  1. Aug 9, 2015 at 8:35 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I check it while the engine is running? Never heard that before
  2. Aug 9, 2015 at 8:36 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    He's saying that the engine normally gets to 180s, but I'm not sure if the trans heats up at the same rate as the engine (assuming movement, obviously.) If it did then you can use the engine temp gauge to guess the trans temp gauge.
  3. Aug 9, 2015 at 8:37 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    It's also saying major differences aren't likely.
    I'll creep on his FB page and see what I can find.
    It's filled via the dipstick tube IIRC.
  4. Aug 9, 2015 at 8:37 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    That's how you check tranny oil. At least that's how we did it in the 2 maintenence shops I've worked in
  5. Aug 9, 2015 at 8:37 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    That sure would make it easy!
  6. Aug 9, 2015 at 8:38 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Sounds good enough for me. I've never messed with transmission fluid before so I know nothing
  7. Aug 9, 2015 at 8:42 PM
    95 taco
    95 taco Battle Born
    @pittim No other pictures, but the more I look the more it looks exactly like my T-case, the physical differences are most of the battle, electrical I can deal with easily.
  8. Aug 9, 2015 at 8:43 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Does anybody have a link for the tac-weld on the steering rack mod? I can't seem to find it.
    Nevermind. I just found it
  9. Aug 9, 2015 at 8:47 PM
    pittim
    Pennsyltucky
    Boujee Prius
    If you want to look at the wiring, I can PM you the FSM pages for the ADD and Jshift cases.
  10. Aug 9, 2015 at 8:49 PM
    95 taco
    95 taco Battle Born
    That would be awesome, Thanks
  11. Aug 9, 2015 at 8:49 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    You also need to run through the gears (with foot on the brake) slowly a couple times after you've added the new fluid, then check the level.
  12. Aug 9, 2015 at 8:51 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Thanks for letting me know
  13. Aug 9, 2015 at 8:52 PM
    pittim
    Pennsyltucky
    Boujee Prius
    PM inbound.
    Also, see this.
    Jshift case
    Push button
    They look the same haha
  14. Aug 9, 2015 at 8:57 PM
    95 taco
    95 taco Battle Born
    Thanks
    Wiring appears (from the little I can see and from lots of assuming) to be similar or the same, that's good.
  15. Aug 10, 2015 at 3:26 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I changed the diffs, tranny, engine and transfer over to Amsoil. GL4 75-90 for the tranny and transfer case, 75-110 severe gear for the diffs and SS10-30 in the engine. I went with 10-30 instead of 5-30 because when it comes to the difference in Amsoil it's almost not even there from a cold flow standpoint and the closer the numbers are the less VII's they have to add.
  16. Aug 10, 2015 at 5:52 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Finally made it passed the break in period!
  17. Aug 10, 2015 at 6:20 AM
    Madjik_Man
    Colorado Front Range
    See attached. It looks like page 51 of the pdf is what you want? :notsure:
    And sorry for the screwed up pdf, the 01-04 FSM I have is all out of whack and since I have a 98 I never took the time to mess with it.
  18. Aug 10, 2015 at 7:48 AM
    MatthewMay1
    Matthew
    Lone Star Republic
    How are you going almost 80 at that RPM?
    Also, apparentally Toyota told me the wrong coolant on Saturday.....And, when I check my transmission dip stick with the engine hot, it reads the same as when I check it cool. Guess I need to add some fluid
    opteron likes this.
  19. Aug 10, 2015 at 7:49 AM
    95 taco
    95 taco Battle Born
    How long did you drive to get it hot?
  20. Aug 10, 2015 at 7:51 AM
    MatthewMay1
    Matthew
    Lone Star Republic
    About 20 minutes. I went to the dealership to get another jug of coolant to find out that the other dealer sold me the wrong coolant on Saturday
