  1. Jul 30, 2015 at 6:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Also.......Modern filters aren't "Paper", but rather a synthetic mesh. They not only filter better than any gauze filter out (smaller particles), but hold more dirt too.
  2. Jul 30, 2015 at 7:03 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    My apologies Chris, honestly didn't realize You conducted the test yourself, I thought he was using your Mod status as a basis for the discussion.
    I agree with you and already stated it, run what you want.
  3. Jul 30, 2015 at 7:56 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Best quote ever! :thumbsup:
  4. Jul 30, 2015 at 8:02 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    It's the epitome of this thread the past few weeks :rofl:
  5. Jul 30, 2015 at 8:20 AM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
  6. Jul 30, 2015 at 8:26 AM
    scocar
    scocar Patron of the Farts
    Sand in the vagina or sand in the engine. Neither is pretty.
    MatthewMay1 likes this.
  7. Jul 30, 2015 at 8:35 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I threw not one, but two connecting rods and scored the rotors on my supercharger when I had my drop-in K&N ...nevermind the metric shit ton of water that got sucked into the intake...it's all the K&N's fault.
    Now everyone knows someone! And it wasn't 4 degrees of separation like a friend's brother's sister's boyfriend. But a friend's brother's sister...is the same thing as just the friend's sister (because well...brother and sister and friend are all siblings), so we can cull that down to 3 degrees of separation...friend's sister's boyfriend.
    m3bassman likes this.
  8. Jul 30, 2015 at 8:36 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Puts a whole new meaning to "polished knob".
  9. Jul 30, 2015 at 9:05 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Hold that thought.... mine is 263K miles and I just changed to SuperTech FullSynthetic oil at waltmart 17.89 \5q. and better to get the OEM oil and air filters. Also I changed to Valvoline Full Synthetic ATF transmission x5\5q 17.89 each at waltmart too. I don't trust mobil 1 since many indicated is not full synt. is blend. Supertech passed API standards so I'm good with that.
  10. Jul 30, 2015 at 9:08 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    As long as the oil you buy is rated for your trucks standards you're fine, I use valvoline in my gears and Rotella in my engine.
    I suggested mobile 1 as its praised around here and super easy to find, I used it for years with no issues as well.
    2002Tacoma4x4[QUOTED] likes this.
  11. Jul 30, 2015 at 9:18 AM
    2002Tacoma4x4
    C K
    I just got sold by the idea of synthetic is better and OEM parts are the recommended , so I found a full synthetic oil and ATF with good reviews and that fits my budget.:burnrubber:
  12. Jul 30, 2015 at 9:20 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    It isn't that synthetic is "better" but its main advantage is that it doesn't need changed as often as conventional.
  13. Jul 30, 2015 at 9:25 AM
    Roll Tide
    Q
    01 T4R
    I've come to realize I do everything wrong with my truck.
    That means that it is either by absolute happenstance, luck, or miracle that it still runs, drives, and it generally all still bolted together.
    Bilstein lift
    Regular ol oil changed every 5000 miles
    K&N filter
    I suppose it will probably spontaneously combust within the hour.
  14. Jul 30, 2015 at 9:29 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    When it comes to my truck I dont seem to have a budget..I have had parts fail most likely to my negligence and over the 6 years I have owned it tried a lot of different things, I have a bit of a routine down now with the products I buy and how often I change them.
    Purchased the truck with 110k miles
    Now is sitting at almost 205k miles
    Never had an major issues with he engine or transmission.
    Since June 2009 I have replaced:
    Rear drive shaft
    Rear gears in third member
    1 battery
    crumbled shifter boots
    rear driver side hub seal.
    All the parts I have upgraded for funzies:
    Doug Thorley headers
    Magnaflow muffler
    air filters, back to stock Toyota in stock box with deck plate
    38lbs fly wheel, race clutch.. back to oem grade stock flywheel and clutch
    Tundra big brake kit off a 06+
    Fog lights
    front, rear bumpers
    Tire carrier/rear bed cage for longer shocks
    Sliders
    Stuff that wore out:
    on my 4th set of tires, second set of wheels
    4 sets of spark plugs, dealer OEM Denso
    1 set of plug wires
    battery terminals
    Throttle cable
    2 windshields
    3 sets of headlight bulbs
    on my second set of O2 sensors
    CV boots on both sides
    Reverse light switch on transmission
    Throttle position sensor
    Mass air flow sensor
    Countless engine oil and gear oil changes
    Replaced stock OEM bilstiens with 5100's on the highest setting to level the truck out in front with KYB rear shocks on stock leafpack.
    then went to Icon coil overs in front with custom made leaf pack in rear.. ran like shit, extremely harsh,
    Now am running Fox front with external resi re valved for my trucks, 10 inch rear fox with resi also valved for the truck, Deaver J59 leaf pack. been great for years.
  15. Jul 30, 2015 at 9:34 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    :violent::itllbuffout:
  16. Jul 30, 2015 at 9:36 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    You still rocking your first gen, pops?
  17. Jul 30, 2015 at 9:41 AM
    pittim
    Pennsyltucky
    Boujee Prius
    You are now prepared to move up to a 3rd gen. Congratulations.
  18. Jul 30, 2015 at 10:01 AM
    2002Tacoma4x4
    C K
    So far including the financial charges for the loan , the Tacoma had cost me USD$ 7,150.00 , sold for 7,150.00
    :burnrubber::oldglory:
    Many expend a lot more on upgrades without checking the frame 1st. and at the time they want to sell , well...everyone want it almost for free.
  19. Jul 30, 2015 at 10:07 AM
    2002Tacoma4x4
    C K
    You're right... that is one of the reasons I picked synthetic..... planning to do oil change only :oldglory:once a year since I just drive the Tacoma on weekends.
  20. Jul 30, 2015 at 10:09 AM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    What filter are you running now?
