  1. Dec 10, 2015 at 5:35 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It could be a "bad" battery. I'm not convinced however.
    You installed it a month ago, and it worked perfectly all that time then became intermittent, with lights dimming and then coming back on full, not starting, then starting just fine.
    Symptoms of corroded battery cables and electrical resistance.
    In my experience a bad battery is bad right off the shelf. Meaning no start right from the start.
    I'm betting the store you bought the battery from will replace it with no questions asked because this is fairly common.
    I'm also betting you have the problem again. The cable clamps need to be clean of course, but I would also peel back some insulation on those 16 year old battery cables and see if the wire is turning green/black. If it's anything other than bright shiny copper, it's bad.
    Corroded cables will not cause the ALT light to come on because they can carry voltage just fine. So the ECU sees voltage from the alternator. They cannot however carry amps anymore which is really what the battery needs to charge .
    Hopefully it is just a bad battery and a nice easy fix though.
  2. Dec 10, 2015 at 6:51 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Added two more switches.
  3. Dec 10, 2015 at 8:20 AM
    imcafee195
    imcafee195 Well-Known Member
    Isaiah
    Chattanooga TN
    98 tacoma on 35s
    Lift Raptor lined
    No the raptor liner will stick to pretty much anything. I just sanded it down and it worked great.
  4. Dec 10, 2015 at 8:56 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone know what went into these?
  5. Dec 10, 2015 at 9:03 AM
    Jarob11
    Jarob11 Well-Known Member
    Hilo/Tacoma/Evanston
    99 Taco Limited
    Badlands custom frt winch mount bumper. badlands RR bumper w/ spare swing out, jerry can holder. Leer Camper shell. Royal Purple synthetics. Baja fender flares. Entire truck rhino lined. 31's. Custom sound system. More to come.
    That new quicksand is way cool..when I was still living in Washington a guy saw my truck while I was in the tactical store and then found me to show me his..it was a 98 reg cab he did in red. I believe it was the monstaliner and you could barely tell it was lined. Looked hella clean. People at gas stations always trip out when they see mine..takes em a minute to realize the entire truck is sprayed
  6. Dec 10, 2015 at 9:13 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  7. Dec 10, 2015 at 9:46 AM
    JKO1998
    Utah
  8. Dec 10, 2015 at 9:56 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Retrofit, hit up the TRS GB. 25% off all retrofit kits except the FXR's
  9. Dec 10, 2015 at 9:56 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Looks like a blacked out retro with halos in front and behind the shroud.
  10. Dec 10, 2015 at 10:00 AM
    JKO1998
    Utah
    I just wanna know the parts he got, those are like exactly what I want
  11. Dec 10, 2015 at 10:05 AM
    JKO1998
    Utah
    What parts though, I asked him I think.
  12. Dec 10, 2015 at 10:14 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Oh I know but since I don't know anything about retros I figure I give you a link to the guy who put them in if you have any questions.
  13. Dec 10, 2015 at 10:15 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I would say those are gattling gun shroud with white halos on front and back. The projector is probably an h1kit but may not be
  14. Dec 10, 2015 at 10:15 AM
    JKO1998
    Utah
    I don't know anything either
  15. Dec 10, 2015 at 10:19 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Yea mine from a small distance looks pretty smooth. Only thing is, we had chunks in the paint and now there are sharp little chunks all over the body. We think its because we had the paint setting in our shop for almost a month, with high humidity and temp, its suppose to be stored in a cool dry place. It doesnt look horrible, kinda gives it some character but I wish it would have came out smooth. I'm still happy though.
    So if anyone is going to do it, don't buy the paint tell your ready to actually paint it!!!
  16. Dec 10, 2015 at 10:28 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Go the the retrofit source and look at their complete retrofit kits. They have everything you want and you can look at all the shroud styles. D2S and H1 are the easier to do retrofits.
  17. Dec 10, 2015 at 10:29 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Don't forget the TW discount. 25% of on certain kits
    Delta00[QUOTED] likes this.
  18. Dec 10, 2015 at 10:43 AM
    Jarob11
    99 Taco Limited
    Mine is rougher in some spots and smooth in others..I like the rougher dimpled look..my only complaint is that you can tell its thicker in some spots.. And my baha fender rubbed some off the passenger door. But Its pretty flexible, even on my bug shield it hasn't cracked or chipped or anything. Now all I got to do is find your build thread so I can steal your grill:spy:
  19. Dec 10, 2015 at 10:48 AM
    JKO1998
    Utah
    Dang it
  20. Dec 10, 2015 at 10:54 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Did scuff up the chrome some for the bedliner and the stainless, sprayed the plastic with bulldog adhesion promoter per monstaline instructions
    My build link is in my sig as well. Just added this small write up.
