  1. Dec 12, 2015 at 6:59 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    How'd you?
  2. Dec 12, 2015 at 9:44 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    Gotta give the tire the extra inches to expend for heavy impact or bump especially when off roads
  3. Dec 12, 2015 at 10:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I like the idea but a couple of things may complicate that. One is the shape your hood. The '01-'04 hood has a rise in it that the grill follows. That rise isn't there on the '98-'00 hoods. Easy to fix by swapping in an '01 hood. Also, I'm pretty sure that Toyota changed the shade of green slightly in '01. Only noticeable when they are next to each other. FWIW, they did it with the dark red too.
  4. Dec 12, 2015 at 10:11 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    do you have to get different fenders too? i thought i read that the corner lights were different.
  5. Dec 12, 2015 at 10:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think so. But I'm not really qualified. I'm only going by what I've read on here. There are a couple of guys that did front clip swaps on here. @Madjik_Man Usually to get away from the '98-'00 front grill and headlights.
    It is true that the marker lights vary a little from model years. But has to do with how they mount to the fender. Now that I think about it a bit more, swapping the front grill may present issues with mounting the headlight housings too.
  6. Dec 12, 2015 at 10:31 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Yeah I would need a new hood... maybe fix the one on my old truck now and repaint!
  7. Dec 12, 2015 at 10:34 PM
    TacoVio
    Kolton
    CO/WY
    Someone on here did a swap from 2000 to 2001 or something and used the same fenders!
  8. Dec 12, 2015 at 10:36 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I went retro on my '04. Changed it to a '98.
    The core support/headlight buckets are a bit different and the marker lights are different. My '04 fenders fit the marker lights, but there was no real good way to secure them in. I just tie wired them from the inside. If tie wire is good enough for the airplane buiz, its good enough for my marker lights.
  9. Dec 12, 2015 at 10:36 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Yep. Fenders, hood, grill, corner and headlights. Older bumper works with them i think though
  10. Dec 13, 2015 at 4:25 AM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    How much paint did it take and how did you apply it?
  11. Dec 13, 2015 at 6:27 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Getting my truck ready for my Elite front bumper!!!
    Still have to weld on the frame end caps and finish up moving the blinkers up to the corner lights.
    tibblits920 likes this.
  12. Dec 13, 2015 at 9:56 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Me. All I used was new headlights, hood, hood latch, corner lights, grill. Can keep fenders and core support. My conversion page is below in my signature!
    Older bumper works as well and ran with it until just recently until I got a free 01-04 bumper and that works perfectly too.
  13. Dec 13, 2015 at 10:15 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    I honestly can't remember, with your frame it won't take as much since its not as rusty. I think we bought 2 gallons, definitely had some left over but can't remember. We used cheap little paint brushes, worked fine. The one thing we did wrong was apply it to thick in places. Your suppose to do thin light coats. It draws in moisture to cure, and when its to thick bubbles form...will this hurt anything? I don't know.
  14. Dec 13, 2015 at 11:24 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Aw you were meaning the stock bumper, I see now :facepalm:
    Delta00[QUOTED] likes this.
  15. Dec 13, 2015 at 11:26 AM
    TacoVio
    Kolton
    CO/WY
    Right you did a real good write up! I have all that too from my totaled truck! And I have a plate bumper so don't have to worry about the stock one!
  16. Dec 13, 2015 at 11:29 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks! I actually made money off my conversion by selling parts off my truck. What put me under was the paint for the hood. If you can just swap all that stuff over and sell the 00 stuff, can make a few bucks
  17. Dec 13, 2015 at 11:32 AM
    TacoVio
    Kolton
    CO/WY
    I'd have to get the hood painted but I have a hookup lol!
  18. Dec 13, 2015 at 11:34 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Well shit, there you go. No excuse not to do it!
    TacoVio[QUOTED] likes this.
  19. Dec 13, 2015 at 11:35 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Went camping last night
    Also found a puddle of what I think is oil, looked around couldn't find anything. Then I looked at the oil filter and it looked kinda gross, so I tightened it up so let's hope that's what it was. Oil wasn't even low so I guessed I overfilled it :notsure:
  20. Dec 13, 2015 at 11:37 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    :drool: looking great! That might make for a good sig pic :wink:
