  1. Jan 23, 2016 at 4:18 PM
    yota yoter
    yota yoter Well-Known Member
    Jordan
    Wet Side Oregon
    02' Imperial Jade Mica, V6, TRD 4X4
    Custom Real Tree Camo Interior.
    Save money and buy the larts in the boss kit minis the aal from wheelers. About 800 shipped for dakkars bilsteien 5100s eibach 620s and 51w5s for the back. Complete lift fpr 800$
  2. Jan 23, 2016 at 4:19 PM
    yota yoter
    Jordan
    Wet Side Oregon
    Just call wheelers they will stlet u up propper.
    Fernando likes this.
  3. Jan 23, 2016 at 4:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wish someone would chime in with opinion on the Toytec lift... (Hint hint).
    I kinda just figured it was like Ome lift. I don't get too crazy with my truck, but do tend to get on some rough stuff when I'm hunting....
  4. Jan 23, 2016 at 4:22 PM
    yota yoter
    Jordan
    Wet Side Oregon
    This is like the boss lift but with dakkars....800...little high in the front. Dont botber with doff drop just get a steel bumper.
  5. Jan 23, 2016 at 4:24 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Stick with 33s. Look plenty BA on a 2.5'' lift.
    35s are a lot of work. And WAY more expensive in every way
  6. Jan 23, 2016 at 4:26 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    BOSS isn't a bad lift. A lot of people around here have Toytec coilovers. I'd say they are on par with OME, with the added benefit of adjustment. For the price, they are great. If you saved up a little more you could go with Icon or Fox.
  7. Jan 23, 2016 at 4:39 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I did the tac weld mod on the steering column today. Man, it made a very noticeable difference on the highway! I highly recommend this to anyone with sloppy steering. Plus, everything you work with is from the interior so all the bolts come out with ease!
  8. Jan 23, 2016 at 4:46 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Oh, and I also put in a new bulb for my glove box. So nice to have now!
  9. Jan 23, 2016 at 4:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Glad it worked out, I like working in the interior because almost every bolt is 10mm or Philips head.
  10. Jan 23, 2016 at 5:41 PM
    JKO1998
    Utah
    Aren't those like 1600$?
  11. Jan 23, 2016 at 5:51 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    No. Icons are like 1200. ADS is 1400, there the most expensive I think
  12. Jan 23, 2016 at 5:51 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    About half that at $800.
  13. Jan 23, 2016 at 5:52 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    For what?
  14. Jan 23, 2016 at 5:52 PM
    PcBuilder14
    Brent
    Nor Cal
    The Boss coilovers.
  15. Jan 23, 2016 at 5:58 PM
    JKO1998
    Utah
    I was talking for fox or king. I'm gonna get the full boss front and back goodness unless I hear something way bad
  16. Jan 23, 2016 at 6:00 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    What is the best way to pull the diff seal on the drivers side? I'm doing the ECGS bushing mod and I'm at the point where I need to replace the rubber seal. I want to make sure not to scratch the seat.
    Edit: I have a 65mm seal installer to drive the new one in which seems like the best size.
    TIA
    Edit Edit: Eye got it now. nbd.
  17. Jan 23, 2016 at 6:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I paid $940 shipped for Kings from DSM.
  18. Jan 23, 2016 at 6:07 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    @JKO1998 I would defiantly do this then
  19. Jan 23, 2016 at 6:35 PM
    JKO1998
    Utah
    Front and back?
  20. Jan 23, 2016 at 6:36 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    pretty sure he meant just the front coilovers
