  1. Dec 8, 2015 at 5:51 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Ok good you'll need an extra set of hands with placing the head. It's a heavy bitch when your trying to reach to the middle of the engine bay (well I'm short and have t-Rex arms) Have a bungee cord ready to hook the sprocket and chain to when you take off the head. Good luck if you run into any questions hit me up.
    Speedytech7 likes this.
  2. Dec 8, 2015 at 6:13 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I've got them on my dd! They are about the same width of a285 just a bit taller. Of the ones you suggested I would go with 285s
  3. Dec 8, 2015 at 6:19 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    255s :cool:
  4. Dec 8, 2015 at 6:19 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    I guess he was saying I might need still need a machine shop to mill the block surface, so at that point it would need to be at a shop anyway. :notsure:
  5. Dec 8, 2015 at 6:20 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    I might have to go this route.
  6. Dec 8, 2015 at 6:20 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Subi's have aluminum blocks, your 3RZ does not. There is very little chance that it is warped, but before reassembly it would be best to check it against a real straight edge, and use feeler gauges to gauge the run out.
    I should clarify and say that you should follow the FSMs recommendation for checking the block surface, and by straight edge I mean a machinists straight edge, not an average household ruler.
    tibblits920[QUOTED] likes this.
  7. Dec 8, 2015 at 6:25 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    The head gets resurfaced. I've never heard of the block needing resurfacing. When I did mine I bought a replacement head with head gasket and threw it on. Done. The old head went to recycling.
  8. Dec 8, 2015 at 6:36 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    That's good to hear. So how much am I looking at for a fully assembled head? At this point I'm thinking with a little help from you guys and some time and patience we can get the head off the block. What sort of adjustments am I looking at after that? And I am told I'll have to get a new timing chain/kit to go with the new head?
  9. Dec 8, 2015 at 6:37 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Sounds like we're going to need to buy more than a few tools for this job..
  10. Dec 8, 2015 at 6:38 PM
    Speedytech7
    You don't have to get a new chain, I didn't. That being said if you're up for it, it's a good thing to do although Toyota regards it as a lifetime part. That requires more disassembly, mainly taking off the front timing cover which is a pretty big job itself. You could get the head off without removing the cam gear from the chain, most people zip tie the two together to avoid them coming apart.
  11. Dec 8, 2015 at 6:43 PM
    Speedytech7
    Feeler gauges are good (and not expensive) to have and a good straight edge is great if you ever plan to fab stuff. If you decide to use your head you'll probably want to have the valve clearances checked by a shop or do it yourself as it sounds like they've never been done, and on the RZ engines they are really important to keep up on to avoid head cracks on the exhaust valve side.
    SilverGhost likes this.
  12. Dec 8, 2015 at 6:45 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Have you regeared? And you're a v6, little tougher on the 4 banger.
  13. Dec 8, 2015 at 6:46 PM
    GreeGunc
    Jacob
    North GA
    That's what I'll probably go with.
  14. Dec 8, 2015 at 6:50 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    You don't need to replace the chain at all. But what you should check are the chain guides. They are made of plastic. Check the sprocket for uneven wear and the chain for any wear. If you don't see any wear then your good. Don't buy it unless you need it for sure, that will save some money. You'll also need new head bolts to play it safe. vvvvv everything he said.
  15. Dec 8, 2015 at 7:02 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Haha, if I use my head. That's all I'm trying to do here man. Haha. And yeah they've never been checked so I'll be sure to get those checked. Should I do that before we start tearing this thing down?
  16. Dec 8, 2015 at 7:03 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    This is a very rare sight. Just washed my truck in the middle of December (or close to it.) it was a VERY cold 74 today, most of the time I hate this bipolar weather but today I took advantage of it
  17. Dec 8, 2015 at 7:15 PM
    Speedytech7
    LOL, not how I meant it but much funnier :D You can do it at any time throughout the process, provided the cams are installed in the head that you are going to be using.
  18. Dec 8, 2015 at 7:17 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
  19. Dec 8, 2015 at 7:20 PM
    Speedytech7
  20. Dec 8, 2015 at 7:22 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Haven't re geared yet, the v6 does help though.
