  1. Aug 22, 2015 at 1:37 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Haha thanks man! I love how it turned out. Always loved snow camo so since this is just a toy I ran with it!
    Lol. Unfortunately I don't own a tire brush
  2. Aug 22, 2015 at 1:41 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I'm up to my ears in this TC/ADS build. Can someone tell me how to get the thin metal cap off the hub? I need to pull the spindle to press the upper ball joint out.
    Does it screw on/off or does it press on?
    TIA
  3. Aug 22, 2015 at 1:42 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    it is pressed on. Just need a flat blade screw driver or small pry bar.
  4. Aug 22, 2015 at 1:49 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    What you said is most likely exactly what I'm going to do. I doubt I could run a muffler-free setup without loss of low end torque.
    I'm leaning towards doing exactly what you said, word for word.:thumbsup:
    Flowmaster50 and the pipe extension, dump the whole thing out the side and do whatever O2 sim is necessary to keep the computer happy;)
    Gawd I love this truck..
    SilverGhost[QUOTED] likes this.
  5. Aug 22, 2015 at 1:53 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I get what your saying
  6. Aug 22, 2015 at 1:56 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Oh and @tooter likes the flowmaster cause apparently it increases the gas velocity. The exhaust gas comes out faster then it goes in and all I'm saying is that having no muffler isn't going to loss you anything. As long as the pipe stays the same diameter it should only help. If I'm wrong someone provide some proof.
  7. Aug 22, 2015 at 1:57 PM
    WheelInTheSky
    G
    Jackson Hole
    Thinkin' I'll just bite the bullet and get my exhaust work done at a shop early next week. No point in pansying around wringing my wrists about it, time to get an exhaust extension and put a new muffler on!
    Pics to follow soon enough..:D
  8. Aug 22, 2015 at 2:38 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    03 Tacoma SR5
    3" lift Freedom Off-road adjustable coilovers 5100’s out back with AAL TRD Pro wheels w/ 285.75.16 KO2’s Freedom Off-road UCA’s 4xInnovations front bumper (on order!)
    How many wheel bearings on rear driver side of the axle? Is there an inner and outer bearing?
    I'm replacing the inner and outer axle seals on the rear driver side. Also on the same side I'm replacing the wheel bearings and replacing the brake shoes. Anything else I should replace while there?
    I had a axle seal go out so I had diff fluid spewing out
  9. Aug 22, 2015 at 2:56 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Just picked this up she'll for $300
    SanClementeTac01 and WildLand like this.
  10. Aug 22, 2015 at 3:16 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Get on it! Not to long ago I added a 14" magnaflow. I was stuck between the flowmaster 50 series and mag. Went with the mag.
  11. Aug 22, 2015 at 3:34 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Bumps? and how tall are they?
  12. Aug 22, 2015 at 4:45 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Silver02Taco and tibblits920 like this.
  13. Aug 22, 2015 at 4:52 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I think I am going to PC tomorrow early in the morning. Haul my son around them rocks again..lol
  14. Aug 22, 2015 at 4:55 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Nice sounds fun
  15. Aug 22, 2015 at 4:56 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    So I stripped one of my wheel studs last time I rotated my tires. I guess that means its time for a SAS
    :p JK
    Can someone point me in the right direction for extended wheel studs? I am running a 1/4 spacer up front and would like to get them a bit longer since I am replacing one.
    I am going to start stacking up parts for a full front end overhaul. I need new LCA's, LBJ's, Tie rods, and wheel studs. UBJ's where done recently.
    TIA gentlemen
    Silver02Taco likes this.
  16. Aug 22, 2015 at 4:57 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    dude, I need to get you those lights..lol...I'm bout to just say F**k it and mail them to you!
  17. Aug 22, 2015 at 5:00 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    I believe it's get two birds stoned at once
  18. Aug 22, 2015 at 5:02 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Nah, dont mail them. What time are you gonna be at PC tomorrow?
  19. Aug 22, 2015 at 5:04 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    install these baby today, damn it put a smile on my face when they magically rise by themselves.
  20. Aug 22, 2015 at 7:49 PM
    canonmutant
    canonmutant Well-Known Member
    Kansas
    02 PreRunner TRD
    Hmmh, temping. I've reached an age where getting it up and hitting the hole are both a challenge . . . talking about the stock hood lift rod here, folks. I can see the advantage of these . . .
    As for me, these arrived today since my exhaust is shot . . .
    http://gibsonperformance.shptron.com/p/stainless-cat-back-performance-exhaust-system-single-side-184
    http://www.magnaflow.com/products?partNumber=14586&searchTerm=14586
    http://mbrpautomotive.com/?search=r1012&submit=Search&page=products
    I put the MBRP resonator in front of the Magnaflow muffler on the Gibson catback [barely fits]. And it's much cheaper than just buying a Magnaflow catback. Plus all the Magnaflow catbacks just have 4x9x18" mufflers. Did this on a previous V6 truck using the largest Magnaflow that would fit [5x11x22] and it was amazing how much raspiness that MBRP resonator removes from the sound. Just a mellow rumble over stock and looks great.
    At least that is the plan. Will repost when I get-er-done.
