  1. Dec 20, 2015 at 9:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Hmmm, certainly a good idea for a product. A box that isolates a door speaker when the CB is doing something. I can think of a couple ways to do it but I think with most CBs tiny built in amp they wouldnt get very loud. But its doable.
  2. Dec 20, 2015 at 9:05 PM
    Speedytech7
    Now there's a hashtag i can get behind...
    Because I'm broke as hell :(
  3. Dec 20, 2015 at 9:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    #truestory
  4. Dec 20, 2015 at 9:07 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Little bit of google and I found this.
    http://www.eham.net/ehamforum/smf/index.php?topic=23686.0
    Speedytech7[QUOTED] likes this.
  5. Dec 20, 2015 at 9:16 PM
    Speedytech7
  6. Dec 20, 2015 at 9:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    #wheresmymoney
  7. Dec 20, 2015 at 9:20 PM
    95 taco
    95 taco Battle Born
    Do it and make a thread about it, or at least design it and make a thread for someone to try it.
  8. Dec 20, 2015 at 9:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Well... That escalated quickly.
    Silver02Taco and TacoVio like this.
  9. Dec 20, 2015 at 9:32 PM
    Speedytech7
  10. Dec 20, 2015 at 9:36 PM
    95 taco
    95 taco Battle Born
    Specs say it uses DC power and you can get an adapter for in home use, but it's $50, we should be able to design something for cheaper.
  11. Dec 20, 2015 at 9:40 PM
    Speedytech7
    You're totally right, not sure how I misread that. I'm thinking of a method that uses a couple diodes and a relay. Ideally you'd want two relays even though the CB is a mono audio source. You'd want to kill the music on the other speaker to avoid unclear audio. Also it would be good to be able to control the gain on the CB radios output so it isn't glaringly louder than the radio when it blasts on.
  12. Dec 21, 2015 at 12:46 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    @m3bassman wondering, can you see out your rear view mirror with the RTT at that height? I'm thinking of doing the same by splitting the difference above and below the roofline.
  13. Dec 21, 2015 at 1:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. Only way to have a useful rear view mirror with a RTT is have it be over 15" above the bed rails. And that is way to tall IMO.
  14. Dec 21, 2015 at 1:16 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah, that's what I was afraid of.
  15. Dec 21, 2015 at 1:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You get used to it in a hurry
    Jarob11 likes this.
  16. Dec 21, 2015 at 5:24 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Installed LED lights under the rear bumper.
  17. Dec 21, 2015 at 6:18 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Wait Monte is mass producing his rear bumper now o_O
  18. Dec 21, 2015 at 6:31 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Is there a write up for this mod?...look:thumbsup:s good. I had been thinking two led pods would look good cut into the bumper on each side too.
  19. Dec 21, 2015 at 7:01 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Put a camera on the back of the frame holding the RTT and mount the screen in place of your mirror.
  20. Dec 21, 2015 at 7:07 AM
    ClevSix
    IL/IA
    A truck driver friend of mine had his CB set so it would turn the volume on the radio down 20db or so and the CB would play over all the speakers. He also had a headset he could hook up to hear the CB better. I'll have to ask him how he had that set up.
