  1. Nov 30, 2015 at 4:32 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I would not recommend doing this without loosening the LCA cams. But this also depends on what coils you're installing.
    First time I did it without loosening the cams. Decompressed the coil with the jack, then removed the jack, but there was still tension on the coil as the LCA would not drop further. Avoid a potentially dangerous situation and loosen the cams, you'll need an alignment anyways.
    yota yoter likes this.
  2. Nov 30, 2015 at 4:47 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Thank you sir! :D
  3. Nov 30, 2015 at 5:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've never had to remove the ones that hold the skids together to remove the whole unit.
  4. Nov 30, 2015 at 5:23 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    This.
    The other 2 bolts hold the trans skid to the ifs skid.. shouldn't have anything to do with removing the front skid.
    I'm about to go out there with a hacksaw a blowtorch and a beer, hopefully one of those helps me get the job done.
    Gimme a minute, I'll do my best with a crappy 1.3megadixel phone cam.
    Chipskip[QUOTED] likes this.
  5. Nov 30, 2015 at 5:50 PM
    WheelInTheSky
    G
    Jackson Hole
    It's hard to get pics that really show anything, here's the best that I can do:
    If you look just to the left of the edge of the skid you will see the vertical piece of the skid that appears to be stuck against the frame...
  6. Nov 30, 2015 at 6:11 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Got a center console with round holders to replace the one that came in my truck that had square holes.
    DSCN5452.jpg DSCN5457.jpg Installed the new rubber tabs DSCN5458.jpg DSCN5459.jpg
  7. Nov 30, 2015 at 7:13 PM
    TacoVio
    Kolton
    CO/WY
    @m3bassman What kind of cb antenna and setup are you running?
  8. Nov 30, 2015 at 7:13 PM
    Madjik_Man
    Colorado Front Range
    Best mod ever
  9. Nov 30, 2015 at 7:18 PM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    A big flat head and hammer and just chisel it from that angle? Not sure man I don't see why it shouldn't come off now
  10. Nov 30, 2015 at 7:33 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Working on a little something
    Fernando, camptaco01, ClevSix and 2 others like this.
  11. Nov 30, 2015 at 7:37 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Retrofit fogs?
  12. Nov 30, 2015 at 7:39 PM
    LSC15
    Logan
    2008 TRD D-Cab
    Yes sir. Very difficult lol
  13. Nov 30, 2015 at 7:44 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Bump
  14. Nov 30, 2015 at 7:46 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I looked, but i couldn't find anything under junction box.
  15. Nov 30, 2015 at 7:48 PM
    TacoVio
    Kolton
    CO/WY
    That's the CB I will run too...eventually lol! But how does your two foot work?! I was thinking of the Wilson flex! But 4ft is just too tall to have on the truck all the time especially by the windshield! I was thinking a 3 foot firestik with a spring or can you change my mind lol!
  16. Nov 30, 2015 at 8:38 PM
    TacoVio
    Kolton
    CO/WY
    Well I have no idea how to tune it lol! Will be my first CB!
  17. Nov 30, 2015 at 9:00 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Don't try to talk on it without tuning it. If you can't do it yourself, a local CB shop can get it done in less than 5 minutes. It is essential so that you don't mess up the radio.
    TacoVio[QUOTED] likes this.
  18. Nov 30, 2015 at 9:01 PM
    TacoVio
    Kolton
    CO/WY
    Got it thanks! :D
    MatthewMay1[QUOTED] likes this.
  19. Nov 30, 2015 at 9:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  20. Nov 30, 2015 at 9:08 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    They're cheap. I got mine from my local Fry's, definitely worth having. I have tuned 3 local members' radios. Guess I'm the only one who knows how to do it in my area. Haha
