  1. Nov 10, 2015 at 8:52 AM
    buttergarden
    buttergarden Member
    Can somebody please provide a second opinion on this? I find it really hard to believe that putting RP in my differentials would make it "shift like crap"... unless you're referring to the manual tranny?
    And I've used RP 530 as a motor oil in my Lexus for 5 years, it has been nothing short of amazing for me. I just bought a 2013 Tacoma and plan to switch her over to RP motor oil this weekend.
  2. Nov 10, 2015 at 9:07 AM
    Madjik_Man
    Colorado Front Range
    The only experience I have with Royal Purple was with my manual transmission. I went with it because of all the rave reviews but I immediately felt it was horrible, in my opinion. And removed it within 4 or 5 days.
    Worst feeling shifting, horrible in the cold, etc.
    I have no experience with RP in my differentials.
  3. Nov 10, 2015 at 9:08 AM
    buttergarden
    buttergarden Member
    Thanks for the reply. I've read that Toyota manual transmissions require a certain amount of friction for proper shifting, so I already know that I shouldn't run RP for that (my truck is auto). But for the motor oil and gear boxes I have read so many good things about RP. I just wanted to make sure I'm not missing something here!
  4. Nov 10, 2015 at 9:23 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I have had it in all areas, engine, transmission 5 speed, front and rear diffs in the past because I believed the hype.
    The next morning it was in the truck the shifting was all wrong and hard to move without lots of effort and additional crunch sounds.
    I run as close to the stock rated stuff now and its the best long term for it I feel.
    I run 75w-90 in the trans, transfer case, front diff and in the rear I use a 75w-140 all synthetic.
    In the engine I use Rotella 5w-40 with a toyota filter changed every 7-8k
  5. Nov 10, 2015 at 9:26 AM
    buttergarden
    buttergarden Member
    Thanks for clarifying your experience, it sounds like you put it in the manual tranny? If so then what you experienced with shifting is normal since RP is not recommended at all for Toyota transmissions.
  6. Nov 10, 2015 at 9:28 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    The fact it is not recommended was never expressed by anyone, the RP I used was a 75w-90 synthetic so in reality it should have been the same as others.
  7. Nov 10, 2015 at 10:21 AM
    yota yoter
    yota yoter Well-Known Member
    Jordan
    Wet Side Oregon
    02' Imperial Jade Mica, V6, TRD 4X4
    Custom Real Tree Camo Interior.
    I just changed my rear diff fluid yesterday. After 30k the used oil still looked good. I dont have the breather mod and have got my diff hot then submerged it in water. No water and it was clean. I used dyno juice 75-90 it was the valvoline with lsd additive. The bottle said it was okay for both.
    Then I detailed my bitch. I have camo interiors...ooo aahhh.
    White Horse and 2002Tacoma4x4 like this.
  8. Nov 10, 2015 at 10:31 AM
    yota yoter
    Jordan
    Wet Side Oregon
    And....because I am just feeling active...this is what I did for my CB.
    Still going to install and wire the PA.
    I ran the antenna wire under the floor then i to the rear driver storage cubby. I have the magnet base and run it out the back window. The ground wire is on a braket under the dash. Power splices from cig lighter.
    2002Tacoma4x4 likes this.
  9. Nov 10, 2015 at 10:32 AM
    CelsisTaco
    CelsisTaco Well-Known Member
    Anthony
    Des Monies, IA
    2011 DCSB
    2 inch lift. LED fog lights (Cali fab) Alpine head unit. Kicker door speakers. Skar subwoofer.
    What material did you use for you your doors? So sweet
  10. Nov 10, 2015 at 10:50 AM
    yota yoter
    Jordan
    Wet Side Oregon
    Real tree AP from Jo Anns fabric....its actually stealth and cannot be detected by radar.
  11. Nov 10, 2015 at 10:56 AM
    buttergarden
    buttergarden Member
    I had to do some digging around, but I figured it out after reading Amazon reviews on the RP gear oil. Also, threads like this one help to point out that putting RP in a manual tranny is a bad idea because it is simply too slippery and does not provide enough friction for the tranny to operate as intended by Toyota.
  12. Nov 10, 2015 at 12:11 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Whoa whoa whoa!! Take my money and do mine!! :)
  13. Nov 10, 2015 at 12:15 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Still can't find the solution to my problem yet. Went to my mechanic and told him about it and he couldn't figure it out. We checked everywhere underneath the truck. I noticed that that chirp is more of a weird squeak when I'm hitting a bump (axle flexing) & turning.
  14. Nov 10, 2015 at 12:24 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    I wonder if I can wrap mine to say TRD around it. Hmmmm :jerkoff: got a link on how you did this?
  15. Nov 10, 2015 at 12:25 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Bad alignment can cause the front tires to chirp in sharp turns. Mine did it before a recent alignment.
  16. Nov 10, 2015 at 12:26 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Went on a few trails with a friend and took poser shots.
    Also got to 120,000 miles.
  17. Nov 10, 2015 at 12:33 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Hmm I guess that recent rescue the 2WD vehicle messed that up. It doesn't happen in sharp turns though sometimes slightly turning the wheel when I'm going 20 mph does the same thing.
  18. Nov 10, 2015 at 12:55 PM
    Squeaky Penguin
    Brett
    How do the ubolts and centering pins look? Also, I assume you figured this out but never use a chain to pull someone out. A good, stretchy snatch strap will not only work better, but also avoid damage to the vehicles.
  19. Nov 10, 2015 at 1:02 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    our rigs look so at home covered in mud
  20. Nov 10, 2015 at 1:18 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    tibblits920 and 2002Tacoma4x4 like this.
