  1. Nov 5, 2015 at 6:40 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    That's who I got mine from too.
    Did you bleed the system for air bubbles? Did you flush with fluid? Is there a possible leak?
  2. Nov 5, 2015 at 6:45 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  3. Nov 5, 2015 at 6:51 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  4. Nov 5, 2015 at 6:57 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Cut out your bumper.....and mount em up under.....
  5. Nov 5, 2015 at 7:43 AM
    matt 157
    matt 157 Well-Known Member
    California
    2003 Black Xtra Cab 4WD SR5 TRD
    Pioneer DEH 8400 head unit/deck, Crunch 1100 watt amp, 12" Kenwood subwoofer, Kicker mids & tweeters, AllPro front tube bumper, Smittybuilt tow hooks, (welded pipe for muffle) straight-pipe, 4 orange "Raptor" lights in grill, Duratrac tires, American Eagle rims, ProComp 2" front leveling kit, Plasi-Dipped black on chrome trim, PIAA fog lights w/ in-cab switch, Unidin CB/Firestik II/8 ohm PA speaker, TRD leather 5-speed shifter knob
    That kit is perfect I bought and installed that exact kit about a year ago. Talked to my Toyota specialist friend and he recommended Aisin over anything else
  6. Nov 5, 2015 at 7:51 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    No air bubbles, new fluid. It whines at start-up too.
  7. Nov 5, 2015 at 8:08 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Is it the "power steering whine" or more of a chirp? If it was a chirp I would think potentially loose belt, if it's still the power steering whine I would guess there is a leak in the system letting air in near the pump.
  8. Nov 5, 2015 at 8:30 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
  9. Nov 5, 2015 at 8:40 AM
    KMKtacoma
    KMKtacoma Well-Known Member
    Karl
    Adamsville, OH
    2001 Tacoma TRD 4x4 5spd, 126k miles
    255/70/17 Cooper AT3's, tonneau cover
    Guys, for those of you that have had a Tacoma for a while, when do you normally replace all of this? I know 90k miles is recommended, but I also saw that people didn't change the timing belt until 200k and it looked ok. I just bought my first Tacoma with 116k miles. Is there any way to tell that its already been done without tearing it apart? Look for new gaskets in some area?
  10. Nov 5, 2015 at 8:42 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    220,000 and mine still hasn't been done...Even though I have had all the parts of about a year now just no free time to do it. Id recommend doing it now if you have the funds to, peace of mind for a while. Usually people write it on the timing belt cover but sometimes thats not the case
    KMKtacoma[QUOTED] likes this.
  11. Nov 5, 2015 at 8:44 AM
    KMKtacoma
    Karl
    Adamsville, OH
    But you've done your water pump at least once, I'm guessing?
  12. Nov 5, 2015 at 8:46 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    So, in the last couple months I've been hearing this noise somewhere near the motor. I kind of put it off because it doesn't seem like a big deal, but it bothers me sometimes. It sounds like a bb in a tin can, or a piece of plastic in a bike wheel. It gets faster and louder as the RPMs go up, and I can't hear it all that well when it's cold. Almost sounds like a rattling heat shield or something, but I stopped the heat shield rattle awhile ago
  13. Nov 5, 2015 at 8:48 AM
    bellassaiw10
    Currituck NC
    za
    Nope, trucks been in the family ever since like 20k and our mechanic said he's never done anything to it before I got it except plugs, and a couple 02 sensors
  14. Nov 5, 2015 at 8:53 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Got off from night shift and installed my knock light/shift light. Time for bed now. Gonna go run it and see how much knock it picks up. Then I'll use it as a tuning device for any knock that isn't audible.
  15. Nov 5, 2015 at 9:21 AM
    matt 157
    California
    Yeah I believe 70-90k is recommended, and even if it does "snap" you're not totally fucked because we don't have interference engines. However because this kit has all the water pump gaskets and everything id still change em at the 70-90 mark just because I'd want to avoid any coolant leak, don't want to run hot and blow a head gasket or soemthin
  16. Nov 5, 2015 at 9:38 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    If the seller is highly rated and has a high volume your chances are as good as any other place.
  17. Nov 5, 2015 at 9:43 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Same. I'm over 200K. I will probably do the overhaul this spring however just to lower my chances of getting stranded.
  18. Nov 5, 2015 at 10:39 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Got the plates welded up today, got 8 out of 10 bolts, just need to get new hardware for the remaining bolts. Also painted behind it as well. Just have to take some small stuff off and its finished
    One guy from my buddies shop was like "Are those Bilsteins? Big money right here! " :rofl:
    SWYPER, Scenekyd, reef and 9 others like this.
  19. Nov 5, 2015 at 10:42 AM
    bellassaiw10
    Currituck NC
    Never been a fan of hybrids or hoops, but that looks pretty good!
    BYJOSHCOOK likes this.
  20. Nov 5, 2015 at 10:42 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Looks great. Have you relocated your turn signals already?
