  1. Sep 7, 2015 at 12:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks good, you end up welding the brackets in like I did or just pound and drill.
  2. Sep 7, 2015 at 12:46 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Ended up swapping the rails over. I didn't want to drill more holes.
    Very happy with the final product.
  3. Sep 7, 2015 at 12:48 PM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    What year seats swap over again?
  4. Sep 7, 2015 at 1:09 PM
    Speedytech7
    Nice, they look great!
  5. Sep 7, 2015 at 1:12 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Hey gents know that the engine is out I'm going to clean up my engine compartment and paint it. Any one know where I can find the grey paint that is used in there. I'll do some google searching but just wondering if any one here knows.
  6. Sep 7, 2015 at 1:38 PM
    j0shu4
    Just flat black it.......
  7. Sep 7, 2015 at 1:45 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I believe 1996-2002. Mine are 2002
    Thanks man! Yours also.
    j0shu4[QUOTED] likes this.
  8. Sep 7, 2015 at 1:51 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I considered that but I like working on my truck and with the black inside I might loose a tool in there. I like the contrast of the grey and parts. Maybe any engine bay grey would be fine I guess.
  9. Sep 7, 2015 at 3:21 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Cleaned the mud out of my starter and flushed the power steering reservoir. I tried to fix my whine but it's still pretty loud.
  10. Sep 7, 2015 at 3:42 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Just the resovoir or the whole system. I jacked the front and turned wheels lock to lock with the return line off until clean fluid flowed. A bit of hose and a bolt to plug the nipple on the resovoir.
  11. Sep 7, 2015 at 3:58 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is the general consensus that Light Racing uca's are junk? I thought I read somewhere that they changed something in the design but never heard of it fixed the issue.
    I need new bushings in my driver side uca but I beat the crap out of it trying to break the bj loose a month or so ago and it might be causing alignment issues. Might just go with a cheap rock auto part then replace it as soon as possible.
  12. Sep 7, 2015 at 4:23 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Just the reservoir. Heard the screens inside could get blocked which would cause it to not flow as well.
    TACO TX[QUOTED] likes this.
  13. Sep 7, 2015 at 4:29 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    They have changed the design a little bit. I've had mine for over 2 years and I haven't had any issues. Oz-T has had them for over 4 years and hasn't had any problems. I don't pound on mine and they work great for fixing the alignment issues on a lifted truck.
  14. Sep 7, 2015 at 5:33 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Frame all cleaned and painted from the cab back. Waiting on shocks and springs.
    Silver02Taco, tibblits920 and j0shu4 like this.
  15. Sep 7, 2015 at 6:01 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Check your tensioner pulley, I replaced my PS fluid and cleaned the reservoir. Damn belt snapped because the pulley was seized
  16. Sep 7, 2015 at 9:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you going to add some frame reinforcement plates? Shock relocate? So much easier for both if the bed is off.
  17. Sep 7, 2015 at 10:01 PM
    ElScorcho
    ElScorcho You don't understand, I rekt it all the way home!
    Sacramento
    1995.5 Tacoma Xtra cab 3.4L 5spd
    20150907_193610.jpg Designated a seat for my dog.
  18. Sep 7, 2015 at 10:28 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yep. Got the Total Chaos shock relocate coming.
    It puts the shock outboard of the leafs and requires 1.25" spacers like they show here.
  19. Sep 7, 2015 at 10:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Thats what im gonna do to my double cab.
  20. Sep 8, 2015 at 6:07 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Pulley still spins freely. Rack is also relatively new as well. I'll probably replace the pump eventually.
    Let me know how you like it. Was thinking about going this route too.
    alphabravo[QUOTED] likes this.
