  1. Aug 18, 2015 at 7:28 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    For best results the diff breather mod needs to be done while the axle is underwater
    tibblits920 and ClevSix like this.
  2. Aug 18, 2015 at 7:36 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Yes, deeper the better!!
  3. Aug 18, 2015 at 7:39 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Ok. You make it sound easy haha. And I'm sure it is. I just don't know how long I can keep driving the truck the way it is before something bad happens. I havent seen oil in the driveway yet but I think the factory skid is holding most of it.
    Thanks I will definitely try this.
  4. Aug 18, 2015 at 7:59 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Took off the bed rack and tent now that I have a garage to throw it in. Looks weird but starting to like it again.
  5. Aug 18, 2015 at 8:04 PM
    Wulf
    rock raisin
    I'm thinking 96-02 T4R seats are all as I don't think that they
    in your Taco?
    I think they're similar but the I think the 4runner ones have taller side bolsters
  6. Aug 18, 2015 at 9:02 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Definitely want to change the seal sooner than later IMO, I'm pretty sure nothing bad should happen unless the oil level drops below what it's supposed to be though.. (Full..)
    Removing the front diff wasn't exactly easy but it's definitely do-able in one day/afternoon, if you do it on a weekend you should be good IMO. Just make sure you have a 12mm Allen or whatever the correct size is.
    Fernando likes this.
  7. Aug 18, 2015 at 9:07 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Thanks presto! I believe I can do it
    presto[QUOTED] likes this.
  8. Aug 18, 2015 at 11:12 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :p
    Thats what she said :rofl:
    Whoaa! Dude, ur alive! Where ya been man? Rig looks pimp:thumbsup:
    SWYPER and 552Jrider like this.
  9. Aug 19, 2015 at 4:45 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ha yes, one of the first mods that need to be done to deal with the south jersey puddles. This truck definitely is no stranger to water.
    You've been hooked on the 2 wheel addiction. Don't worry, I don't blame you. :p
    SWYPER likes this.
  10. Aug 19, 2015 at 6:40 AM
    PcBuilder14
    Brent
    Nor Cal
    Haha yeah, I've been busy nonstop for the past 3 weeks. From travelling, getting married, and now moving houses.
    Haha you're right... Main reason for it was because gas mileage and I have to go buy some furniture.
    2002Tacoma4x4 likes this.
  11. Aug 19, 2015 at 6:52 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Wait what?? :eek: congrats dude. I didn't even know you were engaged
  12. Aug 19, 2015 at 6:58 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Wat. Had no idea as well. Congrats on the marriage and new house dude! :thumbsup:
  13. Aug 19, 2015 at 8:56 AM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Thats a serious thing man, its a terrible addiction.
  14. Aug 19, 2015 at 9:10 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Trying to decide if i should remove my sliders and change the angle or just leave them. when i had them welded the guy put them a pretty high angle. i want to make sure they are at an ok angle and will still protect my body. Any opinions??
    [​IMG]DSC_3209 by Jeremy Pabst, on Flickr
    [​IMG]DSC_3211 by Jeremy Pabst, on Flickr
    [​IMG]DSC_3210 by Jeremy Pabst, on Flickr
  15. Aug 19, 2015 at 9:18 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    I just recently fixed my AC...or rather lack of.
    I have slider console controls as opposed to knobs.
    I took the console apart to just take a look and discovered something that I should have taken a pic of.
    Not knowing the correct part terminology, I'll describe it as best as possible:
    When I slide the hot/cold slider, inside the console it is connected to a wire that manually opens/closes some kind of flapper door back in there to allow warm air in or not. The cable has a sheath on it (like a bicycle brake line). The problem in my situation was that the sheath had come loose on the lever end. So what happened when I moved the slider was that instead of the wire itself moving back and forth in the sheath, the whole sheath moved, so the wire wasn't actually actuating the flapper door. I tried snapping the sheath back into the plastic retention mechanism, but apparently it's worn over the last 18 years and kept popping out
    So, I MacGyver'd it.
    I took a small washer that I had and clipped a piece of it out so it looks like a C. I snapped the sheath back in where it was supposed to be, then slipped the newly made C clip over the sheath and used some small long nose pliers to crimp the C clip opening more closed.
    Now when I slide the lever, the sheath is held in place by the washer and the wire slides freely inside, actuating the flapper properly. After I did that, I can actually hear the flapper go thump as is closes. I don't think I've ever heard that since I've owned my Taco. Nor have I had as cold air as I do now.
    j0shu4 likes this.
  16. Aug 19, 2015 at 9:21 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Nice. cant beat a semi easy and cheap fix like that.
  17. Aug 19, 2015 at 9:22 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    They look fine to me! :cool:
  18. Aug 19, 2015 at 9:23 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    :notsure: they look high to me. But i guess ive never seen a set on another truck.
  19. Aug 19, 2015 at 9:27 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I can get a finger and a half between them and my door and I think its at a perfect angle. I'd say leave it
    quetzal likes this.
  20. Aug 19, 2015 at 9:28 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Leaving it sure does sound nice. its a b!tch to grind the welds out.
