  1. Sep 29, 2015 at 5:45 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I might need to look into that. As you all know, 110mph is when a Tacoma's flux capacitor kicks in.
    TheSpeediTurtle and Holy schmidt like this.
  2. Sep 29, 2015 at 6:07 PM
    Caligula
    Los Angeles, CA
    The question is are they both 3 way catalytic, or separate reduction and oxidation catalytics? If its the latter, then you would need to replace the cat that is closest to the rear O2 sensor, as this one is responsible for recombining the excess CO, HC, and O2. If its not functioning, then you would have unused O2 exiting and hitting the sensor.
    If you get a gas readout done, you can tell for sure.
    Remind me, where is the rear sensor, its after the second or first catalytic?
  3. Sep 29, 2015 at 7:59 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Does the 3rz and 5vz use the same fuel pump in the tank?
  4. Sep 29, 2015 at 8:34 PM
    Caligula
    Los Angeles, CA
    Yes sir
    SilverGhost[QUOTED] likes this.
  5. Sep 29, 2015 at 8:48 PM
    Chodey
    Chodey New Member
    Cody
    2000 Toyota Tacoma 4x4 stock
    Thoughts on jegs baja 8 steel wheels?
  6. Sep 29, 2015 at 9:55 PM
    Rgarcia133
    Rgarcia133 Member
    Roberto
    Dinuba, CA
    04 Prerunner SR5
    Well I'm not sure if I have it or not yet, haven't really checked except for just eyeballing it but just in case I've set the driver side at 2 threads higher than the passenger side. Hopefully that works.
  7. Sep 29, 2015 at 9:56 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Okay I have a rear squeak that exists both when I start driving forwards and backwards as in the the first initial turn of the driveshaft. I read that it could be a u joint going bad. Help!?
  8. Sep 29, 2015 at 10:00 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Grease them and see if it stops.
  9. Sep 29, 2015 at 10:04 PM
    TacoVio
    Kolton
    CO/WY
    See I greased them about 3,000 miles ago but I just read that the second to last zerk going into the rear diff is only supposed to have 3 pumps of grease. I will grease them and see what happens
  10. Sep 29, 2015 at 10:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is referring to the slip joint. The 2nd to the last grease fitting does not grease that last u-joint.
  11. Sep 29, 2015 at 10:15 PM
    TACO TX
    Kelly
    Denison ,Texas
    Not the slip yoke, just the front and rear u joint on the rear shaft.
  12. Sep 30, 2015 at 1:31 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Ok I still have a harsh engagement in the transmission, anytime you put it in drive or reverse it bucks hard. Ive changed the tranny fluid and its still there, there is also a long delay for it to engage. Some say that could be a dirty screen in the tranny pan. Almost seems like there is maybe play in the rear diff and its cause it to slam the gears hard. It also rolls alot more then it should when you put it in park, like there is alot of play.
    Brie likes this.
  13. Sep 30, 2015 at 6:23 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'm no expert at this, but assuming you have an automatic, it sounds like the torque converter is going bad,
    Brie likes this.
  14. Sep 30, 2015 at 6:30 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Interested in what others say about the bold. My inner CV boot's blew the moment I put my lift on and started clicking not long after. Not sure if this is binding, or just CV's with no grease. I am assuming you aren't running a diff drop right? I am not either.
  15. Sep 30, 2015 at 7:18 AM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    That might work for you. Good luck! I have 1/4" lean on my driver side than the passenger side. Which is somewhat annoying to look at.
  16. Sep 30, 2015 at 7:29 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Getting my alignment today again. They gave me $10 off but they said I put new strunts (Coils) after the alignment which is complete bullshit. If it's not straight this time they better be ready for a lawsuit.
  17. Sep 30, 2015 at 7:49 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Possibly just old brittle boots having to run at a different angle. My boots ripped shortly after my lift too. Replaced with new shafts/boots and they are fine now.
  18. Sep 30, 2015 at 8:03 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Yes i do. It shifts fine and there is no problems when driving, just when its engaging.
  19. Sep 30, 2015 at 8:09 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Alright alignment done. And everything looks pretty good.
  20. Sep 30, 2015 at 11:08 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Good to know. I have my spare CV's ready to be rebuild with SDHQ boots and do the bootslide mod at the same time. Will swap the current CV's with NAPA lifetimes as trail spares.
