  1. Jan 12, 2016 at 6:50 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    ordered trail-gear rock assault low profile bumper. debating on winch, is this one good Smittybilt 98495 XRC Synthetic Rope Winch - 9500 lb. Load Capacity d07ae0818bbeff811beed614a1a75dd0.jpg
    Waterproofing: IP67 rating, fairlead: hawse, rated line pull: 9,500 pounds (4,309 kilograms) single-line, remote control: included, motor: 6.6hp series wound, recommended battery: 650CCA minimum for winching, control: remote switch, 12 feet (3.7m) lead, battery leads: 25 square millimeter, 72 inch (1.83m), gear train: 3-stage planetary gear ratio: 161.28:1, finish: textured black, weight: 46.0 pounds (20.9 k), clutch: sliding ring gear mounting, bolt pattern: 10.0 inch x 4.5 inch, brake: automatic in-drum; overall dimensions (L x W x H): 22.3 inch x 5.4 inch x 9.4 inch, drum size: diameter 2.5 inch, cable type: synthetic rope, cable: 98.5 feet 3/8 inch diameter, length: 10.0 inch (254mm).
  2. Jan 12, 2016 at 6:51 PM
    Madjik_Man
    Colorado Front Range
    :confused:
    How do you adjust them?
  3. Jan 12, 2016 at 6:52 PM
    Madjik_Man
    I'd imagine you could easily score a pair from a part out.
  4. Jan 12, 2016 at 6:53 PM
    00yotasr5
    lee
    merced, ca
    they are adjusted similar to spot light on police vehicles.
  5. Jan 12, 2016 at 6:53 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I just bought that winch but haven't installed yet!
  6. Jan 12, 2016 at 6:54 PM
    00yotasr5
    lee
    merced, ca
    rating seems good
  7. Jan 12, 2016 at 6:56 PM
    TacoVio
    Kolton
    CO/WY
    Yeah ALOT of guys on here run these smittybilt winches and they are pleased with them!
  8. Jan 12, 2016 at 7:01 PM
    Madjik_Man
    Say wha?
    They have an adjustment knob on the sail panel or something?
  9. Jan 12, 2016 at 7:14 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Never had a vehicle with manual mirrors?
  10. Jan 12, 2016 at 7:15 PM
    00yotasr5
    lee
    merced, ca
  11. Jan 12, 2016 at 7:15 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    They arent power but I need mirrors on my truck hahah
    ^thats what id look for unless yours are power and want to keep that.
  12. Jan 12, 2016 at 7:18 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    well I want to do some maintenance stuff first... Cv's, steering rack, new valve cover gaskets. Probably gonna do the deck plate mod too. Then want to put a rack and rtt. But the list go on and on lol...armor, new seats.....etc
  13. Jan 12, 2016 at 7:20 PM
    00yotasr5
    lee
    merced, ca
    power everything but Toyota couldn't do power mirrors. key ring illuminates green when door is open but there is a ring mod going on in here that looks like there a lot of tacomas don't have it. weird :notsure:
  14. Jan 12, 2016 at 7:27 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Man that knob is nifty, on the manual mirrors I've had in the past you had to push the mirror itself.
  15. Jan 12, 2016 at 7:28 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Sounds like you have a solid plan! Stoked to watch your build and see where it goes!
  16. Jan 12, 2016 at 7:30 PM
    malburg114
    Las Vegas, NV
    Speaking of build... do you have one?
  17. Jan 12, 2016 at 7:34 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    the keyring light was part of a special package in '99 that gave the glovebox light and something else
  18. Jan 12, 2016 at 7:37 PM
    00yotasr5
    lee
    merced, ca
    and the coin thing has a light too though mine is out damn 74 bulbs.
  19. Jan 12, 2016 at 7:40 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    There's a little lever in the cab that adjusts the angle of the mirror itself, but the mirror housing does not move.
  20. Jan 12, 2016 at 7:45 PM
    Madjik_Man
    My Tacoma has manual mirrors but the only way to adjust it is to move the assembly that holds the glass. :notsure:
