  1. Jan 21, 2016 at 6:53 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should. Same door and Id be amazed if Toyota changed that. Harness could be different but should bolt in. Not a fun job. But not bad.
  2. Jan 21, 2016 at 6:59 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Its $90 on rock auto for just the lock motor. Its in the "body" category
  3. Jan 21, 2016 at 7:02 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    [QUOTE="quetzal, post: 11631528, member: 12801mool! I wouldn't advise that mod. I did it on mine and even though they are a huge improvement over the oe bulbs, the beam they put out resembles chicken feet. It's pretty annoying too. (my .02 anyway)[/QUOTE]
    Hids in all 6 of mine. The beam stayed pretty much the same with a little more flooding off to the sides. Hids were alot brighter than the 100watt bulbs i had in them.
  4. Jan 21, 2016 at 7:37 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Have you done it before? I have already had to change the window motor.
    Is this it? http://www.rockauto.com/catalog/moreinfo.php?pk=1354990&cc=1375343&jnid=525&jpid=0 Whenever I press the lock or lock the doors with the key, you can hear it grinding. Is it this piece I need or the entire assembly?
    Thansk for the help
  5. Jan 21, 2016 at 7:54 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Check out @Blackdawg build thread, or just search PVC washer fluid relocation. I have a link to his in my build thread too.
    It's easy and cheap.
  6. Jan 21, 2016 at 7:55 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
  7. Jan 21, 2016 at 8:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I swapped my electric window and locks over to the new doors when i did the cab swap. Everything bolted up perfect. Toyota is very efficient in that regard.
  8. Jan 21, 2016 at 8:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hyperlink is in the OP. Here is the link though: https://www.tacomaworld.com/threads...trail-rig-and-bs.159436/page-399#post-8802626
    I would use bigger(thicker) Zip ties then my pictures show. Even 6'' hose clamp might work or 7'' or bigger. I want to change to hose clamps, just haven't tried it yet.
    Chipskip[QUOTED] likes this.
  9. Jan 21, 2016 at 8:12 PM
    malburg114
    Las Vegas, NV
    Thanks. If thats the right part on rock auto, will be ordering it and hopefully doing it next week. Cant seem to find any 4runners or tacomas with the complete doors... everyones already gone through and stripped them clean.
  10. Jan 21, 2016 at 8:31 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    another thing is I think the rear turn/stop(brake)/run light share a common ground and this may be causing the issue. I remember a post about this but its bedtime, GL! :)
  11. Jan 21, 2016 at 8:37 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    How easy is it to remove the steering rack? I'm tempted to do the tac weld mod this weekend, but I'm not going to have time to do anything intensive.
  12. Jan 21, 2016 at 8:40 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You should only have to remove the steering column but it's a bit of a pain.
  13. Jan 21, 2016 at 8:43 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Right, that's what I meant. A pain doesn't make it seem like I'll have time. I just found a write-up over on TTORA
  14. Jan 21, 2016 at 8:47 PM
    Cr250jumper
    The moon
    50 shades of tan©
  15. Jan 21, 2016 at 8:51 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Well tore into my dash and got my 4wd indicator light fixed and now my
    speedometer and high beams don't work and check engine light is on! Fix one problem and cause three more! Can't seem to catch a break! Lol
    tibblits920 and BYJOSHCOOK like this.
  16. Jan 21, 2016 at 8:59 PM
    tacoma75
    tacoma75 Member
    california
    06 Trd Sport 4x4 LB
    4 inch pro comp suspension lift Flowmaster Gears 4.56 skid plate K&N air intake Rancho quick lift 9000 Rear rancho 9000
  17. Jan 21, 2016 at 9:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ummm...
    Please tell me this isn't true..but did you paint the actual shock shaft?
    And
    Please tell me those aren't 5100s and they are compressing the coils AND you have a spacer..
    camptaco01 and Cr250jumper like this.
  18. Jan 21, 2016 at 9:05 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Reds cool. Spacer lift...not so much.
    MatthewMay1 likes this.
  19. Jan 21, 2016 at 9:09 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Hmmm maybe they are 5100. in that one pic with them mounted on truck you can kinda see grooves....but then again it almost looks like the diameter of the shock changes after the spring perch....
    And this doesn't look like a 06 trd sport lol
  20. Jan 21, 2016 at 9:45 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Hmmm very interesting indeed
