  1. Jan 28, 2016 at 2:03 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    But I don't even know if that's where my problem is
  2. Jan 28, 2016 at 3:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Do a leak test, take all carpet out and sit in side while someone goes nutso with the garden hose.
  3. Jan 28, 2016 at 3:11 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Ugh I don't want to tear out the carpet!
  4. Jan 28, 2016 at 4:16 PM
    SWYPER
    SWYPER Well-Known Member
    Dylan
    South Carolina
    1998 Tacoma 2.7L 4x4
    I was curious about the whole new frame deal with my truck because it was pretty rusty when I got it. Looking forward to seeing how it goes for you
  5. Jan 28, 2016 at 4:32 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Absolutely atrocious for a 13 year old vehicle!
    shaniac, FirstGen Jer and PcBuilder14 like this.
  6. Jan 28, 2016 at 6:25 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's taking way too long! I miss my truck.
    SWYPER[QUOTED] likes this.
  7. Jan 28, 2016 at 6:27 PM
    shaniac
    shaniac Well-Known Member
    Charleston, SC
    2014 Double-Cab Tacoma SR5 V6 4x4
    One indicator that it's taking water through your transmission shifter boot is by pulling up the center console and you'll probably see a little surface rust on the boot plates... Plus you'll get a good view of the boots and if the boots are dry rotted, I assure you that is one place you are definitely getting water from.
  8. Jan 28, 2016 at 6:48 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    I need to tear it all apart someday and find the source. Until then, I'm not going to worry too terribly much
  9. Jan 28, 2016 at 8:09 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Blackdawg likes this.
  10. Jan 28, 2016 at 9:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You are so wrong on this one. :smack:
    It is a contest, a competition to see who can make their lower ball joints and their water pump last until they disintegrate.
  11. Jan 28, 2016 at 9:55 PM
    pittim
    Pennsyltucky
    Boujee Prius
    My tire blew off but truck still drives so I don't see a reason to buy a new tire...
    fiziks and m3bassman like this.
  12. Jan 29, 2016 at 12:53 AM
    Speedytech7
    Look at the bright side, at least our water pumps have metal impellers. They'll probably leak before they disintegrate. On that note, there is no reason not to change the water pump on a 5VZ considering it should be done every time the timing belt is done. Super easy on the 3RZ as it is separate but no major maintenance it coincides with it so people probably forget it has a service life.
    tibblits920 likes this.
  13. Jan 29, 2016 at 4:39 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I just feel a thousand times better after I did my timing belt/waterpump/ball joints. Peace of mind is something you can't put a price on.
    Also @SilverGhost that double cab the dude has for sale is so clean. Would buy it in a heart beat if I was in the market.
  14. Jan 29, 2016 at 5:43 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah tell me about it! In person it's even nicer. He's the kind of guy that puts a lot of elbow grease in it to keep it that way. If he sees any rust start to form he's scrubbing with a wire brush, treating it and painting it. He's a good guy too. He's the one that came to my house and we measured everything so I can get my motor and transmission set. Very nice guy.
  15. Jan 29, 2016 at 6:20 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    What do I win???
    FirstGen Jer and bowyer2002 like this.
  16. Jan 29, 2016 at 7:26 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Well photobucket is down which sucks cuz I've got some good stuff to show you guys.. how about a video? Someone will have to school me on how to make it work on here.
  17. Jan 29, 2016 at 8:07 AM
    shaniac
    Charleston, SC
    EXACTLY.... that's why you have a spare! LOL:rofl:
  18. Jan 29, 2016 at 8:23 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You don't have to use photobucket. Which sucks anyways.
    Just upload it straight to here. Next to post reply click upload file.
  19. Jan 29, 2016 at 8:30 AM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Lol I thought that was the only easy way to get pictures on here.. I mean I'm sure there's other ways but I didn't think you could directly upload from a phone
  20. Jan 29, 2016 at 8:36 AM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Yeah that's not working.. I uploaded the pics like you said and went to preview to see if they would post right and it just showed 3 broken image icons
