  1. Dec 28, 2015 at 6:14 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    just type in led lights in an Amazon search. Plan on having a few hours free.
    Reh5108 likes this.
  2. Dec 28, 2015 at 6:30 PM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    are you winching around a tree?
  3. Dec 28, 2015 at 6:32 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Probably a snatch block attached to the tree with a tree saver.
    Bobert14 likes this.
  4. Dec 28, 2015 at 6:33 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Just search "18watt led light" and it should pop right up. They re very cheap
  5. Dec 28, 2015 at 6:36 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Right, I know what the proper technique would be I was asking him what he did.
  6. Dec 28, 2015 at 6:44 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Looks like 2 runs going to truck so probably a pully too
  7. Dec 28, 2015 at 6:47 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    whatever it is that road looks nasty!
  8. Dec 28, 2015 at 7:07 PM
    Bobert14
    Bobert14 .
    Well...sort of. The winch line is going to a snatchblock attached to the tree via a tree saver and then to a snatchblock on the ranger's bumper and back to the tree saver.
  9. Dec 28, 2015 at 7:12 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    damn that must have been like 80ft of line out
  10. Dec 28, 2015 at 7:17 PM
    Bobert14
    Bobert14 .
    It used quite a bit of line haha. The more line you use the more pull you get out of a winch. Something about gear reduction by reducing the diameter of where the line comes into the drum or something. His pickup was half a foot from going over a ledge that was 70% or greater slope for several hundred yards and riddled with trees. I wanted all the pull I could get haha.
    tibblits920 and pittim like this.
  11. Dec 28, 2015 at 7:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Look like Blitzpro 6lz. Not sure you can get them from them anymore.
  12. Dec 28, 2015 at 7:51 PM
    2004TacomaNavy
    2004TacomaNavy Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    Yes, I made it out of a piece of metal and painted it. I also had to make a backing plate so it locks it into place front and back together.
  13. Dec 28, 2015 at 7:52 PM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    Just found some cheap ones on Amazon thanks guys
  14. Dec 28, 2015 at 8:09 PM
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    Badass truck man
    devinzz1 likes this.
  15. Dec 28, 2015 at 8:10 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Thanks!
  16. Dec 28, 2015 at 8:28 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Shell cleaned and primed.
    Carpet in 24 hrs.
    SWYPER and Deathbysnusnu like this.
  17. Dec 28, 2015 at 8:36 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That looks familiar haha. Gotta take the cap with the magnets off and pull out the coiled armature for the motor too, that usually gets gunked up and seized in the bottom, don't loose the little balls on the top and bottom. I use a screw driver, wire brush and electrical contact cleaner (doesent evaporate as fast) and just spray scrub spray scrub the spring, gear, arm, housing, scrape out everything you can with a knife or screwdriver and grease it all back up (I used dialectic grease cuz I'm too lazy to get the yellow shit from toyota. Then put it all back together and make sure it cycles freely out of the housing
    Speedytech7 likes this.
  18. Dec 28, 2015 at 8:55 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Put it in a vise and use properly fitted driver and put all your weight on it as you turn. You can also use an impact, that'll usually take out most buggered screws.
  19. Dec 28, 2015 at 9:14 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Correct. It needs to come off one way or another. If the screws break, then you get a chance to fix em haha. If they snap (mine have) just tap out the screws and replace em. Usually they poke down enough you can grab the broken screw and twist it out with vice grips
  20. Dec 28, 2015 at 9:31 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Can you clamp it to a table? If the threads are seized an impact will share them but usually you can get screws out with one.
    Do not get cheap taps, the only thing they're ok for is chasing threads. Check out a machine supply place or sometimes ace industrial supply has good ones that they sell individually.
