  1. Oct 23, 2015 at 10:02 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Drill holes farther back on the frame and remount?
  2. Oct 23, 2015 at 10:06 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Not that easy. Ive looked in to it but it would be a lot of work. I've been looking into buying a welding. If that happens and I have some time, I might give it a shot. I can live with it how it is for now though. There's another guy on here that had a 96 with a plate bumper that has a HUGE gap. Can't remember his name though.
  3. Oct 23, 2015 at 10:06 AM
    Madjik_Man
    Colorado Front Range
    Well you said you have 33x12.5s on your truck. That does two things to your mpgs:
    1. Lowers them. Heavier, more friction, etc will obviously have an effect on your fuel economy.
    2. Is your speedometer calibrated for the larger tires? If you left the stock speedo gear in with the larger circumference tires, theoretically your odometer/trip meter is probably reading shy of actual mileage.
    Have you ever cleaned the intake (MAF, throttle body, IAC)? Do you know the truck's history of such maintenance?
    Same question for spark plugs and wires.
    ^ I'd start there. Cheap and easy maintenance.
  4. Oct 23, 2015 at 10:11 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You mean to tell me this whole time I mistook this pissing match as friendly banter?
    I'm very well hydrated, thanks for asking!
  5. Oct 23, 2015 at 10:20 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Pitman puller. Cheap tool that saves lots of headache. A variety of uses on the 1st gen Tacoma. I keep it in the truck.
    Current gas mileage. I just drive it, no egg under the pedal. 285/75-16 E rated tires.
    :D
    at_olw likes this.
  6. Oct 23, 2015 at 10:23 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Just throw a winch in there and say it's designed like that. You'll won't tell the difference. It is a few inches to far tho. Besides that it lines up well. Mine sits out 6-7" but I designed it that way so the fairlead sits behind the skid not on it.
  7. Oct 23, 2015 at 10:25 AM
    Dustyktm
    Dustyktm Member
    Devin
    99 Prerunner v6
    intake trail gear bumpers
    My speedo is calibrated I will try and give updates
  8. Oct 23, 2015 at 10:26 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Allpros is like that and CBIs too. Not many that don't as most are designed with 01-04s.
  9. Oct 23, 2015 at 10:27 AM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    I bet you it's the tail light fuse. Check it and see
    MadTaco461[QUOTED] likes this.
  10. Oct 23, 2015 at 11:15 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I could of sworn I checked that one cuz I noticed it at night. I'll check it after work. It is a relay and a fuse correct?
  11. Oct 23, 2015 at 11:32 AM
    at_olw
    at_olw Banned in D.C.
    Today I... Walked outside. Saw my pile still on jack stands, instead of on the trip it's supposed to be on. Shook my head and walked back inside.
  12. Oct 23, 2015 at 11:35 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I believe that's called diarrhea and if you’re peeing it yes you probably should be going to the doctor.
  13. Oct 23, 2015 at 12:20 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I think the pre-runner style bumpers are designed with high speed through the brush in mind. In that case you want the bumper to stick out and keep branches from slapping into your grill and hood.
    552Jrider likes this.
  14. Oct 23, 2015 at 12:20 PM
    JDEMELLO
    JDEMELLO Well-Known Member Vendor
    Corona Ca
    none
    If we did that, it is very very old. And had to be to be custom requested to be that far out in the front. We wouldn't do one that sticks out so far unless it was requested like that.
    kigmob[QUOTED] and Silver02Taco like this.
  15. Oct 23, 2015 at 12:42 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    FIFY :D
  16. Oct 23, 2015 at 12:51 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Its OK if the box is from China.
  17. Oct 23, 2015 at 1:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I am sincerely sorry for the tragic sight. I know it all too well..
    But I am excited for photos :popcorn:
    Why is it on jack stands still?? Diff issues?
  18. Oct 23, 2015 at 1:36 PM
    reef
    reef Well-Known Member
    04 4WD
    bumpers arrived.
  19. Oct 23, 2015 at 1:38 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Figured out it's time for a new battery just a little while ago...awesome
    Last one was replaced in 09
  20. Oct 23, 2015 at 1:38 PM
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
