  1. Oct 5, 2015 at 8:13 AM
    matt 157
    matt 157 Well-Known Member
    California
    2003 Black Xtra Cab 4WD SR5 TRD
    Pioneer DEH 8400 head unit/deck, Crunch 1100 watt amp, 12" Kenwood subwoofer, Kicker mids & tweeters, AllPro front tube bumper, Smittybuilt tow hooks, (welded pipe for muffle) straight-pipe, 4 orange "Raptor" lights in grill, Duratrac tires, American Eagle rims, ProComp 2" front leveling kit, Plasi-Dipped black on chrome trim, PIAA fog lights w/ in-cab switch, Unidin CB/Firestik II/8 ohm PA speaker, TRD leather 5-speed shifter knob
    Little bit of playing in the sand @godsend
  2. Oct 5, 2015 at 8:19 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Fucking awesome
  3. Oct 5, 2015 at 9:08 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    5100s/Eibach. Extended brake lines from wheelers on the way. LR UCAs.
  4. Oct 5, 2015 at 10:12 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Not sure what you mean by leaning toward down ward slope. There is definitely more body roll.
  5. Oct 5, 2015 at 10:15 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    How long are your rear shocks? Also how much rear lift is from springs and how much from shackles?
  6. Oct 5, 2015 at 10:22 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    5100s in the rear also with wheelers progressive 1.5AAL leaf pack. Overload still in. no shackles.
    because_wumbo-truck likes this.
  7. Oct 5, 2015 at 10:24 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    I guess since there is more body roll on turns due to the force when turning, will I experience the same affect when driving on off camber roads where the weight of the body will make the cab lean/roll towards the downward slope of the off camber road? Hopefully that makes sense.
  8. Oct 5, 2015 at 10:33 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah, it seems that Bilstein does not publish the lengths of the 5100 series shocks since they are sold by "application" rather than length. My guess is that the shock matches the OEM lengths which means you might not get much droop. You would have to load it on a ramp to see the full flex rather than just lifting the rear strait up.
    I still have the OEMs on while my springs and shocks are on order. I think I only get like 4 inches of droop on a strait rear hang.
  9. Oct 5, 2015 at 10:37 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    There are no brakes on the front so if you lift the rear it will want to roll forward and slide sideways. I derped something similar so now I block the tires or use a crowbar to engage the front brakes when lifting the rear.
  10. Oct 5, 2015 at 10:39 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Hmm, I wonder if a line lock would be smart for keeping the front brakes on in emergency lifting situations.
    alphabravo[QUOTED] likes this.
  11. Oct 5, 2015 at 11:11 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    I had my 4wd engaged and in first gear lol I'm not that dumb. The ass end was sliding to the side rather than flexing more
  12. Oct 5, 2015 at 11:49 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    This wont happen unless you have some really worn out springs and shocks. It rolls from the force of turning, it wont lean simply because the truck is running along a small slope.
    chowwwww[QUOTED] likes this.
  13. Oct 5, 2015 at 11:54 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Thank you. Just the information I was looking for.
  14. Oct 5, 2015 at 12:23 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Wow, these Whiteline LCA bushings are beefy. I'm kinda glad I chickened out on the ES install.
    Anybody want an Energy Suspension kit with my old OEM bushings :D
    2scars and Silver02Taco like this.
  15. Oct 5, 2015 at 12:28 PM
    scocar
    scocar hypotenoper
  16. Oct 5, 2015 at 12:32 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Let me know how these work out, I am due because my alignment cams are seized.
    Speedytech7 likes this.
  17. Oct 5, 2015 at 12:32 PM
    scocar
    scocar hypotenoper
    Took pics for the sale thread, drafted the ad, still have not posted it, I hop tonight. Newborns fuck with your ability to complete any task no matter how small...o_O
    A small sample...
    Speedytech7 and quetzal like this.
  18. Oct 5, 2015 at 12:40 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Will do. Prolly start a thread just cuz there is so little about bushings on here.
    These bushings have a slight step in them you can see on the outside metal sleeve. It is pretty subtle but there are several guys running them with no problem. It might even match the OEM bushings but mine were so corroded I couldn't tell if they had a step. Whiteline doesn't officially support these yet for first gens. Early 2016 they said.
  19. Oct 5, 2015 at 1:21 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Was thinking of changing lca bushings in December also. Hopefully you'll have a write up by then.
  20. Oct 5, 2015 at 3:05 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    What brand of sliders?
