  1. Jan 24, 2016 at 11:15 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    That's what I'm curious about, though. Does it repel snow and debris or just collect it so that you can wash it off at the end of the season?
  2. Jan 24, 2016 at 11:16 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Confused? Why would you want help in collecting snow and debris on your truck?
  3. Jan 24, 2016 at 11:22 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Fixed this.
    Definitely not. Is it rebuildable or revalvable? Not if it is based on a 5100. Does it have upper and lower heims. Doesn't look like it.
  4. Jan 24, 2016 at 11:27 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Yeah I'm patiently waiting to see if he over returns
  5. Jan 24, 2016 at 11:28 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Thanks haha
    That's what I was trying to lean towards. But you have more knowledge on adjustable coilovers than I do.
    Digiratus[QUOTED] likes this.
  6. Jan 24, 2016 at 11:29 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Oh I see. I guess I heard wrong then.
    Knowing this... No way would I buy them. Way to much money for a 5100.
  7. Jan 24, 2016 at 12:55 PM
    Black Thumb
    Black Thumb Active Member
    Eric
    2003 3.4 2WD street beater
    Ground down a 11/16 wrench so I could properly tighten the front swaybar end links. The Moog end links have flats on the"inside" and because of the flange on the lower control arm a regular wrench wont fit.
  8. Jan 24, 2016 at 1:01 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I got a crescent on one of my moogs lol! :confused:
  9. Jan 24, 2016 at 1:02 PM
    TacoVio
    Kolton
    CO/WY
    How much do our tcases weigh?
  10. Jan 24, 2016 at 1:03 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Made a plate to replace the washers the filled the gap between my bumper and frame mount.
  11. Jan 24, 2016 at 1:03 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    So my buddy has 5 bfg good rich tires that are 33x12.5r17. He moved up to 35in. Tires are 70-80% left and the 5th is brand new. He's letting me have them for free. I looked and it seems as though 3.5-3.75 is the ideal backspacing to run for 33x12.5. I currently have 16in wheels so will be needing to get new rims. Is a 17x8 with -10mm offset and 4.1 backspacing equivalent to a 8in wheel 0 offset with 3.5-3.75 backspacing? Will the 17x8 -10mm 4.1in backspacing work?
    tibblits920 likes this.
  12. Jan 24, 2016 at 1:14 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    yota yoter likes this.
  13. Jan 24, 2016 at 1:14 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Offset and backspacing go hand and hand. Back spacing is the distance from the wheel mounting surface to back of the wheel. Offset is how far that mounting surface is away from the middle of the wheel.
  14. Jan 24, 2016 at 1:16 PM
    TacoVio
    Kolton
    CO/WY
    OME you get your money's worth...just sayin!
    yota yoter and Delta00 like this.
  15. Jan 24, 2016 at 1:17 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Yes pretty much. The other is a good lift as well. Some use the 5100 and the right OME coil to make the lift. OME makes the dakars as well. OME shocks are a twin tube design while bilstein is a monotube. Supposedly the monotube is a better design. But both are good shocks
  16. Jan 24, 2016 at 1:18 PM
    TacoVio
    Kolton
    CO/WY
    Nah OME is better! ;) :p
  17. Jan 24, 2016 at 1:20 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Some do say that the OME coils will work better with there shocks since they were design to be used together instead of with the 5100s.
    TacoVio[QUOTED] likes this.
  18. Jan 24, 2016 at 1:21 PM
    JKO1998
    Utah
    So what coils should I get and stuff? I plan on getting a new bumper eventually. Why is it better?
  19. Jan 24, 2016 at 1:23 PM
    JKO1998
    Utah
    I don't have money at the moment for new springs, I plan on getting all pro expedition eventually.
  20. Jan 24, 2016 at 1:23 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    If your getting a bumper 882 or 883 coils. 883 coils are as tall as the 881 coils however they have a higher spring weight. 882 coils are 10mm higher but have the same spring weight as 881. I have 883 coils and they work fine, however possibly in the future I might try 882 to see the difference.
