  1. Sep 11, 2015 at 4:50 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Some sweet GearWrench metal arrived. Been waiting like 20 years for a nice wrench set.
    (not my white sox)
    SWYPER likes this.
  2. Sep 11, 2015 at 5:07 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Ill be honest when I did my 4wd swap I cut a slit in one of my boots, had it on for for like 80,000 miles never had any issues. I would just check it for play and keep a watchful eye on it until you can replace it
  3. Sep 11, 2015 at 5:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'll tell you replacing one sucks because finding a press that fits it properly is impossible. But they are a lower stress item so it's probably not a huge deal if there isn't any play.
    We could change it together when I'm back over there, it's a pain but it's doable in an hour or so.
  4. Sep 11, 2015 at 6:03 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I got a pair from Amazon for about $28.
  5. Sep 11, 2015 at 6:25 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Looks like drivers side front diff/cv bearings is gone and im leaking gear oil real fast. Im in a small town with no internet for the time being. Does the ecgs 7.5" clamshell tool work for first gens? (seen one for sale that said it was modified for 1st gens) Also is it worth going with their bushing even though the needle bearing lasted 20 years? Wont let me see faq on my phone.
  6. Sep 11, 2015 at 6:26 PM
    bellassaiw10
    Currituck NC
    You sure it's the bearing and not just an axle seal?
  7. Sep 11, 2015 at 6:38 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Very sure. i know this isnt a common problem on 1st gens
  8. Sep 11, 2015 at 6:38 PM
    EngRWW33
    EngRWW33 Well-Known Member
    I agree, the needle bearings shouldn't cause leaks. As it wears, it causes vibrations. At certain speeds.
    With that said, the ECGS bearing was a great investment for me so far (5k miles). I could grab the drivers cv axle shaft and noticed a bunch of play before replacement with the ECGS bearing. Zero vibrations under 60 mph.
  9. Sep 11, 2015 at 7:09 PM
    Bullfrog 75
    Bullfrog 75 Well-Known Member
    Jeremy
    2002 red prerunner
    Drain and filled transmission fluid. Took out 4.25qts and refilled same. Checked condition of rear diff and all is good in the world.
  10. Sep 11, 2015 at 7:51 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Im going to run 4.5" bumps. Its going to be close but it should work. Might have to make bumps taller i guess if it won't. Or get 12" shocks
  11. Sep 11, 2015 at 7:57 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    They do a better job at dampening and controlling body roll when mounted closer to wheel. Wheel travel is more relative to shock travel. Right? If you where going for purely flex you would want them closer to center of diff.
  12. Sep 11, 2015 at 8:09 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Just got this in, hope to put it in sunday!
  13. Sep 11, 2015 at 8:17 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    good point
  14. Sep 11, 2015 at 8:24 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just lower the bottom mounts. and run the bigger bumps probably.
    really, go flex it out and see what happens :p
  15. Sep 11, 2015 at 8:27 PM
    06toyoboy
    06toyoboy Well-Known Member
    Did this
    And then some of this
    SWYPER and because_wumbo-truck like this.
  16. Sep 11, 2015 at 8:29 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    That sound deadening really helps. Put it on the floor of my truck and it helped with road noise for sure.
  17. Sep 11, 2015 at 8:37 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Road noise? You mean turn up the radio!!
  18. Sep 11, 2015 at 8:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I like my hearing. No thanks.
  19. Sep 11, 2015 at 8:51 PM
    otis24
    Mark
    California
    When I ride in anyone else's car I can't help but comment on how quiet it is.
    SWYPER likes this.
  20. Sep 11, 2015 at 8:54 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Just riding in a car in general, feels like im riding in a high dollar bmw compared to the truck lol
    otis24[QUOTED] likes this.
