  1. Jan 5, 2016 at 6:46 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Ok after doing a little more research it is a crank case brether but for the driver side cylinder bank. But why does it releases pre tb and not post tb like the pcv valve.
  2. Jan 5, 2016 at 6:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yah its composite, my neighbor has one. It's plenty strong, but you can crack it.
  3. Jan 5, 2016 at 6:49 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I'd imagine. Though I would think it'd take quite a big of force to crack it. Happen to know if there've been reports of cracked beds?
  4. Jan 5, 2016 at 6:51 PM
    Speedytech7
    Yah I remember there have been some member that have had stuff shift forward under braking and crack through the wall, nother guy did it with a 2x6. Never seen any go through the bottom though.
  5. Jan 5, 2016 at 6:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I think Toyota will replace it if you do from normal use. Our dealer told us they would. And no one had broke one yet. That was 6 years ago
    Speedytech7[QUOTED] likes this.
  6. Jan 5, 2016 at 6:53 PM
    Speedytech7
    Wasn't following the conversation, gimme a minute to read up.
    EDIT: Looks like a crackcase breather to me too. My 3RZ has two breathers on the valve cover, one is the PCV, the other is just a hose coming from a right angle nipple going before the TB. Not sure the purpose though. I'd check the FSM to be sure, if you don't have it I can send it to you.
  7. Jan 5, 2016 at 6:56 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    If I were to add a second battery (deep cycle) would it be an issue to mount it in the bed? I was thinking pos to pos and neg to frame, put an isolator on the Pos side and wire it to a switch/low voltage sensor.
    And of course upgrade the alternator.
    malburg114 likes this.
  8. Jan 5, 2016 at 6:58 PM
    sente3
    sente3 -
    North Jersey
    Ah makes sense. Sounds like something an enthusiast would mod to avoid. Though with what Monte just said about the replacement is true, then it doesn't sound like a bad system. That weight reduction must be nice with a composite bed.
  9. Jan 5, 2016 at 7:02 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Lets not start with the 'PCV by any other name' ordeal.
  10. Jan 5, 2016 at 7:03 PM
    Speedytech7
    What would you call it? The PCV is just a check valve but I don't know why the other one doesn't have that.
  11. Jan 5, 2016 at 7:04 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    I don't have a fsm. But I do have a Hayes repair manual. It might show it, I'll look.
    I just want to know why is it covered in oil?
  12. Jan 5, 2016 at 7:05 PM
    Caligula
    Los Angeles, CA
    I dont see why not, i think just making it weatherproof is going to be your biggest concern.
    I know ground loops from a amp and radio can cause distortion through the speakers. What kind of interference could be caused by running two separate ground point on a battery?
  13. Jan 5, 2016 at 7:06 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    WTF are you saying?
    Silver02Taco likes this.
  14. Jan 5, 2016 at 7:07 PM
    Speedytech7
    Just a friendly jab to get your goat. :)
    I could start a farm with all the goats I've gotten from that statement.
    tibblits920 likes this.
  15. Jan 5, 2016 at 7:08 PM
    Caligula
    Los Angeles, CA
    It has the same function. It just doesn't have the check valve as there isn't positive pressure kicking back from the manifold.
  16. Jan 5, 2016 at 7:08 PM
    otis24
    Mark
    California
    Im going to do the same thing.
    Is it necessary to upgrade the alternator?
  17. Jan 5, 2016 at 7:09 PM
    Speedytech7
    Gotcha, so his is probably oily from being cracked around the nipple.
  18. Jan 5, 2016 at 7:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Go for it. Work fine.
    Not an issue on a DC system. Which the whole truck is. Ground loops happen with multiple ac circuits with un common grounds or imporper ground drains in equipment. On a truck. Ground is ground.
    LEDS and HIDs are our biggest issues as they emit radio interference
  19. Jan 5, 2016 at 7:12 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Why wouldn't there be positive pressure? What makes it different from the pcv on the passenger side? They both see vacuum correct? So why are they different?
  20. Jan 5, 2016 at 7:12 PM
    Caligula
    Los Angeles, CA
