  1. Sep 19, 2015 at 6:37 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Looks really nice!!!!
    I just did the WE caliper upgrade and I absolutely love it. It's a night and day difference.
  2. Sep 19, 2015 at 6:50 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Noted for future reference. I tried using a ball joint press as seen in a write up, but quickly turned to the dead blow hammer and socket method when that wasn't working. It was a lot of work, but it's done and squeak free so I'm happy :)
  3. Sep 19, 2015 at 7:13 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I used vise and hammer. Takes me a few mins per joint :notsure:
  4. Sep 19, 2015 at 7:16 PM
    Deere9798
    Deere9798 Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Do you know of a writeup or guide to changing rear driveshaft U-Joints?
    Thanks,
    Charlie
  5. Sep 19, 2015 at 7:18 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I tried the hammer method once and gave up qiuckly, lol. I use a 2 jaw puller and old socket to push it through and then use a 4 1/2" grinder and cut off wheel to cut the shaft and pull it out. The cap always seems to gouge trying to push it back out the other way so I just cut it.
  6. Sep 19, 2015 at 7:32 PM
    alee891
    Austin
    Black Hills
    Tacomaless
    No vise. Would have made things a thousand times easier/faster
  7. Sep 19, 2015 at 8:27 PM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    How much do you need to smash the wheel well for 33's?
  8. Sep 19, 2015 at 8:27 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Got it dirty :D First time ever going off road in this truck. It was a blast, need to do that more often :)
    tibblits920 and SanClementeTac01 like this.
  9. Sep 19, 2015 at 9:08 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Hammer on the pinch weld a little, cut some plastic. Don't have to do anything if it stays on the pavement
  10. Sep 19, 2015 at 9:12 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Finished the other side of my brake rebuild.
  11. Sep 19, 2015 at 9:26 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Shampooed my seats and and carpet
  12. Sep 19, 2015 at 9:34 PM
    mohavestubbs
    mohavestubbs Why not DIY?
    Denver
    97 2.4L
    Picked up a new transmission pan ($30) from pick n pull.. last guy stripped the bolt so i decided to replace the whole shebang. just need to pick up a new gasket and filter for my 2.4.
  13. Sep 19, 2015 at 10:00 PM
    alee891
    Austin
    Black Hills
    Tacomaless
    *edit: whoops didn't mean to repost
  14. Sep 19, 2015 at 10:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You bastard
    Again...
    you bastard
    I bet his won't go on and off easy anymore..if at all..
    because_wumbo-truck likes this.
  15. Sep 19, 2015 at 10:42 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Where'd you get access to a shampoo machine, I was thinking about doing the same to my trucks carpet. It's either that or get a new eBay carpet.
  16. Sep 19, 2015 at 10:43 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Got vinyl floor in mine. no need to shampoo
  17. Sep 19, 2015 at 11:20 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Getting ground loop noise from new stereo (alternator whine), so i put in a new ground line. I made a Y at the head unit harness and ran an extra wire to the ground point for the amp. Shit be thumpin now. Also, what is the bulb size for the A/C switch (last pic)?
  18. Sep 19, 2015 at 11:22 PM
    Speedytech7
    Oh gotcha, mine is a Group 34R. 55Ah (I think) and 770CCA
  19. Sep 19, 2015 at 11:35 PM
    Speedytech7
    Wiring is one of my favorite pastimes, nice job! The bulb in the A/C switch and also the hazards switch is the 3mm option on this page if I remember correctly.
    Caligula[QUOTED] likes this.
  20. Sep 19, 2015 at 11:43 PM
    Caligula
    Los Angeles, CA
    Thank you. I picked up a Portosol Superpro 125 soldering iron for this project, its made the process so much more efficient. Probably one of the better tool investments ive made.
    I want to install a blue LED to match the blue LEDs on the HVAC display. I changed out the dome top LED's in the panel with these three LED lights:
    http://www.ebay.com/itm/391219040085?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    The light spread is much better now.
