  1. Oct 18, 2015 at 6:34 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Have you ever cleaned / checked your PCV valve? Oil pressure warning light come on?
  2. Oct 18, 2015 at 6:36 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    First off..thank you for being available to help me right now. Secondly, no, this is the first time I've dove into my intake system to check/clean it. Never had a light come on.
  3. Oct 18, 2015 at 6:36 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Maybe your getting too much oil put through the intake to get re burned and the air isn't able to suck it all in the engine so its running down and collecting in there. :notsure:
  4. Oct 18, 2015 at 6:40 PM
    RustyVT
    Vermont
    Excessive blow by maybe? I'd check the pcv first. It's super easy on the 2.7. You can easily check to see if they work by shaking them back and forth. If they make noise they're generally okay. here's a vid. https://www.youtube.com/watch?v=ayghxiu4KmA And also when was the last time you changed your plugs? My turbo volvo runs like turd if the gap is even a little off. Tacoma is a lot less fussy but could be an issue. And don't take the grommet out to check it, just take the PCV valve itself. Half the time the grommet turns to dust like in the vid.
    tibblits920 likes this.
  5. Oct 18, 2015 at 6:46 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Great video.. I'm gonna check the valve I bet it's fkd. Spark plugs are pretty new I'd say less than 10k
  6. Oct 18, 2015 at 6:46 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    If your getting that much oil in your intake make sure your not getting to much oil in the exhaust. You don't want to plug a cat.
  7. Oct 18, 2015 at 6:48 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I think it is called a resonator and is supposed to generate a negative pressure in order to draw fumes from the crankcase or someplace and feed it back into the intake. It is part of the pollution control system. When I got my truck the tube going in had been blocked off so I don't know where it came from for sure.
  8. Oct 18, 2015 at 6:50 PM
    RustyVT
    Vermont
    ^+1000. Seriously. I had an 89 crown vic that I dumped 800 bucks in parts into because it had a terrible misfire, I replaced every sensor and ignition related thing on it just to find out the passenger cats were so clogged it was only blowing exhaust out of the tiny hole in the manifold. All that time and money just because of a clogged cat.
  9. Oct 18, 2015 at 6:55 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    You guys!.. I've been saying my cat is clogged for the longest time to my friends because that thing is old and rusty and corroded and smells like shit..haha my friend just gave me a cherry bomb muffler to put in its place :devil: that coupled with the o2 simulator from URD I should be good to go.
  10. Oct 18, 2015 at 6:58 PM
    RustyVT
    Vermont
    If you live in a state where you can go without cats go for it. I can't sadly. My whole exhaust system is rusted beyond hope but I'm determined to get it through another winter before buying a stainless.
  11. Oct 18, 2015 at 7:02 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    It also looks like LCE long tube headers in the pic. So if your cat was plugged you could of lost some rings and now blowing oil. Eventually misfiring and loosing your motor. It's what happened to me. You really need to find out where all that oil is coming from and where is it going. Do you check your oil often and see if your loosing quite a bit?
    This is worse case scenario.
  12. Oct 18, 2015 at 7:08 PM
    RustyVT
    Vermont
    He's 100% right. Misfiring toasts engines. That crown vic of mine had about 90-110 psi on the right side bank cylinders after the 3k miles of heavy misfiring. But granted the one day I had the thing on the wood as fast as it could go bouncing off the rev limiter while misfiring probably did most of the damage. I was honest to god hoping that thing would blow up so I could just throw another 302 in it, just kept chugging along though. Traded the pos for my volvo. :anonymous:
  13. Oct 18, 2015 at 7:11 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Yes you are correct. LCE headers. That's pretty scary to think about man. I don't check it often but when I do its always at its mark.
  14. Oct 18, 2015 at 7:13 PM
    RustyVT
    Vermont
    Do a quick compression test if you're worried. I think you're probably fine though.
  15. Oct 18, 2015 at 7:16 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Is there such thing as a "quick" compression test? Lol
  16. Oct 18, 2015 at 7:17 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Then you should be good. Im not trying to scare you. Just sharing my experience with my 2.7 with LCE headers. But VVVV
    X2
  17. Oct 18, 2015 at 7:18 PM
    RustyVT
    Vermont
    Quicker than replacing rings :thumbsup:
  18. Oct 18, 2015 at 7:20 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Silvergoast how did you like the lce headers. How did it improve the truck
  19. Oct 18, 2015 at 7:21 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    A surprisingly large amount of oil came out of this thing
    Damn. I am down to halfway between the marks on my dipstick.
  20. Oct 18, 2015 at 7:24 PM
    RustyVT
    Vermont
    Really sounds like pcv to me personally. Does it run decent after it smooths out?
