  1. Sep 2, 2015 at 8:46 PM
    SWYPER
    SWYPER Well-Known Member
    Dylan
    South Carolina
    1998 Tacoma 2.7L 4x4
    I do, so If the bumps don't touch I need taller ones right?
  2. Sep 2, 2015 at 8:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yes. If you have fully compressed the shock and your not on the bumps, then the shock is the bump stop. Not a good scenario and leads to the situation with that pic of the broken shock.
    tibblits920 and SWYPER like this.
  3. Sep 2, 2015 at 9:02 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Yes, 881 can net up to 2.5" but you said you wanted 2" which is why I mentioned the 880. 881 is what I recently purchased.
    I would add that the original quote you got for a grand would have included installation whereas the quote for 320 would mean you need to install it yourself or pay to have it installed.
  4. Sep 2, 2015 at 9:08 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Yup and that was buying the shocks from the off-road shop. I know if I set the 5100 at full lift, it's going to ride pretty stiff in the front. I might just have to buy each piece of the lift at a time, until I have all of the parts for everything to be installed and sense I don't have a spring compressor I will go ahead and let the shop install the whole lift for me as well as alignment. I heard they do great work and care about their customers.
  5. Sep 2, 2015 at 9:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No do NOT stack lifts. Your ball joints will hate you and it'llride horrible .
    Your 2wd so do a spindle lift. And then get 5" lift leaf springs and longer rear bumpsand shocks .
    If you bump up to 34-35s though you will have to tube the fire wall and cut the shit out of the fenders. No way around that.
    I'd leave it. Looks great as is
    johnboyTRD likes this.
  6. Sep 2, 2015 at 9:21 PM
    WheelInTheSky
    G
    Jackson Hole
    I considered buying my lift one piece at a time....
    Ended up getting all of it.
    Will put it on myself as I enjoy learning how to do new things and workin on my vehicles.
    You mentioned that not having a spring compressor is a reason for you to have your suspension done by a shop... Compressor isn't necessary if you own a jack. So, I'd say save yourself $600 and do the install yourself. If the lack of a spring compressor is the only thing holding you back then just do it yourself, it's all just nuts and bolts;)
    Also, if you were willing to drop a grand on billies installed by a shop, go ahead and drop a grand on real suspension and do the work yourself!! Not tryin to sway you or anything..:boink:
    2002Tacoma4x4 likes this.
  7. Sep 2, 2015 at 10:41 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    What kind of bumps to people generally run for first gens? I still need to check mine for any issues. Down the road I would mind getting hydro ones, but that'll probably be a while.
  8. Sep 2, 2015 at 10:51 PM
    WheelInTheSky
    G
    Jackson Hole
    I too am curious about bumps. When it comes to 2-3inches of lift how necessary are aftermarket bumps on a 1st gen?
  9. Sep 3, 2015 at 3:08 AM
    FortMyersTaco
    FortMyersTaco Member
    Red, four door 1st gen
    Lights, sound system
    Spindles are a little pricy for me. I think I'm going to go with a 1in daystar body mount. I know body lifts are bad, but I figured 1in won't kill it. Any opinions on what 1in body lift kits are the best? Or does everyone hate them to much to care haha
  10. Sep 3, 2015 at 6:08 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I would say very important from a do it right standpoint. Too much compression will wear out a set of leaves fairly quick as well as the bottoming out of the shocks and ruining them
    But if you don't wheel hard, prolly unnecessary. I still need rear extensions myself, just haven't got around to it. I'll post up pics when I finally get to that stage.
    Daystar, and other companies make some fairly easy to install bumps, you just need to determine the height of the stop.
    http://www.daystarweb.com/productlisting.php?make=ALL&prodcat=Bump+Stops
  11. Sep 3, 2015 at 6:32 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    That body lift is the best as it replaces the entire mounts and doesnt just add spacers. I may get one myself later on.
  12. Sep 3, 2015 at 8:24 AM
    Stone Cold ET
    Stone Cold ET Well-Known Member
    Adam
    Louisiana
    2003 DCSB TRD PRERUNNER
    Finally got around to mounting up my @HomerTaco Raptor-style grill insert. Thanks again! I want to pull it off again and paint the inside "lip" black but time hasn't allowed yet.
  13. Sep 3, 2015 at 8:30 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    You need to get rid of that chrome now :D
    Like what I did
  14. Sep 3, 2015 at 8:38 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    It will be a fun project for me and my dad to do. I do need to change out the front shocks anyways. And someone said they have the 880 but they had to increase the lift on the 5100 by a bit just to get a 2" lift.
  15. Sep 3, 2015 at 9:39 AM
    Stone Cold ET
    Adam
    Louisiana
    No doubt. Need to do the front and rear bumper. Used some wipe on plastic restorer that wasn't worth a shit so need to spray all the black too.
  16. Sep 3, 2015 at 9:57 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
  17. Sep 3, 2015 at 9:59 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Just don't forget the clear coat to make it look like its factory installed. My rear bumper is just painted with the base color.
  18. Sep 3, 2015 at 10:03 AM
    Madjik_Man
    Colorado Front Range
    So ummm, yeah about this. Do you think I should get new bump stops for the rear? Mind you my passenger side lower bump stop is missing entirely.
    What do you think I should do?
    tibblits920 likes this.
  19. Sep 3, 2015 at 10:06 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Did you get rid of them when you put the new suspension on? I just drilled out holes in the stock stops and put them back on after I installed dakars.
  20. Sep 3, 2015 at 10:06 AM
    Madjik_Man
    I didn't. Had no clue it was even missing until we put the new suspension on.
    Driver's side is still intact and fully stock.
