  1. Oct 2, 2015 at 11:08 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Never found one in stainless either......I think caligula ^^^^^^^ has a good idea. Get a different o2 sensor to save you from removing and rewelding exhaust pipe. If I understand correctly?
  2. Oct 2, 2015 at 11:10 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  3. Oct 2, 2015 at 11:17 AM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I'd rather not, as then I'd have to replace the front O2 sensor as well. I think that I'll just have the guy weld one of these O2 flanges on, shouldn't need to remove the exhaust pipe for that.
    Headed to work now, I'll look for a stainless one later. I don't have the tools to make one, so I'll keep you in mind if no stainless ones are on the market.
  4. Oct 2, 2015 at 11:19 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    be careful not to poke a hole :anonymous:
    :anonymous:
  5. Oct 2, 2015 at 11:21 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Hmmmmmmm I'ma gona assume you might have poked a hole in yours...
  6. Oct 2, 2015 at 11:21 AM
    Caligula
    Los Angeles, CA
    Wait a sec, is all this for the upstream or downstream sensor? If its the downstream, then you dont need anything special, any generic sensor will do. Its a classic narrow band sensor that is just monitoring post cat O2 consumption, it has no impact on engine management.
  7. Oct 2, 2015 at 11:23 AM
    Caligula
    Los Angeles, CA
    :boink:
    Youre going to have to pull it out anyway. Just buy a new reservoir, problem solved.
  8. Oct 2, 2015 at 11:24 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That'd be my guess haha, I had nothing on the bottom I just need to change my fluid. But my A/C pulley froze so that fixed my problem :anonymous:
  9. Oct 2, 2015 at 11:41 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    who me??? naaa :p
    No shops had reservoirs in stock and it was all taken apart, so F it!! I will be replacing it eventually...:annoyed:
    nagorb[QUOTED] likes this.
  10. Oct 2, 2015 at 12:13 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Deaver has finished my custom springs. Hopefully I will have them next week.
    Silver02Taco likes this.
  11. Oct 2, 2015 at 1:55 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Was gonna build a sleeping platform but found this on craigslist for $65. :woot: I need to do something about the carpet... but way better than building one!
    tibblits920, Brandoniiw and SWYPER like this.
  12. Oct 2, 2015 at 4:05 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    nice find!
    WildLand likes this.
  13. Oct 2, 2015 at 4:09 PM
    Caligula
    Los Angeles, CA
    Somewhere theres a 1970s porn director missing his camper platform.
    Be sure to clean it well before use. :D
  14. Oct 2, 2015 at 5:50 PM
    Madjik_Man
    Colorado Front Range
    Seriously. The only way to clean that thing is with a blow torch.
  15. Oct 2, 2015 at 6:07 PM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    Anyone know where I can get an Hi-Jack Bed mount?
  16. Oct 2, 2015 at 6:19 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Could use relentless bars or if it's small enough put it in a toolbox
  17. Oct 2, 2015 at 6:21 PM
    TuckGraham
    Tg
    Montana
    Do you have a link for that?
  18. Oct 2, 2015 at 6:26 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    SWYPER likes this.
  19. Oct 2, 2015 at 6:33 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Need some help. So I've been looking at ECU's and Im finding two different part numbers for them. My question is, is one going to be a TRD and the other NON TRD? An ebay one I saw was a TRD and the part number is 89661-0Y021. Then on a website where I'm looking up parts I also see 89661-0Y020.
  20. Oct 2, 2015 at 6:34 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Trust me. The carpet will be removed! @DCSBFTMFW told me I should take bets on how many pounds of pubes I'll vacuum out of it
    DukesTaco and Caligula[QUOTED] like this.
