  1. Sep 22, 2015 at 8:14 AM
    viverr
    viverr Member
    WA
    '02 dcsb
    Makes sense, thanks. I'll back them off and retorque.
  2. Sep 22, 2015 at 10:14 AM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    After getting the majority of mud and dirt off of the rear end of the frame I sprayed lithium grease on the fuel filler neck, nuts and bolts and all welds on the frame.
  3. Sep 22, 2015 at 10:42 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    What's the lithium grease for?
  4. Sep 22, 2015 at 11:55 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Jason suggested that two sets of hands can do it while it is still mounted on the truck. In that scenario, I would think that it would have to be at full droop to be able to do that.
    Anytime you do any work/make changes on suspension components an alignment is indicated.
    I'm running 700# coils on my Kings. But I am at maximum weight with a plate bumper, a winch and aftermarket skids. Fully loaded, the truck weighs in at ~5400#.
    Even with all that weight, others that have driven my truck describe the front ride as stiff, but it is what I like.
  5. Sep 22, 2015 at 12:06 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    It would probably be safe to go with the 650# then. I might be able to weigh my truck this weekend. Like to see how it compares to yours.
  6. Sep 22, 2015 at 2:58 PM
    SanClementeTac01
    SanClementeTac01 Well-Known Member
    Dylan
    San Clemente, CA
    2001 Tacoma 4cyl manual 4x4 275k miles
    Fox 2.0 TRD Rear Diff Locker KM2's Snugtop Shell
    I'm in need of new tires. I am getting km2's again but I am thinking about moving up from 265/75/16 to 285/75/16 due to the recent 2" Coilover lift I added about a month ago. What has your experience been with bigger tires?
  7. Sep 22, 2015 at 3:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Have you re-geared yet? If not, you'll want to.
  8. Sep 22, 2015 at 6:08 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Wanting to order a new muffler. Thinking I'm gonna do a dual magnaflow setup on this truck. Should I go 14" or 18"? And if you have a link to a good deal on, post it up please
  9. Sep 22, 2015 at 7:17 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    By dual you mean single in dual exit muffler?
  10. Sep 22, 2015 at 7:24 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Sure does bring back some memories
    EB Group[QUOTED] likes this.
  11. Sep 22, 2015 at 7:28 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Forgot to post this but hit a milestone a few days ago. :D :D
  12. Sep 22, 2015 at 7:31 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
  13. Sep 22, 2015 at 7:38 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That's really funny.
  14. Sep 22, 2015 at 7:44 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    So I have a problem. I tried putting my 5125 rear bilstein shocks but the bottom will not go in. I bought it off someone on here and I was seeing if this was the right part #
  15. Sep 22, 2015 at 8:12 PM
    petronemoslappywag
    petronemoslappywag I gotcha a dollar. Now give it back.
    David
    North of Seattle
    '03 Xtra Cab 4x4 2.7
    Westin bug deflector and bed rail covers, Trail Gear rock sliders, LED Interior with footwell lighting, WeatherTech floor mats, 7 wire trailer harness
  16. Sep 22, 2015 at 8:20 PM
    KT406
    KT406 Active Member
    2001 Tacoma TRD SR5
    Borlo exaust
    IMG_20150922_192357406_HDR.jpg got rid of the chrome grill and emblems
  17. Sep 22, 2015 at 8:48 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Are shackles as easy to change as they look?
  18. Sep 22, 2015 at 9:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Mine is heavy as fuck when fully loaded its around 5600-5800.
    yea they will be great, just give them time. And a lil weight.
    Id go for 650s man. Happy medium. Will work great with not a lot of weight and will work weight with plenty of weight.
    18''. A 14'' will be retardedly loud as a dual. Think about it. 9'' of muffler per pipe vs 7''. Hell id actually get a 22'' really. That is killer loud on my Dads 2nd gen. So loud after we did headers he put a second muffler on.
    Did you put some grease in the bushings and on the post? that'll help a ton. My Foxes wouldn't go on it seemed. Added a bit of grease i and i hand pressed them on easy.
    yes.
    Take the tires off, put the frame on jack stands and a jack under the axle. Id actually recommend undoing the leafs from the axle. This will make your life easier as the axle won't pull the leafs down when you unbolt the shackles. The leafs will be heavy enough in that position. They it is super easy as long as nothing is rust fused together.
    Not taking the leafs off the axle, it'll be harder and a bit sketchy..
  19. Sep 22, 2015 at 9:13 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    I put some grease on the bushings and on the post at the top but I just greased the bushing that mounts on the bottom. I'm putting the boot down and I can't see why I'm having trouble fitting it in the post.
  20. Sep 22, 2015 at 9:14 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Thanks man. I have these Toytec adjustable shackles that I am gonna run while I wait for my springs from Deaver. Depending on how much lift I get from the springs I can lower the shackles.
