  1. Oct 24, 2015 at 10:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Might it be your shackles hanging on the bumper.
  2. Oct 24, 2015 at 10:37 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    I had thought about that haha, but no, sadly not it. I slammed on my brakes to see what that sounded like, was more of clang than a clunk. It definitely seems more suspension related. My plate bumper is mounted to the stock frame end caps / stubs that the original rode on. I didn't realize how chintzy those mounts were until I was able to move the current bumper back and forth a good 1 1/2 inches when I push on the grill guard. I assume it's the end caps flexing but the bolts are tight so it doesn't make sense. So I'm not sure why it's able to flex like that, unless something I can't see is loose, or the metal in the caps are just stupid weak and bending. I'm wondering if the clunk is from the bumper bouncing up and down over bumps, doesn't seem to be though, because I can see the grill guard while driving and it seems pretty static. I'm thinking possibly top strut bushings? I didn't realize the Bilsteins didn't come with bushings so I re used the old ones. Here's a pic of how the bumper is mounted, it's a piece of 2 inch square tube welded to that end cap / stub. The bumper rides on the square tube. So it is front heavy for sure. Doesn't seem to make the same clunking noise I'm after when I flex it back forth by hand though. Probly needs more reinforcing but for now I'm fine with it unless it is in fact clunking.
  3. Oct 24, 2015 at 10:44 PM
    P.Blackley
    P.Blackley Well-Known Member
    Patrick
    Layton, UT
    99 Tacoma 4WD SR5
    Fox extended coilovers, LR UCA's, Deaver J59's W/ 12" Fox triple bypass shocks
    Replaced my steering rack bushings today, drives much better now.
  4. Oct 24, 2015 at 10:46 PM
    RustyVT
    Vermont
    Glad I'm not the only one that did that today. Hopefully you didn't struggle for 2 hours trying to put the U clamp on backwards like my dumb ass did until I realized what I was doing. Ah well, live and learn I guess.
  5. Oct 24, 2015 at 10:51 PM
    P.Blackley
    Patrick
    Layton, UT
    99 Tacoma 4WD SR5
    Nah, only took me 30 mins to realize that one, my struggle was getting the center bolt to unsieze when you cant really get on it.
  6. Oct 24, 2015 at 10:55 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    If you have access to a welder fixing the movement on the bumper is pretty easy. There's multiple ways to do it but I'm pretty sure there's a writeup on ttora.
  7. Oct 24, 2015 at 10:56 PM
    RustyVT
    Vermont
    I didn't mess around with that center bolt haha, I got a swivel ratchet and a 4 foot pipe to use as a breaker bar right off the bat. Whoever designed that is a moron. Could have easily just been a nut and bolt deal that would take 10 seconds to get off but no, lets make it way harder than it needs to be :annoyed:
  8. Oct 24, 2015 at 10:58 PM
    RustyVT
    Vermont
    I've got a welder but I'm so bad at welding I legitimately think a toddler could do a better job haha.
  9. Oct 24, 2015 at 11:16 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    When it rains it pours! I just got under the truck to see if there was any noticeable play in the rack, there wasnt but my lower ball joints on both sides were leaking. Theyre oem, less than a year old. I just had a shop install new lca's, shocks and cv's, i think they must have accidentally sliced the boots :mad:
  10. Oct 24, 2015 at 11:17 PM
    Madjik_Man
    Colorado Front Range
    Is that a suicide knob on the steering wheel?
  11. Oct 24, 2015 at 11:29 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'm sure you can figure a way to bolt something in.
  12. Oct 24, 2015 at 11:31 PM
    RustyVT
    Vermont
    That was the plan, hopefully get that done tomorrow.
  13. Oct 25, 2015 at 5:33 AM
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    Repainted / touched up my sliders
    E4A23C5B-E788-4C71-88ED-F04D3EE42FF6_zps_0556e73cc2a319495a72967e765b7e44b42077d7.jpg
    DFEB2CAE-4373-46B6-A5C5-F09C9F6A81E1_zps_1fadeed58294864ed87e0b7c7448da124f1d00b1.jpg
  14. Oct 25, 2015 at 5:50 AM
    Kneeboarder1025
    Walt
    Broken Arrow, OK
    '03 Forester
    I came out of Walmart to see this pretty scene -
    ECE4E27E-39CA-4E92-B5BF-6BE4368645A0_zps_5ef5363a6a6a2bb44a328b828d1773f1e28228ba.jpg
    2002Tacoma4x4 likes this.
  15. Oct 25, 2015 at 7:42 AM
    Mischief
    Mischief misadventurer
    Christi
    Duke City NM
    2004 Tacoma crewcab TRD
    Yup
    ramonortiz55 likes this.
  16. Oct 25, 2015 at 8:40 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Bought this gem for $600
    00, 144k on the clock 2.7 4wd... Small frame rust hole so got it for cheap
  17. Oct 25, 2015 at 8:42 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    :eek::eek:
  18. Oct 25, 2015 at 8:59 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Are you kidding me!? Gonna get that frame replaced or what's the deal with that?
  19. Oct 25, 2015 at 9:00 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Even with the rust hole.... The truck is still worth 3-4 times that
    tibblits920 likes this.
  20. Oct 25, 2015 at 9:15 AM
    bellassaiw10
    Currituck NC
    Gonna patch it and sell it. Already got a guy wanting it as is but might keep it for a little while
