  1. Oct 9, 2015 at 1:18 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  2. Oct 9, 2015 at 1:20 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    You're effectively dropping the drain plug an inch or so and it sticks out waiting to get hit by rocks.
    Plus if you dont have a skid getting to your plug isn't difficult. Fumoto is basically a shutoff valve which makes is great for those who have skids who would normally have to drop them to get to the drainplug.
  3. Oct 9, 2015 at 1:22 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Alright thanks, might just do the fog light mod today then see if the LEDs I have are bright enough to see during the day.
  4. Oct 9, 2015 at 1:25 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Ah I see that makes sense. My skid has a hole cutout for easy access to the drain plug that's why I've never bought one
  5. Oct 9, 2015 at 1:27 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    This.
    I like the valve because it allows you to drain a small sample of oil for testing. Or if you overfill you can drain a bit out. Also it allows you to do the oil change when the engine is HOT!!!
    Edit: Just be sure to buy a couple of extra washers. The threaded portion of the valve is longer than the thickness of the pan and will cause some oil to be left in the pan if you don't have the extra washers. Alternatively you could probably shorten the threaded stem on a grinder.
    BYJOSHCOOK likes this.
  6. Oct 9, 2015 at 1:29 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Mine does to, but I don't like getting oil all over the top side of the skid and dripping all over town. I drop my skid everytime and it takes longer to do that than to change the oil.
  7. Oct 9, 2015 at 1:30 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I haven't changed the oil with my skid yet :anonymous: I need to within the next 800 miles or so
  8. Oct 9, 2015 at 2:28 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Getting oil all over your undercarriage helps protect against rust.
    TheSpeediTurtle and scocar like this.
  9. Oct 9, 2015 at 3:16 PM
    scocar
    scocar hypotenoper
    Drop the skid on one piece on your chest/knees, and when goign back in, let it rest on your knees/chest while you position it to start the bolts back in. The frton has tabs to hang while you start a couple in front, then push the back up and start a couple there. Does not take long at all. Never take the two parts of the skids apart, PITA.
    TACO TX[QUOTED] likes this.
  10. Oct 9, 2015 at 3:36 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Where did the bumper come from, cant find one for a fist gen on their site?
  11. Oct 9, 2015 at 3:49 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I'll just leave these here :D
  12. Oct 9, 2015 at 4:07 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :jellydance:
    2002Tacoma4x4 likes this.
  13. Oct 9, 2015 at 4:18 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    So finally caught up on about 20 pages of reading to kill shift time.
    What is that cleaner y'all use for the engine bay, simple green or something green? Want to get it cleaned up and detailed before the s/c goes in and the new H/O alt.
  14. Oct 9, 2015 at 6:08 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    What would you guys recommend for an air intake system other than factory and k&n? Rock ripper any good? 3RZ
  15. Oct 9, 2015 at 6:10 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    I don't know about the 3rz but I liked Airaid as well as aFe
  16. Oct 9, 2015 at 6:16 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Something mild probably like Simple Green. Then some kind of under hood Armor All type stuff for all the plastic.
  17. Oct 9, 2015 at 6:20 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
  18. Oct 9, 2015 at 6:20 PM
    Nervo19
    Nervo19 Well-Known Member
    Simple Green works great. Just don't let it sit on aluminum or paint for very long before rinsing. It can etch aluminum. Also Purple Power from Walmart works well. Same cautions.
  19. Oct 9, 2015 at 6:22 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    I'm only finding replacement filters by these guys.. I'm looking more for something to replace my stock intake tubing/airbox that isn's k&n
  20. Oct 9, 2015 at 6:24 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    If you plan to leave them there overnight, please post your address. Hahahha
    because_wumbo-truck likes this.
