  1. Jan 3, 2016 at 9:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    #repost :luvya:
    TacoVio likes this.
  2. Jan 3, 2016 at 9:36 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    #yourejustworriedyoursisgonnabenextsinceitsalreadycausemajorissusealreadyforyou
  3. Jan 3, 2016 at 9:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea would make sense. But not sure how the inside looks.
  4. Jan 3, 2016 at 9:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    TL;CR
  5. Jan 3, 2016 at 9:44 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    The diff hasn't exploded nor is there any damage. I guess it was taken off for some reason. Now is there a difference between the elocker motor and the elocker actuator? If a part that's labeled elocker acuator only, does it not have the motor? And vis-versa.
  6. Jan 3, 2016 at 9:54 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    You will have to call the places that have them, some are both and some are not.
    If it were me I would take the diff apart and make sure it is not laying in the bottom of the housing.
  7. Jan 3, 2016 at 9:58 PM
    JBTacoma
    Jeff
    Cullman Alabama
    gray223[QUOTED] likes this.
  8. Jan 3, 2016 at 10:04 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i would just try to find a working used one. The time and resources to rebuild that wont be worth it
    lol that sucks. kind of an important part. how have you not noticed before?
  9. Jan 3, 2016 at 10:15 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Found out the connector the hooks up to the connector on the actuator has serial pins broke/corroded as well....
  10. Jan 3, 2016 at 10:19 PM
    JBTacoma
    Jeff
    Cullman Alabama
  11. Jan 3, 2016 at 10:20 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    This is the first time I've pulled the it off the truck. It hasn't worked since I got the truck.
  12. Jan 3, 2016 at 10:21 PM
    gray223
    SE Missouri
    2014 Tundra Limited
  13. Jan 3, 2016 at 10:40 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Well my dad took a small piece of wire and fished it inside the drain hole and tried to tell around for anything setting in the bottom. He doesn't think it's in there. And if it was, wouldn't it be stuck to the magnet on the drain plug? Possibly?
  14. Jan 3, 2016 at 10:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea could be there
  15. Jan 3, 2016 at 10:47 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    is there even enough room in the hosing with the ring gear for that thing to sit there and now get chewed up? I mean safest bet is to pull the third and be dead sure because you dont want a rebuild...but i think you would have noticed by now
  16. Jan 3, 2016 at 10:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know on mine the ring gear is on the otherside of the diff from the drain plug.
  17. Jan 4, 2016 at 12:15 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Well I had drained the diff already and it wasn't there.
    I would think so too. I don't see how something that size could not be hurting anything.
    What would be a reason for someone to pull the gear of the actuator? I wouldn't be surprised if there was no reason.... Whoever owned this truck before wasn't very smart. You should see the axle seal I replace. Looks like someone punched it in there with a screw driver... And the interior had mold growing on it and covered with oil so yeah...
  18. Jan 4, 2016 at 4:36 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Yes.
  19. Jan 4, 2016 at 7:38 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    :yes: where at?
  20. Jan 4, 2016 at 8:19 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Over the weekend, still need to add the top hoop
