  1. Jan 4, 2016 at 8:29 AM
    Suggs12
    Suggs12 Well-Known Member
    Logan
    Johnson City, Tennessee
    2004 PreRunner
    3" Lift kit, Bilstein 5100 front and rear, 2881 EMU coils, 2" Deavers AAL, 18x9 KMC rockstar 1 wheels and 33" Nitto Terra Grapplers, Debadged, Grillcraft insert, clear corner and turn lights, 6k Leds, 30" Led light bar, 4 Pod fog lights.
    Installed 4 pods for fogs and a 30" light bar.
  2. Jan 4, 2016 at 11:14 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Ha! But seriously...
  3. Jan 4, 2016 at 11:38 AM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    There is a hole drilled in the side of the ABS tube. Cap was too nice to drill into. :D
  4. Jan 4, 2016 at 12:18 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Changed my oil, and this little washer/gasket. 1st time for the gasket since I've owned the truck. :p
    tibblits920 likes this.
  5. Jan 4, 2016 at 12:26 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Thank you for changing that fibre washer, LIKE EVERYONE ELSE SHOULD BUT DOESNT. :D
    Magnetic plug? Looks longer than my OEM one.
  6. Jan 4, 2016 at 12:28 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Also had my wheel bearings replaced, again, 2nd time in 9000 miles but that's another story for another time. This happened last month but thought some of you might like to see what happens when they get wet.
    And new
  7. Jan 4, 2016 at 12:29 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    first time it was changed in 130,000 miles :D
    And not magnetic, I wish it was, not sure why it's so long.
  8. Jan 4, 2016 at 12:31 PM
    Caligula
    Los Angeles, CA
    Deathbysnusnu[QUOTED] likes this.
  9. Jan 4, 2016 at 12:53 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    No wonder it was leaking...
  10. Jan 4, 2016 at 12:59 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I'll say :facepalm:
  11. Jan 4, 2016 at 1:31 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Whoever installed it looks like they decided to punch it in with a screw driver. This truck is just full of surprises...
  12. Jan 4, 2016 at 2:41 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Before I put in my fumoto, I use to change those every time. Still have a bag of them somewhere. They're really cheap and it's very frustrating changing your oil only to have those leak. Got to drain it all and do it again to swap a 50 cent washer.
  13. Jan 4, 2016 at 2:51 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I never did when mine leaked. Just plugged the hole with my finger and put the new gasket on and then replace the oil that was lost
  14. Jan 4, 2016 at 2:54 PM
    Squeaky Penguin
    Brett
    I would inevitably end up covered in oil if I tried that.
    Plus that would involve dropping real heavy skid plates. I like my fumoto.
    TacoVio and bayareataco like this.
  15. Jan 4, 2016 at 2:58 PM
    Jarob11
    Jarob11 Well-Known Member
    Hilo/Tacoma/Evanston
    99 Taco Limited
    Badlands custom frt winch mount bumper. badlands RR bumper w/ spare swing out, jerry can holder. Leer Camper shell. Royal Purple synthetics. Baja fender flares. Entire truck rhino lined. 31's. Custom sound system. More to come.
    I use royal purple 5w-30 oil and the royal purple filter. It comes out to about 75 bucks an oil change..but I only change the oil and filter once a year or between 12 and 15k miles..love the stuff! 265000 mile with next to no compression loss and within 3lbs across all cylinders! (Just tested em last month)
    tibblits920[QUOTED] likes this.
  16. Jan 4, 2016 at 3:05 PM
    Squeaky Penguin
    Brett
    I wheel my rig quite a lot, and never had an issue. The end of the fumoto is over an inch above the skid plate. Also seems like a hard spot to bend a skid plate that much, but yes, it could potentially increase the chance at damaging your oil pan. A guy with a 2nd gen I know dented his oil plan slightly because of his fumoto and skid plate deflection.
    Silver02Taco likes this.
  17. Jan 4, 2016 at 3:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Also you gotta figure the inside of that housing must be filled with all sorts of garbage considering how torn up that locker was.
    Digiratus likes this.
  18. Jan 4, 2016 at 3:18 PM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    they sure do make oil changes effortless. I hope I can keep mine after the build, although I'm not sure, we are adding a shit ton of moving parts down there.
  19. Jan 4, 2016 at 4:00 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Ok Squeaky, I will play your silly game: What is a Fumoto? (said in my best Jeopardy contestant voice).
    Er EDIT: IGTFM
  20. Jan 4, 2016 at 4:21 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Nothing unusual was in the gear oil
