  1. Jan 17, 2016 at 7:45 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Awesome! Thank you! It's like hot potato ahahahha!
  2. Jan 17, 2016 at 7:47 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Good for you for trying to help people out, but I'd hang on to it. CBs don't stay tuned forever. I check the tune on mine before every big wheeling trip.
    Mine was like $18 plus a 3' section of coax. Not hardly worth the shipping.
    PcBuilder14 likes this.
  3. Jan 17, 2016 at 7:50 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Thanks, I already have another one so no worries there. I never want it back, this is an endless chain to the next person in need.
  4. Jan 17, 2016 at 7:53 PM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Yeah, I had trouble with mine in until I figured out to clean ALL of the gunk out of the allen hole. After that it seated in there and came out.
  5. Jan 17, 2016 at 7:57 PM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Fell in a hole the other day...:annoyed:
    Actually it was kinda funny..went like 3 feet to the right of the guy I was following and K'doosh right in a hole
  6. Jan 17, 2016 at 8:02 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Fernando likes this.
  7. Jan 17, 2016 at 8:03 PM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Thought I'd share this screenshot from a video with the wrong orientation..made me laugh :laugh:
    Screenshot_2016-01-16-15-00-14_zpssgoet7_b8b3ab18c879ab5e7910fb4f1333511faa210a7d.jpg
    camptaco01 and TacoVio like this.
  8. Jan 17, 2016 at 8:07 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Yeah, that's the worst part with mine, the frame is only 3 years old. Doesn't take long for these things to start turning to dust, hence why I spent almost an entire summer on and off rust proofing this turd. Then oil sprayed it and fluid filmed it after that.
    tibblits920 likes this.
  9. Jan 17, 2016 at 8:49 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I like your idea and would consider taking you up on the offer if I didn't own my own SWR meter. I use it often enough to warrant keeping mine. However, if local to me I'd be happy to let anyone barrow it. I'll even help tune an antenna if anyone needs.
    nagorb and Speedytech7[QUOTED] like this.
  10. Jan 17, 2016 at 9:25 PM
    CWR56
    CWR56 Member
    2003 Tacoma Prerunner 4cyl Xtracab
    I didn't do it. My dad backed his car into it last night. :-(
    No idea what it'll cost to fix.
  11. Jan 17, 2016 at 9:28 PM
    Speedytech7
    That should pull out well, truck beds that have large non complicated (not a whole lot of crinckles) dents are body shops bread and butter. That and painless removal. I hope they don't quote you too high.
    EB Group likes this.
  12. Jan 17, 2016 at 9:39 PM
    CWR56
    CWR56 Member
    Yeah, well, I want that repair invisible from both the outside, inside AND underneath. Like it never happened.
    I'm just annoyed and depressed over it right now. I drove a total rustbucket 1990 Chevy 2500 w/ utility bed for 9 years. After many years, I finally saved up enough to buy a nice truck, and my dad wrecks it in 3 months...
  13. Jan 17, 2016 at 9:58 PM
    j0shu4
    Used the stock fender liners to fill in the gaps from my fiberglass fenders and bedsides. Just cut and sheet metal screwed them in. Came out nice, looks better plus will block out mud, rocks, cab noise.
    Widened rear until SUA
  14. Jan 17, 2016 at 10:14 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    So I had a cheap short rubber Wal-Mart antenna on my truck and the reception sucked. So I switched it out with a oem and even though is better, it's not working like it should. I get a alot static where I shouldn't. So know I'm wondering if maybe the radio is bad? Also when I press scan it goes to every single frequency instead of skipping ones that just have static. Another thought was maybe the bedliner messing with something...?
  15. Jan 18, 2016 at 7:14 AM
    joemauma
    joemauma Well-Known Member
    Oregon
    Double Cab
  16. Jan 18, 2016 at 7:14 AM
    Madjik_Man
    Colorado Front Range
    Yes. It's in the lower right of the gauge cluster.
    Jarob11 likes this.
  17. Jan 18, 2016 at 7:17 AM
    Madjik_Man
    Do you LED lights/bars on your truck?
    Any aftermarket wiring where power supply wires could be running through the wire harness behind the head unit?
  18. Jan 18, 2016 at 8:01 AM
    TacoVio
    Kolton
    CO/WY
    I'm gonna have to check the plugs on the diff and probably rip my dash apart! Damn.
  19. Jan 18, 2016 at 8:32 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Sounds familiar...
    Finished stripping my sliders. Treating with phosphate coating then paint.
    alee891 likes this.
  20. Jan 18, 2016 at 8:43 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    ***Preface***
    I am by no means an electrician.
    I got my 20 inch bar in the mail the other day. Yes, its a cheapy, from China/Amazon. $36, its a good tester. I'm gonna pull it apart and reseal it with some silicone. While I am waiting for warmer weather to install, I started thinking about how I want to run the wiring. It has no harness, so, I was considering running it off of the fuse block for the headlights, for both dim and high beams. I plan on putting a yellow filter on it as well, for on road use in hazardous weather conditions, barring any state laws disallowing this. Can I simply ground the light bar, and run a hot into the fuse block? Would it be best to simply run a harness, and a switch? I suppose I could rewire my PIAA's after I get them mounted as ditch lights and have them on a panel of switches as well. I typically forget they are on during the day though, and it usually kills my battery...womp womp.
    Just looking for all avenues of thoughts....
