  1. Dec 2, 2015 at 5:51 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Pretty sure it's an ebay knockoff but I got it for cheap cheap, mileage unknown, maybe .5mm in and out, bout 1-2mm of side to side. I haven't pulled it apart to measure turbines yet but it's small. I'm probably going to build my own manifold so I can put the turbo where I want it.
  2. Dec 2, 2015 at 5:51 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Ah, I see. So that's where the difference between electronic and vacuum diffs come in. Makes sense.
  3. Dec 2, 2015 at 5:52 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    J-Shift. ADD. 5 Speed. Best possible combo :cool: I love getting up to 5 gear low range, pushing in the clutch, and tossing it in 2nd gear high.
    I wouldn't want to give up the ADD for winter driving, and manual hub CV shafts are quite a bit weaker. These other guys are right, the vacuum operated ADD does not depend on the transfer case, but the switch that turns it on and off is different.
  4. Dec 2, 2015 at 5:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm not an advocate of making your own headers. Very against it actually. It's hard to do correctly and really should be TIG welded. And for a turbo you want high velocity but don't want to disrupted the flow of the gasses between cylinders. Would get them made by a professional performance shop before making my own.
    And that is a lot of play..was cheap for a reason..the turbo game is an expensive one and you need to know before you start there is no such thing as cheap in turbo land. It'll always come back and bite you. Pay for the real stuff. It's worth it. Trust me.
    Yea. I mean the vacuums have solenoids for the vacuum lines but not the actual actuator isnt electronic.
  5. Dec 2, 2015 at 5:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No I'm pretty sure the electronic actuator is with push buttons and the vacuum is j shift.
    Is your electronic actuated or vacuum? I thought I read at some point the 01-04 May just all be electronic actuated..but I thought for sure the j shifts just had vacuum front diffs.
  6. Dec 2, 2015 at 6:00 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Its getting harder and harder to find a j shift truck! I just keep telling myself be patient!
  7. Dec 2, 2015 at 6:00 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Are you still buying yours back?
  8. Dec 2, 2015 at 6:02 PM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah i know you get what you pay for and I plan on rebuilding it. I mainly picked this one up to build my setup off of and dick around with till it goes then spend the coin on a garrett or turbonetics or something once I have most of the bugs out.
  9. Dec 2, 2015 at 6:03 PM
    TacoVio
    Kolton
    CO/WY
    Yeah and I'm thinking about swapping my j shift from my old truck in a new truck if I dint find a nice one with a j shift! I posted earlier if anyone has done the swap from push button to j shift! But no answer!
  10. Dec 2, 2015 at 6:07 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Where's the kitty cat at? :infantry:
  11. Dec 2, 2015 at 6:09 PM
    sente3
    sente3 -
    North Jersey
    All info is helpful. I'm trying to diagnose/repair my 4x4 system right now, and the issue seems to be up front, so I'll take whatever info I can get.
  12. Dec 2, 2015 at 6:10 PM
    Squeaky Penguin
    Brett
    Gotta say you've confused me, because I always thought all the ADD actuators are the same.
    Mine has a vacuum actuator. Which in and of itself is electric.
  13. Dec 2, 2015 at 6:14 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  14. Dec 2, 2015 at 6:15 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What's that?
  15. Dec 2, 2015 at 6:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha what??
    If it's vacuum then vacuum is what slides the shaft over to lock in 4wd.
    If it's electric it has an electric motor that slides the shaft to lock in 4wd..
    Make sense??
    Yea I mean they all use electronics to turn on but to actually lock the diff in their is either a vacuum actuator or electronic.
  16. Dec 2, 2015 at 6:26 PM
    SenorMaxTheFantastic
    SenorMaxTheFantastic New Member
    Max
    Colorado
    96 extended cab tacoma trd
    very much many plasti dip right now.
    I put in a sleeping platform for all of the adventures in life
    It's a stock 96 going up mosquito pass in Fairplay colorado. I have a lot planned for the truck but being a student I don't have bags of cash lol
  17. Dec 2, 2015 at 6:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Welcome to TW :) Lets get some truck specs and details on the trip you took in the second pic.
  18. Dec 2, 2015 at 6:34 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Just reading back a couple pages.....I'm super confused with this talk about front diffs. I'm an '01 with a J-shift... Now I'm curious whether or not I'm electronic or vacuum driven?
  19. Dec 2, 2015 at 6:34 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Mountain lion? Haha
  20. Dec 2, 2015 at 6:34 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    X2 Welcome!
