  1. Jan 2, 2016 at 6:22 PM
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    Got rid of the modified banjo bolts and hard lined the Tundra Calipers.
    TylerTron, otis24, BYJOSHCOOK and 4 others like this.
  2. Jan 2, 2016 at 6:32 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Reading my news, see this in front of the Donald Trump rally in Biloxi, MS today.
  3. Jan 2, 2016 at 7:01 PM
    DiamBag
    DiamBag Active Member
    Alex
    Utah
    2015 Magnetic Grey Access Cab, TRD Sport
    Finally got my 3rd brake light on my leer shell wired up today, used quick connects so I can take it off easily. Noticed there's a switch and socket for a bulb (906) on the inside behind the brake light. Not sure if this is custom or not by the last owner but no idea how I'd power it.
    Next projects are to install a microphone on my stereo (having trouble removing the grab handle to wire, screws are stripped and can't seem to drill them out), and to replace the broken lock on my fuel door
  4. Jan 2, 2016 at 7:22 PM
    Caligula
    Los Angeles, CA
    Is that safe? I want to say no, but cant really back up my thought.
  5. Jan 2, 2016 at 7:28 PM
    -40
    North Dakota
    The calipers are made for the flare fitting. In order to use banjo bolts you have to modify the banjo bolt to get it to fit, which works but probably isn't as safe. This brake line kit is sold by LCE.
    Silver02Taco and Speedytech7 like this.
  6. Jan 2, 2016 at 7:28 PM
    96_taco
    96_taco Well-Known Member
    Clayton sandgren
    Northern va
    1996 Tacoma 2.7 4x4 extended cab
    33" bfg mud terrains, cold air intake, flowmaster with side exhaust, manual swapped, manual hub swapped, lifted on bilsteins
    Built a sub box for my extended cab with 2 12" Sony's and a Kenwood amp. Old vs newimage.jpgimage.jpg
    devinzz1, JKU3000 and Chipskip like this.
  7. Jan 2, 2016 at 7:43 PM
    Caligula
    Los Angeles, CA
    Ok, i see. I would look into just getting new brake lines. The lines for a Tundra aren't compatible with Tacoma connections? The parts supplier i use, BMAauto.com, they carry custom length braided lines for several applications, they might be able to help.
  8. Jan 2, 2016 at 7:59 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    @Caligula... I PM'd you some goodies lol!
  9. Jan 2, 2016 at 8:04 PM
    -40
    North Dakota
    You are correct, the factory Tacoma line at the frame is not compatible with a Tundra line. The LCE lines are braided. One end is compatible with the Tacoma Factory Flare Nut (at the frame) the other end is compatible with the Tundra OEM hard line which is needed to run the 13WL Calipers, the hard lines are Toyota OEM for the tundra calipers.
  10. Jan 2, 2016 at 8:04 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    My 4Runner started overheating last night and antifreeze was low. Found a leak in the radiator this morning. As you can see it was time for a new one lol
    Old
    New
    Comparison
    Also making some progress on this
  11. Jan 2, 2016 at 8:07 PM
    -40
    North Dakota
    I Really like that bumper. Looks great.
  12. Jan 2, 2016 at 8:08 PM
    LSC15
    Logan
    2008 TRD D-Cab
    Thanks man
  13. Jan 2, 2016 at 8:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  14. Jan 2, 2016 at 10:15 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    You should have built it vertically so you have one free seat back there.
  15. Jan 2, 2016 at 10:19 PM
    96_taco
    Clayton sandgren
    Northern va
    Yeah i didn't bolt it down and I left enough slack in the wiring to be able to flip it up on end to be able to drop the back seat
  16. Jan 3, 2016 at 1:09 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Bah I've never had a sender anyway. You'll live lol.
    Glad to hear it's working! Isn't it a great feelin!!
  17. Jan 3, 2016 at 7:11 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    A kit from Anti-Dark, my wife got it for me for Xmas :)
    Very easy install and great light output!
    tibblits920 likes this.
  18. Jan 3, 2016 at 8:20 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    :thumbsup: I gotta get me one.
  19. Jan 3, 2016 at 8:56 AM
    reef
    reef Well-Known Member
    04 4WD
  20. Jan 3, 2016 at 11:46 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Wow I want to be there! Looks so incredible!
