  1. Sep 29, 2015 at 7:14 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    My 3.4 won't do it either, so you aren't missing out too badly. haha
  2. Sep 29, 2015 at 8:04 AM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I will get on the people that did my front alignment asses today or tomorrow. Thanks.
  3. Sep 29, 2015 at 8:06 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    It only took them 20 mins to do. Either they do it right or they give me my money back. Had it alignmened by C&H tire.
  4. Sep 29, 2015 at 9:05 AM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    You could do it on the way down from Payson on the 87 for sure :D
  5. Sep 29, 2015 at 9:21 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    For a clumsy old truck, she is surprisingly stable at 102mph
  6. Sep 29, 2015 at 9:42 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Did they mention anything about frozen ecentrics? Sounds like a toe-and-go, but could be frozen cams.
  7. Sep 29, 2015 at 10:11 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Nope said nothing about frozen ecentrics. I saw the guy that did my alignment take my truck for a test drive.
  8. Sep 29, 2015 at 11:05 AM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I'll re-measure when I get home from work. What psi am I measuring at and on or off the truck? Should mention that I've already put some wear on the tires so they'll be less than they were brand new.
    And yes, I was quick to react, don't want any misinformation out there and figured you may not have the tire so might be guessing based on other tires. I think someone said they are 32.5"? They were 33 the day I put them on:notsure:
  9. Sep 29, 2015 at 11:16 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    so I got the front done for my OME kit and had my brother take it to the shop for alignment. says there is still a vibration but tracks right. also said the CVs are "clicking" a bit. stock CVs with 138k and never any hard wheeling. thoughts?
    I'll be getting the rear done Friday hopefully, will the change in angle from the rear affect anything?
  10. Sep 29, 2015 at 12:20 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Guess I check the brake fuild resi and see if I've lost any. Not sure how long it's been leaking though.
  11. Sep 29, 2015 at 1:02 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Hey now hey now, it was auto corrects fault!
    Usually measured at whatever air pressure you run them at, I run mine at 34 psi.
    Correct I don't have the tire but when I was deciding between coopers and dynapro all the info I found on people who were running them said they were less then what the specs say, which is typical. I said 32.5 but might be wrong, been awhile. Mine are 3.6 according to the specs but measure exactly 33 on the truck.
    Weird yours measure larger then what the specs say.
    Check the bleeder valve also, doesn't take much to cover the back of the wheel with fluid. Worth a shot, a lot easier to fix that.
  12. Sep 29, 2015 at 1:48 PM
    Madjik_Man
    Colorado Front Range
    Hauled 1.25 tons of rock.
    The Dakar leafs are unreal with weight on them.
  13. Sep 29, 2015 at 1:59 PM
    batcat420
    batcat420 I'm a Blue Ribbon man.
    Scott
    Atlanta
    2022 Lunar Rock SR5 Trail Edition
    I'm looking in to getting a new cat for my 2000 2.7 and I'm seeing front and rear units for sale. What's up with that? Which one, if not both, would be the most likely candidate for throwing a P0420 code?
  14. Sep 29, 2015 at 2:35 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Get a laser temp reader and check both inlet and outlet on both cats. The temp should be hotter at the outlet.
  15. Sep 29, 2015 at 3:27 PM
    Rgarcia133
    Rgarcia133 Member
    Roberto
    Dinuba, CA
    04 Prerunner SR5
    Well this was about a week ago but I'm liking where she sits now. I put fabtech coilovers on my taco :). I wanted the "nose high" look btw. I did it all at school :D with the help of a friend and supervision of my auto teacher. I forgot to measure from the center of the hub to the top of the inner fender before I removed my stock struts and coils so I am not sure how much of a lift they added. I'll post a picture of it off the lift when I remember to take one lol. 20150929_124947.jpg 20150929_124939.jpg
    tacomatrd22 likes this.
  16. Sep 29, 2015 at 4:31 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I've done it going down hill. It's possible. But the governor will kick in too. Then again I'm the guy without a motor right now.
  17. Sep 29, 2015 at 4:37 PM
    westhumboldt
    westhumboldt Well-Known Member
    Arcata,Ca
    97 Tacoma sc 4x4
    Doug Thorley headers, urd 7th and Trd Supercharger, bilstein lift, trd locker just installed.
    Supercharge it I can get to max easy. Its like 4000 rpms in 5th gear. My old tacoma 5spd would scream at 3000 in 5th going 70 must have been geared different or something.
  18. Sep 29, 2015 at 4:47 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    @TXSmiley thought that was you, I was like wait you have a jeep...
  19. Sep 29, 2015 at 5:38 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Check if you have driver side lean. I have it and I'm paying someone I know to do it, after last week I'm done with my suspension for now.
  20. Sep 29, 2015 at 5:42 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Done this today. Very easy but very time consuming. I will do the gray wire mod sometime this week.
    because_wumbo-truck likes this.
