  1. Dec 2, 2015 at 6:38 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Today I fixed my ebrake. I know I know :worthless: but I was running out of daylight fast. Somehow the cable had come out of the end of the handle but I was able to reconnect it with the help of my fiancé. There must be something missing on my because nothing triggers the little push button that shuts the brake light off. I just pulled the plug above it so it's always off but I'm still curious to know what it's supposed to look like down there.
    Chipskip likes this.
  2. Dec 2, 2015 at 6:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  3. Dec 2, 2015 at 6:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'll take a pic for ya when I get off this airplane. I'm still somewheres over Colorado but I'll snap a pic when I get home. It's just a pin switch and a paddle that comes off the shaft to hit it if I remember correctly.
  4. Dec 2, 2015 at 6:43 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    After some research it appears I was wrong. :anonymous:
    Still, all '01-'04s, regardless of J-Shift or push button, had electronic actuators. It certainly makes some vacuum like noises though. Swapping transfer cases shouldn't require changing the actuator, but the button on the push button engages the actuators on both the transfer case and the front diff, whereas with the J shift triggers the actuator when you toss it in 4wd. Not a clue if the wiring between the two is compatible.
  5. Dec 2, 2015 at 6:53 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    So if a J-shift swap was done, couldn't a switch on the dash be used to engage the ADD?
    Edit, like run the wires up to the dash and connect to a switch.
  6. Dec 2, 2015 at 6:54 PM
    Squeaky Penguin
    Brett
    I don't see why not. But you should also be able to wire it in to whatever switch is already in the J-Shift.
  7. Dec 2, 2015 at 6:57 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I suppose maybe. The only thing the switch on my J-shift turns on the little 4x4 indicator on the dash. But I suppose it could be used with a relay.
    I like my hubs personally. :headbang:
    Speedytech7 likes this.
  8. Dec 2, 2015 at 7:06 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    Neh only 5peed that was just the sticker
  9. Dec 2, 2015 at 7:08 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Bolted my clutch back to the firewall.
    Anyone had issues with a bolt falling out that holds the clutch pedal to the sheet metal near the fire wall? Similar to the one shown above the spring in this picture. It has fell out twice in 4 years while driving.
  10. Dec 2, 2015 at 7:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should be easy to wire it.
  11. Dec 2, 2015 at 7:54 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    That's sweet man. I don't believe in using dogs to tree a cat at all but still cool to see one. Hopefully this 4th year of tracking/calling I'll finally get one.
  12. Dec 2, 2015 at 7:55 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Cool man thank you. Yeah the pin switch and paddle that sounds about right. I must be missing the paddle.
  13. Dec 2, 2015 at 8:01 PM
    JKO1998
    Utah
    I walked up to this one this fall during archery. 50 yards.
    tibblits920[QUOTED] likes this.
  14. Dec 2, 2015 at 8:02 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    In response to all this 4wd add jshiftin electricock nonsense I'm guessing I have a jshift? No push buttons or manual hubs here
  15. Dec 2, 2015 at 8:03 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Damn dude! That looks freaky! Haha I bet that was fun!
  16. Dec 2, 2015 at 8:07 PM
    JKO1998
    Utah
    I stared at it for 3 minutes, trying to decide what I wanted to do. Then it ran off and I just keep walkin around
  17. Dec 2, 2015 at 8:08 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I doubt anybody has bothered.. seems like a waste of time and $$ to me
  18. Dec 2, 2015 at 8:12 PM
    Speedytech7
    Plenty of the dcab guys who swapped to five speeds did that as well. Also lots of people pick them up for dual cases but yeah unless you are like me and prefer to have fewer electrical failure points there's not much reason to.
  19. Dec 2, 2015 at 8:12 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Not really cuz I already have the j shift out of my old truck and its more reliable than push button.
  20. Dec 2, 2015 at 8:17 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Yeah if you're doing a driveline or manual swap sure otherwise meh
