  1. Aug 17, 2015 at 11:44 AM
    Wulf
    rock raisin
    my only regret is not having done it sooner!
  2. Aug 17, 2015 at 11:52 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Do the 4runner seats bolt right in?
  3. Aug 17, 2015 at 11:56 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
  4. Aug 17, 2015 at 12:06 PM
    Wulf
    rock raisin
    My truck is a 96 and the seats came out of a 2001 4runner (3rd gen). Except for the outer front foot on each seat due to the difference in floor pans, they bolted in. The outer front needs to be hammered flat and have the hole filed out. Other than that they bolt in.
    I had to do some jimmying to get the holes to line up but they fit fine.
    I may post a thread about it once I get the chance
  5. Aug 17, 2015 at 12:12 PM
    TacoVio
    Kolton
    CO/WY
    Hmm that's awesome! May have to do some thinking lol
  6. Aug 17, 2015 at 12:54 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Got it stuck twice, and got to use my winch.
    These BFG AT's are no match for Mississippi mud.
    tibblits920 and SWYPER like this.
  7. Aug 17, 2015 at 1:20 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I was really wanting to do this...
  8. Aug 17, 2015 at 3:05 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I may go that route for the headlights in an attempt to have similar color lighting (I don't want stock, yellow head lights to make my upgraded lighting look bad). My plate bumper doesn't have fog cut outs so I'm just looking to put some ditch lights on the hood and point them accordingly. 4000s are for certain now, but the rest of the lighting is a toss up. Plus, I need to figure out what I want for the sides and rear.
    m3bassman[QUOTED] likes this.
  9. Aug 17, 2015 at 6:15 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Can anyone explain to me why the front tires rotate in different directions when in 4 wheel drive?? We swapped wheels and tires on our trucks today to see how hers would look with my setup (and it does look good) but when I was sitting there spinning one wheel when I had the front in the air the opposite tire would spin the opposite direction...it's probably something really simple that I'm just over thinking.
  10. Aug 17, 2015 at 6:19 PM
    95 taco
    95 taco Battle Born
    Standard for an open differential.
    YouTube has a good video on how differentials work.
    tibblits920[QUOTED] likes this.
  11. Aug 17, 2015 at 6:22 PM
    95 taco
    95 taco Battle Born
    Toe is set last, so does it effect camber?
    I had an alignment about 10 weeks ago and my alignment has started to go bad, first I noticed bad tire wear (worn on the inside edges from camber) and the toe doesn't feel right through the steering wheel.
    Tonight I crawled under my truck and found this, I guess the tech didn't tighten the jam nut, but would this affect the camber?
  12. Aug 17, 2015 at 7:47 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Started installing my TC UCAs. After about 50 trips to the parts store, walmart, home depot, I only have one side pulled apart haha. Can't find the dang lube I need for them locally. So gotta order it after checking one more potential place tomorrow. Also got one of my rotors turned.
    tibblits920 and alphabravo like this.
  13. Aug 17, 2015 at 7:55 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Ive heard of people using the teflon lube you can buy for guns if you can get some of that locally
  14. Aug 17, 2015 at 7:58 PM
    Ice Horse
    Lauren
    Florida
    I'm kind of paranoid about killing them so I've been following manufacturer recommendations haha.
  15. Aug 17, 2015 at 8:14 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    What does TC recommend using? I use Tri Flow Dry on my All Pro uniballs
  16. Aug 17, 2015 at 8:16 PM
    Ice Horse
    Lauren
    Florida
    The Tri-Flow Dry with PTFE for the uniballs, but I couldn't find any on the website, the link on the paperwork was dead with no mention on the website about it. So I got some WD-40 Dry lubricant with PTFE for the uniballs. And then this stuff for the zirc fittings http://www.super-lube.com/super-lube-synthetic-grease-cartridge-4oz-400g-model-41150-p-11.html which I cannot find. Nothing around here has "PTFE" in it/on it/whatever that is lol
    alphabravo likes this.
  17. Aug 17, 2015 at 8:30 PM
    TIPICOTACO
    Tyler
    nw nj
    I got the Tri-Flo from Amazon.. just using Lucas Red-n-Tacky on the bushing zerks.. Hope that's the right stuff lol
  18. Aug 17, 2015 at 10:15 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I was wondering about this. I got tons of scratches from mudding....will this do the job?
  19. Aug 17, 2015 at 10:57 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Will it take out the scratches? IDK. It sure is clean and smooth though. Should help with bugs and mud i guess. I had my fare share of mudding in high school. No more for me
  20. Aug 18, 2015 at 7:21 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I found tri-flow hidden in the bike section of Walmart
