  1. Jul 18, 2015 at 7:12 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Just saw that on the news this morning. Saw a towed boat and a fuck ton of cars burnt up.
  2. Jul 18, 2015 at 7:15 AM
    Tanner757
    Tanner757 Well-Known Member
    Tanner
    virginia beach
    2003 tacoma v6 4door 4x4 swap
    new radio removed mudflaps weld typhoons bed lined bumper Cb radio air resenator removal flowmaster outlaw
    Looks like an 01-04 hood
    But ive been wrong before
  3. Jul 18, 2015 at 7:51 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    yup hood is definitely from 01-04.
    also looks like it has 2nd gen trd sport wheels
  4. Jul 18, 2015 at 10:24 AM
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    Nice setup, Are you rubbing with the 265/75's on stock suspension?
  5. Jul 18, 2015 at 10:34 AM
    AZoverlandTaco
    AZoverlandTaco How do I change my profile name?
    Eric
    Flagstaff
    Toyota 4 Life
    Yeah it rubbed on the inner fender liner near the back when making sharp turns. It wasn't awful by no means. So I trimmed it up a bit and used a heat gun to reshape it. 15 minutes later no more rubbing!
  6. Jul 18, 2015 at 10:41 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Done with sound matting, cable layout. Ive wrapped the power and ground lines in sound matting material where they cross with signal lines. Im hoping the foil will act as shielding against magnetic interference where I dont have the choice of separating the wires.
    Im using the armrest mounting bolt as the ground, any issue with this? Whats an acceptable resistance on the ground i should check for?
    boostedka and SWYPER like this.
  7. Jul 18, 2015 at 10:50 AM
    Caligula
    Los Angeles, CA
    I was coming back from Riverside yesterday, smoke was everywhere coming from the mountains. Some dumb ass with a drone caused the copters and DC-10 fire plane to pull back for an hour, thats when the fire jumped the freeway and all the cars caught fire.
  8. Jul 18, 2015 at 11:47 AM
    Goldfinger
    Goldfinger Well-Known Member
    Brad
    Colorado Springs, CO
    1994 Xcab Pickup truggy
    Exo cage, dual transfer cases (one with 4.7), Alcan springs, 39.5 TSL's, Longfield birfs and axles.
    Very nice looking setup! Love that wheel and tire combo.
  9. Jul 18, 2015 at 11:49 AM
    Goldfinger
    Brad
    They are all coil overs. Even from the factory.
    552Jrider likes this.
  10. Jul 18, 2015 at 11:58 AM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    @Caligula what sound may is that? And how good is it?
  11. Jul 18, 2015 at 1:05 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Test fit!
    SWYPER, presto and westhumboldt like this.
  12. Jul 18, 2015 at 1:07 PM
    cmj
    cmj Well-Known Member
    Tucson
    98 Tacoma 4x4
    I really want to do this to my truck! Please let us know how much of a difference it makes, cost, time etc!
  13. Jul 18, 2015 at 1:23 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Correct.
    Here in tacomaworld though, coilovers are synonymous with adjustable coilovers such as kings/icon/fox. People on here don't call thier Toytec 5100/eibach combos and OME "coilovers" even though yes, they are coil over shock config.
  14. Jul 18, 2015 at 1:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I don't see how kings and the like are more expensive over time or require more maintenance.
    How does a rebuild kit that cost less then 50 bucks more expensive the a whole new set of ome coioovers? Do that twice and your at the same cost of a high quality coil over. And the fact you can rebuild and replace anything in them is what is awesome.
    Having been in a few ome lifted rig vs rigs with a nice co. Night and day difference. I'd never go back on either if my trucks and never will on any future rig. Not worth the money to get ome or 5100 or similar.
    Ice Horse, Digiratus and Goldfinger like this.
  15. Jul 18, 2015 at 1:31 PM
    pittim
    Pennsyltucky
    Boujee Prius
    If you can rebuild them yourself they aren't.
    Vast majority on here cant install a lift themselves, let alone rebuild a shock, so the rebuild process is obviously going to be much more expensive than $50 for them. After 2 or 3 rebuilds it might be a wash.
  16. Jul 18, 2015 at 1:40 PM
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
  17. Jul 18, 2015 at 1:44 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I wouldn't use a rubber bushing shock in the front for a lifted application no matter what color it was.
    Coilover struts are not used on Tacos.:popcorn:
  18. Jul 18, 2015 at 1:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    All you need is basic hand tools and maybe a vice. That's it.
    But DSM only charges 100 a shock or so. Considering they usually last 30-60k I'll do that.
    Bingo!!
    The rubber lower bushings never last
  19. Jul 18, 2015 at 2:44 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Well I left both of my front windows down and it rained, so I have water standing in the cupholders and the seats and carpet are soaked.
  20. Jul 18, 2015 at 2:51 PM
    Scenekyd
    Jay
    Hendersonville, NC
    Don't feel bad.. I've had my tube doors on for a couple weeks.. it absolutely poured last Tuesday.. water ponded up in the floor. Carpet is dry but the gray insulation padding under it.. still soaked.
