  1. Jan 29, 2016 at 8:43 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Fame and Glory and the adoration of your fan base. :humble:
  2. Jan 29, 2016 at 8:46 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Yep, Did my balljoints when I did my lift and I haven't worried about them since, and I'm currently in the process of doing my timing belt/water pump, PO didn't change it at all so i have 140K with OE belt and WP.
  3. Jan 29, 2016 at 9:08 AM
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    2000 xtracab 2.7L manual
    DR coilovers Dakar Leaves Icon rear shocks BFG 33x10.5x15 KM2 Trail Gear front bumper Relentless fab rear bumper DIY sliders
    Another option is to upload to a site like Imgur and then you can use the insert image button on here which just puts the URL of the picture into some brackets "[​IMG]" like that. Or imgur already lets you copy the image URL with the tags already in it.
  4. Jan 29, 2016 at 9:12 AM
    shaniac
    shaniac Well-Known Member
    Charleston, SC
    2014 Double-Cab Tacoma SR5 V6 4x4
    Not sure if the '03 5VZ-FE V6 is set up like the '00 but if you have never done this before let me give you a small tip: If you decide to replace the hydraulic timing belt tensioner, you will need to unattach the A/C compressor from the mounting bracket and push it to the side (leave it attached to the hoses) and then completely remove the A/C compressor engine mount bracket. That's the only way to get the the two bolts holding the hydraulic t-belt tensioner.
    I had a friend help me with my t-belt/water pump replacement and this was probably the hardest part of the entire repair.
    With 140,000 miles on it you can probably reuse the hydraulic t-belt tensioner for another 100,000 miles though... I had my factory hydraulic tensioner on my Tacoma for 240,000 before I decided to replace it... It's not a cheap part since they go for as little as $100 (Gates brand) but it's an important part since it is what keeps tension on the t-belt.
    Good luck!
  5. Jan 29, 2016 at 9:15 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Do you have the tapatalk app? If not get it. I can access like 3 forums at once on mine.
  6. Jan 29, 2016 at 9:15 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Upload from phone to your gallery. Then click on the camera button to see all pics while weighting a post. Then just click on one and poof...it's in the post. Magic.
    tibblits920[QUOTED] likes this.
  7. Jan 29, 2016 at 9:17 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    I don't see how people like tapatalk. Or mobile version of tw. I'm on my phone all the time and I just used the desktop version. So much easier to navigate IMO.
  8. Jan 29, 2016 at 9:22 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I agree with you on Tapatalk, it is a jack of all trades but a master of none. It just feels broken and quite often double posts or just plain doesn't update and then I'm behind on what I was following or commenting on. However mobile TW works nicely and updates lightening fast and I can switch to desktop mode if I absolutely have to.
    FirstGen Jer and BYJOSHCOOK like this.
  9. Jan 29, 2016 at 9:25 AM
    Madjik_Man
    Colorado Front Range
    I upload to youtube then copy/paste the URL into the post.
  10. Jan 29, 2016 at 9:25 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    I like the desktop mode on my phone..very simple to use
    gray223 likes this.
  11. Jan 29, 2016 at 9:28 AM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
  12. Jan 29, 2016 at 9:29 AM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    and a trail down the road after:yes:
  13. Jan 29, 2016 at 9:31 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I got rid of tapatalk and now I just use the mobile version unless I'm at a computer
  14. Jan 29, 2016 at 9:51 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I never had issues with tapa? Great for having all my forums in one spot and uploading images/moments on the fly.
  15. Jan 29, 2016 at 10:01 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    I had issues....that and my thumbs are too fat for my phone. So, I typically only get on at work. Sometimes I'll fire up the ipad, but that is only if I need info immediately.
  16. Jan 29, 2016 at 10:02 AM
    Speedytech7
    It certainly works, but it just plain feels clunky and is less feature rich than the free web mobile interface.
    Cr250jumper likes this.
  17. Jan 29, 2016 at 10:06 AM
    shaniac
    Charleston, SC
    Tapatalk is a learning curve but once you figure out your way around it is a nice tool to have to keep all your forums accessible in one place. I'm sure I'm not the only one here but I am a member of several forums and even though I have them all bookmarked in my PC and much prefer to interact via PC, Tapatalk makes life much simpler when you are on the go.
  18. Jan 29, 2016 at 10:10 AM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    Y'all need to quit talking about tapafluck and watch my seafoam smoke show! Lol
  19. Jan 29, 2016 at 10:19 AM
    shaniac
    Charleston, SC
  20. Jan 29, 2016 at 10:19 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
