couldn't get the trd sticker off. So I had to.
  15. Jul 11, 2015 at 7:23 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Is Hayden the best transmission cooler I can get or do you guys recommend getting a different brand? also, do you guys recommend running the bypass or just adding the transmission cooler after the oem cooler?
  16. Jul 11, 2015 at 7:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am using this one. I hooked it up in series. The fluid goes from the trans to the radiator then to the cooler then back to the trans.
  17. Jul 11, 2015 at 7:56 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    nice, I love my bed Bob.
    Just finished:
    -greased rear OME shackles
    -raised BPV
    -cleaned MAF
    -cleaned TB butterfly
    -cleaned AFE filter
    -greased TC UCAs
    -cleaned dirt off shocks
    tibblits920 likes this.
  18. Jul 11, 2015 at 8:37 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Parts arrived! Started with the rear brakes only to discover the e-brake bell crank is stuck.... damn winter salt making everything rusty.Parts Arrived.jpg ...
  19. Jul 11, 2015 at 9:09 PM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Put my Camper Shell and bed setup/ toolbox up for sale on TW!
    Fits 6ft bed extra cab.
    Check it out
  20. Jul 11, 2015 at 9:52 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Nice. How much more atf and radiator fluid did you need?
