  1. Oct 24, 2015 at 7:11 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Awesome, I had figured I couldnt have changed anything just by moving them around. I just got it aligned a couple weeks ago. Gonna have to go back to that place and have em do it properly this time I guess. The positive camber is ridiculous on the driver's side
  2. Oct 24, 2015 at 7:14 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'd say you were due!:eek:
    ClevSix[QUOTED] likes this.
  3. Oct 24, 2015 at 7:19 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    LOL Actually the oil still looked like it was still good to go for a while longer. ;)
    Deathbysnusnu[QUOTED] likes this.
  4. Oct 24, 2015 at 7:21 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    the vertical bolt in the top of the rack plus the long horizontal bolt should force the correct/same position.
    you might check your ball joints and tie rod ends and lca bushings if you are pulling.
    also if your alignment bushings are frozen they might not tell you and just charge you to align it the best they can
  5. Oct 24, 2015 at 7:22 PM
    Tacoma_11
    Tacoma_11 Member
    Leo
    2003 Tacoma TRD
  6. Oct 24, 2015 at 7:31 PM
    Mischief
    Mischief misadventurer
    Christi
    Duke City NM
    2004 Tacoma crewcab TRD
    My truck came minus the windshield washer apparatus. All I have is a 4 prong plug and a hose hanging down in front of the right front tire. Would someone please tell me what I am missing. I got a res but it has a 2 prong plug on the pump and a hole in the bottom. I guess the hole is for a sensor which I suppose is what the 4 prong plug is about but I don't know what parts I need to hook it all up. Is there a connector pigtail that hooks the pump and sensor up to the 4 prong plug?
    Thanks for any info
  7. Oct 24, 2015 at 7:40 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Photoshop!
  8. Oct 24, 2015 at 7:44 PM
    RustyVT
    Vermont
    Checked all those things today as well, they were all nice and tight. I had thought about the alignment cams being frozen up, but the LCAs are only 2 years old from when I got my frame replaced, Seems hard to believe they'd be frozen that quickly.
  9. Oct 24, 2015 at 7:44 PM
    Tacoma_11
    Tacoma_11 Member
    Leo
    2003 Tacoma TRD
    Lol... I taped the flap and cut the tape with a utility blade and paint sprayed it.b43f5797ae40ff65051e06c0e82cd46b_6cf59a5f381b9e52b8c946ec45a9c9e266d5ea77.jpg
    SWYPER likes this.
  10. Oct 24, 2015 at 7:58 PM
    Medina33
    Medina33 Well-Known Member
    Erik
    Lax
    2010 dcsb 4x4
  11. Oct 24, 2015 at 7:58 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I have a slight clunk that i notice when i turn right fairly tight and fast.
    I heard it earlier when i backed up and turned sharply at the same time, first time ive heard it this way and it was fairly loud.
    Steering rack? Should i worry about it?
  12. Oct 24, 2015 at 8:57 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    what uca do you have?
  13. Oct 24, 2015 at 9:06 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Stock
  14. Oct 24, 2015 at 9:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It is in one of the rack mounts. Or at least mine is. I found it but I don't see any way of stopping it.
  15. Oct 24, 2015 at 9:30 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
  16. Oct 24, 2015 at 9:52 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  17. Oct 24, 2015 at 9:56 PM
    RustyVT
    Vermont
    I didn't win the million, unfortunately.
    Speedytech7[QUOTED] likes this.
  18. Oct 24, 2015 at 10:01 PM
    AZTacoSupreme
    AZTacoSupreme Well-Known Member
    Anthony
    Chandler, AZ
    2006 LS430/ 2004 Sequoia 4X4
    Changed my errl, lubed drive shafts and rotated my tires. Also noticed my steering rack is leaking, awesome
  19. Oct 24, 2015 at 10:01 PM
    RustyVT
    Vermont
    Ever since I put my bumper on my truck it's clunk city, driving me crazy because I see no reason why my bumper would cause it. My steering rack used to clunk on turns too, put some new poly bushings in it and it's quiet now amazingly. But intensified the other clunks that are driving me even more crazy now because they're like blown strut level loud.
  20. Oct 24, 2015 at 10:06 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Ya its a reman rack from rack dr and poly bushings
