  1. Oct 27, 2015 at 7:59 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I baby my truck. I usually hit 3K Rpm's once to twice a week just to hear that whine. But I change my casoil synthetic every 4K with Fram ultra synthetic filter.
  2. Oct 27, 2015 at 8:03 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    If we did that it would be more than just a day trip...
  3. Oct 27, 2015 at 8:07 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    There's somebody here with a 98 that has 500k miles last time he posted.
  4. Oct 27, 2015 at 8:21 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    LoL. I didn't know that either. So x2.
    Oh. btw the spidertrax come with their own stubby acorn nuts. Then you can use the spine conicals for your wheel as normal.
  5. Oct 27, 2015 at 8:26 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Yea I know, had the spacers for a while now..just was curious which lugs to buy to use with the steel spare
  6. Oct 27, 2015 at 8:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    HIGHLY encourage ET lugs for any spacers. Well worth it. Just acorns to hold the rims down is fine.
    The studs on the front are short so the ET lugs will be very nice there.
  7. Oct 27, 2015 at 8:27 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    oic. in a pinch i suppose you could have pulled the spidertrax and used the lugs from that for the spare :D
    i think wheelers has alot of the lugs on their website. i'm pretty sure the acorn shortys should work.
  8. Oct 27, 2015 at 8:30 PM
    TIPICOTACO
    Tyler
    nw nj
    Yea I was gonna just get the shortys, wanted to be sure though. The steel rims are pretty thin so I don't think the ET are needed
  9. Oct 27, 2015 at 8:31 PM
    TIPICOTACO
    Tyler
    nw nj
    Ok, so you're saying that I should be using ET open conical nuts to mount the spacers but then use regular lugs for the rims?
  10. Oct 27, 2015 at 8:32 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I'd do whatever BD said since I just proved I was a spare tire noob :D
  11. Oct 27, 2015 at 8:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes. Torque the spacers on at 90ftlbs.
  12. Oct 27, 2015 at 8:44 PM
    TIPICOTACO
    Tyler
    nw nj
    Aright, torqued and blue loctite for 35k miles now..but will switch up to ET for piece of mind, thanks.
  13. Oct 27, 2015 at 8:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Shouldn't need loctite. But can't hurt.
  14. Oct 27, 2015 at 8:52 PM
    TIPICOTACO
    Tyler
    nw nj
    Mine came with loctite from Spidertrax.. Soo I used it lol
  15. Oct 27, 2015 at 9:00 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Will ET fit in the depth of the spidertrack? How long are they?
  16. Oct 27, 2015 at 10:46 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Didn't wanna post a new thread so figured I'd ask here guys. So I had been noticing a but of dust buildup around the throttle body on my 3.4. Decided to take it all apart and clean it out a long with the iac. When I unbolted the throttle body and slid it off, I found that the gasket in between was folded in half and clamped down like that. So only half of the gasket was seating! I said oh shit!! So last time I cleaned and reassembled, SOMEHOW, I fudged up with that gasket. And the bottom folded upwards! Idk how in the hell I could've done that!! I should've taken a pic because it's the damndest thing. Anyways... I replaced the gasket and all is good now. Question I have is, is there anything that could've been harmed driving it so long with only half the throttle body gasket sealed. It must've been pretty tight and not allowing much of a leak because it ran pretty good. I did have a very slight idle fluctuation and I think that went away. Only drove it once since I fixed it. But it SEEMS to be running a hair better. Hard to tell. Like I said it must've been a tiny leak there as it hasn't really been running bad or anything noticeable enough to worry about. There wasn't really any buildup in the intake plenum. A little bit of an oily residue. But that's it. But the outside all around where the gasket it had a dusty buildup. kinda strange it would build up on the outside and not inside. Especially when the gasket wasn't sealed properly on the bottom of the throttle body, only the top half. So stupid. Can't believe I did that and fail to see how that happened. Unless I slid the throttle body back off a little to get the hoses back on the iac, then caught the gasket when I slid it back on... So yeah, what, if anything, could that have done to the motor? I wanna say the last time I pulled the throttle body, was like, 30k miles ago!! Should I check anything? Or be worried about anything else more serious internally? I guess I shouldn't worry if she's running ok. But wonder if it could've done any harm at all with an open air intake leak like that even being somewhat small.
  17. Oct 27, 2015 at 11:02 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    I got bored
    8583D5FE-67EF-4304-BE44-985347BD3E22_zps_098abd13f1347c35970aa34feb6647337b609321.jpg
    Than met up with a buddy that's polar opposite of me
    F91F6B76-24EC-4D25-B29E-EB75F961FAF4_zps_ca84cd6fd1a69bc2de3017c96cde1e294f75929f.jpg
  18. Oct 28, 2015 at 6:25 AM
    NF2001Yota
    NF2001Yota Well-Known Member
    2001 4 door 4x4 toyota tacoma
    Who can help me Identify this part?
    I guess the PO found more of a use for its hoses. Thanks
  19. Oct 28, 2015 at 7:25 AM
    NF2001Yota
  20. Oct 28, 2015 at 9:05 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Actually I just realized @Blackdawg is talking about the lugs not the nuts. You can press out the old lugs and press in ET lugs which are longer and safer typcally. Just make sure that the lugs fit inside the depth of the spacer which is 1.25" so that they don't hit the back of your wheel.
