  1. Dec 4, 2015 at 6:33 PM
    Madjik_Man
    Colorado Front Range
    The rear springs/shackle extend past the rear of the truck? Or is that just a weird angle of the photo?
  2. Dec 4, 2015 at 6:34 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  3. Dec 4, 2015 at 6:37 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I removed my sway bar, put it back on, and now it's stuck....Don't know how one nut seized up after less than a year
  4. Dec 4, 2015 at 6:45 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    It knew deep down that after removing it once, if you ever tried to take it off again it would be for good... The damn thing is hanging on for dear life!:devil:
  5. Dec 4, 2015 at 6:49 PM
    RhettSims
    RhettSims Tacoma4Life
    Rhett
    Ft Walton Beach, Florida
    2004 Red Tacoma TRD SR5 Limited 4x4
    ToyTec Bilstein 3" lift K&N air filter Grey Wire Mod Mickey Thompson Baja Lock 16x8 BS:3.625 BFG KM2 285/75/16 Turn signal/running light swap 2X10 RockfordFosgate P3 1200 Wat RockfordFosgate Prime Amp Regear 4.88 CV boot mod ABR front locker Custom Fabricated bed rack CVT Mt. Ranier High lift 60" Hella FF
    Plasti dip or I guess you can call is rattle can plasti the badges. Excited to see the results. One badge to start with to make sure I like it. Process is still concerning of how easy it "seems" to be
  6. Dec 4, 2015 at 6:50 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    I reinstalled it just because I had to make multiple 5 hour drives. Tried to remove it for a wheeling trip and one damn nut was so stuck.
  7. Dec 4, 2015 at 6:51 PM
    WheelInTheSky
    G
    Jackson Hole
    Ummm...
    o_O
    Jarob11 likes this.
  8. Dec 4, 2015 at 6:52 PM
    WheelInTheSky
    G
    Jackson Hole
    I've been wrassling with this nut for a couple days now trying to avoid doing anything too drastic. Cutting through it with a dremel and getting penetrating fluid in through the cut seemed to do the trick.
  9. Dec 4, 2015 at 6:54 PM
    muddog67
    muddog67 Well-Known Member
    I did the gray wire mod today, looking forward to playing with it and seeing how it works
  10. Dec 4, 2015 at 6:57 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    I'll have to figure something out next time I have my truck home from school.
    I still haven't done this.....:anonymous:
  11. Dec 4, 2015 at 6:58 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Just fyi, as long as one side is disconnected, the sway bar doesn't do anything. You don't need to take it completely off
  12. Dec 4, 2015 at 7:01 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    But there's nowhere to swing the end link out of the way and I wouldn't want it hanging loose down there.
  13. Dec 4, 2015 at 7:01 PM
    WheelInTheSky
    G
    Jackson Hole
    Zip-ties?:notsure:
    The way I wheel I wouldn't trust it, though..
  14. Dec 4, 2015 at 7:02 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Ziptie that bitch to the lca
  15. Dec 4, 2015 at 7:03 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Rather just remove the entire thing. It only takes 5 minutes if you don't run into a stuck nut or bolt
  16. Dec 4, 2015 at 7:06 PM
    pittim
    Pennsyltucky
    Boujee Prius
    That's the only kind of bolts that are on my truck lol, hooray winter
  17. Dec 4, 2015 at 7:07 PM
    WheelInTheSky
    G
    Jackson Hole
    Salt belt FTW!
  18. Dec 4, 2015 at 7:09 PM
    pittim
    Pennsyltucky
    Boujee Prius
    With enough time they'll just rust through haha, self loosening bolts ftw!
  19. Dec 4, 2015 at 7:09 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Woooo for the south!
    RhettSims likes this.
  20. Dec 4, 2015 at 7:11 PM
    muddog67
    Its easy took me 15 min
