  1. Nov 14, 2015 at 9:06 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    That's pretty good. Seems better than what I see most guys on here saying they get. Then again, a lot of guys (at least the ones who post often) have lots of armor and upgrades that bog their rig down.
    This is true. In my last car, I would get 17/18 regularly, but if I made a conscious effort to get more (and added some highway driving in here for fun), I could get 20-22. I expect a little better fuel economy after I've had the truck for a bit. Ya know, after I've settled into it and have "less" fun with it.
    Delta00[QUOTED] likes this.
  2. Nov 14, 2015 at 9:10 PM
    sente3
    sente3 -
    North Jersey
    I could definitely be mistaken, but doesn't the caster look low? Camber on front left is a little low as well, I believe. Front right camber is good, as is toe.
  3. Nov 14, 2015 at 9:13 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    :notsure: the steering wheel is straight again so I'm good to go for now. But I can bring it back anyday
    Silver02Taco likes this.
  4. Nov 14, 2015 at 9:15 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Does anyone know how the Tacoma tachometer works? If I had a v6, how many pulses per revolution does it read? 3? I can't find any good info online that details how the tach gets its info. I have 2 pulses per rpm to work with.
  5. Nov 14, 2015 at 9:15 PM
    sente3
    sente3 -
    North Jersey
    Well don't take my word for it. I'm sure there are guys on here who know better than I do.
    But I'm sort of like you in that regard. If the wheel is straight and the truck isn't going off to the side, I can't complain much,
  6. Nov 14, 2015 at 9:19 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    IIRC I know most Tacoma owners push for the most Caster or Toe as much as possible. But I just needed it straightened so I can drive to Florida without too much "damage"
  7. Nov 14, 2015 at 9:27 PM
    sente3
    sente3 -
    North Jersey
    Well lots of caster makes sense in most vehicles. But I don't know too much about alignments; just basics.
    Sometime next year, I'll also be driving down to Florida (but I'm in NJ, so quite a drive) because a good friend just moved there. I gotta get a few things with the truck taken care of beforehand - which will include alignment.
    Oh and I can't take time off work during the holidays.
  8. Nov 14, 2015 at 9:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Here are the ideal numbers:
    Camber 0*
    Caster +2.5*
    Toe 0*
    Your toe and camber numbers are troubling. I can understand the low caster if you have stock UCAs but there should be no excuse for the toe. Camber is a bit asymmetrical too. That could be a result of frozen LCA adjuster cams. You may see significant wear on the tires in a long trip.
    Its a good thing you got the lifetime deal because you are gonna need it. The way they left it is pretty lame. I think they can do better. I would definitely not be happy if it was my truck.
    alphabravo and Deathbysnusnu like this.
  9. Nov 14, 2015 at 10:02 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Not necessarily, I was getting about 15 or so before I weighed it down. I did the whole drive like a granny thing when I first got my ultragauge, only got about .5 miles better, so I said fuck it I'm gonna keep driving like I stoled it!
  10. Nov 14, 2015 at 10:08 PM
    sente3
    sente3 -
    North Jersey
    Oh hell yeah. If I only got a .5mpg difference from not having as much fun, no way would I keep at it. It's more important to enjoy a vehicle than to just try to use as little gas as possible. Now if I tested and was getting something like 3MPG better, then okay. A bit more granny driving. That shit adds up.
    But we have pickup trucks, not ecoboxes. I didn't buy a V6 Tacoma so I can rave about how little fuel I use.
  11. Nov 14, 2015 at 10:38 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Fuck if I was getting 3 better I wouldn't really care, it's just so damn hard, though not being in the SF bay without all that bullshit then maybe I would.
  12. Nov 15, 2015 at 7:56 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Pictures of the LCA cams could tell us if your alignment is maxed out or you head a tech that didn't know what he was doing.
  13. Nov 15, 2015 at 7:59 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Received this in the mail yesterday.
  14. Nov 15, 2015 at 8:21 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    i got that too. mine was heavily rusted.
  15. Nov 15, 2015 at 8:30 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I didn't know there were more 1st genners on here in jersey. Stop by nj bs thread.
  16. Nov 15, 2015 at 9:50 AM
    reef
    reef Well-Known Member
    04 4WD
    anyone in here running OME 882 coils?
    TacoVio likes this.
  17. Nov 15, 2015 at 10:05 AM
    sente3
    sente3 -
    North Jersey
    I just brought my in for that yesterday. Aside from the issue of the bolts being rusted to shit, so it'd take longer (not a big deal, I had nothing to do), they couldn't readily do it because apparently the trailer hitch the PO put on obstructs what they need to get to. So either I pay them $115 to do it or I take it off myself and bring it in. No way am I going to basically pay for a recall. I'll take it off myself at some point.
    Until you telling me right now, I didn't know there were dedicated regional threads. I may very well have to stop by. I just got my truck last Tuesday, so I'm pretty new to the Taco game.
  18. Nov 15, 2015 at 10:08 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Nice..ya I wouldn't expect it to be rice on a 6 cylinder. You can imagine what it does to the 4 cylinder tho lol
  19. Nov 15, 2015 at 10:11 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I do, @Squeaky Penguin does too.
  20. Nov 15, 2015 at 10:14 AM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Had a wonderful first night in our tepui tent!
    Some pics...
