  1. Jan 19, 2016 at 3:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you're welcome.
    I expect my free knob as part of my share in the idea by the end on the month :cookiemonster:
    Jk
    but i bet you could sell those.
  2. Jan 19, 2016 at 3:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Im going to give it a go, if it isn't a complete and utter nightmare I'll send you one in exchange for the idea.
    Blackdawg[QUOTED] likes this.
  3. Jan 19, 2016 at 3:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good luck man! If anything, the knob without the switch, is still sweet. And i bet you could sell them as is.
  4. Jan 19, 2016 at 3:49 PM
    Speedytech7
    I could but I bet Low Range OffRoad wouldn't be too happy with me considering it's their product. But a simple service to modify them into functioning switches would be sweet.
    tibblits920 likes this.
  5. Jan 19, 2016 at 3:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ooohhhhhh ha. Didn't know it was theirs. Thought you just made it haha
  6. Jan 19, 2016 at 3:56 PM
    Speedytech7
    I wish haha. My machining ability is decent but I'm not that good.
  7. Jan 19, 2016 at 4:13 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Filled up and got 19 mpg. So I get 19 mpg going 75 mph and get 25 mpg going 65 mph. If I have a 18 gallon tank and I can get 6 mpgs better going 65, I can go 108 more miles going 65 mph than 75 mph. However, every 100 miles at 65 mph takes 92 minutes but at 75 it takes 80 minutes. So I lose 12 minutes per 100 miles. All given steady and level ground. Not a bad trade off.
  8. Jan 19, 2016 at 4:49 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Holy math batman :rofl: I like it!
  9. Jan 19, 2016 at 5:04 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Like a word problem in math class! Your lucky.. I average 13-15 mpg and get about 200-215 miles per tank. Fill up once a week with a 35 mile commute to work and back plus all the extra running around that I have to do. And most of my commute is highway miles doing 65 mph.
    TheSpeediTurtle likes this.
  10. Jan 19, 2016 at 5:44 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Punk kid? When's the SAS happening old man? :D Between your wheel bearings and UCA issues, I'm guessing you just have a sour taste in your mouth.
    I honestly don't think I'm over 3" of lift. I never did put on those top plate spacers you gave me and I have quite a bit of weight. That really doesn't matter though.
    FWIW, I have never tried a diff drop kit, nor am I planning on it. My issue is not if they relive CV angles or not. Regardless of if it helps or doesn't, I really don't see tearing, or replacing CV boots as a huge hassle. The problem that is trying to be fixed is really not that much of a problem to begin with. So the negatives far outweigh the positives to justify even trying it. And if you're going to complain about CV boot issues, you shouldn't be lifting your truck in the first place.
    So yes, don't take my opinion as gospel, nor do I intend it to be taken as such.
    I also tend to destroy CVs from wheeling. They start popping and clicking before I have issues with the boots. Both of them did this after 9 days straight in Moab this past Spring. When I redo the suspension here soon, I'll probably end up with less lift, and new CVs, so we'll see how long they last. It's just how it goes. I use my truck and accept what comes with that. Even your SAS wouldn't be impervious to issues unless you only drive it to the mall.
  11. Jan 19, 2016 at 5:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im with young brett in terms of diff drops. Not worth it. Its MAYBE 1/4'' drop. All they do is rotate the diff.
    TheSpeediTurtle and m3bassman like this.
  12. Jan 19, 2016 at 5:57 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    fwiw, the drop kit or not, the boots are gonna rub period. If you pull off the curb of your driveway, they rubbed. If you do a U-turn, they rubbed. Speed bumps, spring thaw roads, washboards, rub, rub, rub.
    So with that being said, I'll concede they do the most good parked in the driveway.
    As far as sas, far superior to ifs, mallcrawler or not. I went years of hard wheeling with 37's and a Detroit front end Dana44 and the only repairs were the occasional stub shaft from an overzealous right foot.
    Never replaced ball joints or wheel bearings, didn't have upper and lower failure points either, Alignment was always correct.
    :p
    If Toyota had offered the solid axle in the Tacoma, I doubt people would be pulling it out. ;)
  13. Jan 19, 2016 at 6:06 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Pretty sure it depends on application. I'm sure with unlimited amount of money it doesn't but yeah.
  14. Jan 19, 2016 at 6:15 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Not saying that a diff drop is for everybody, but it did reduce the vibes I was getting when in 4wd after I first lifted the truck. Now I could probably remove them and be fine since the springs have settled and I have more weight up front. Seems like it only reduces vibes for us guys with ADD diffs though.
  15. Jan 19, 2016 at 6:55 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Got sick of my eBay led blinkers breaking, so did the relocate to marker light mod today
    EB Group and Chipskip like this.
  16. Jan 19, 2016 at 7:00 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Do you have a writeup for that mod? Im sick of my tractor ghetto blinkers and i just got new corner lamps :D
  17. Jan 19, 2016 at 7:06 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    I do a 450 mile roundtrip once a month and have been going 65 for the past 6 months and forgot what my mpg would be at 75 so thought I would try it this last time. My DD is my motorcycle, so I can get some good mpgs from my truck just from doing that trip on the highway. Mine is mostly stock prerunner 'cept for a 3 inch leveling kit, so I can't compare to most of you with 4x4 and armor
    Speedytech7 likes this.
  18. Jan 19, 2016 at 7:11 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Search 1st gen blinker relocation on Google, monte has a good write up on it
  19. Jan 19, 2016 at 7:11 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
  20. Jan 19, 2016 at 8:22 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Fluid film ftw.
    That's all. Carry on gents
