  1. Jan 29, 2016 at 10:25 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
  2. Jan 29, 2016 at 10:40 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Deja vu all over again.
    tibblits920 likes this.
  3. Jan 29, 2016 at 10:40 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Should be the same, I haven't ever done a timing belt but my dad is and he just got back in town last night so he's gonna be able to help me.
    The kit I got has the tensioner so I'll probably go ahead and replace it.
    shaniac[QUOTED] likes this.
  4. Jan 29, 2016 at 11:12 AM
    tibblits920
    Stephen
    Jumbo Shrimp Taco
    You had smokey treats comin out of your exhaust too??
  5. Jan 29, 2016 at 11:15 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    He was meaning you posted it on the last page ha
  6. Jan 29, 2016 at 11:20 AM
    shaniac
    shaniac Well-Known Member
    Charleston, SC
    2014 Double-Cab Tacoma SR5 V6 4x4
    Help is a good thing since I'm not a master mechanic. My friend that helped me is so I basically helped him (He did the hard parts, LOL) and got schooled at the same time. That should be some well spent father/son time!
    A complete kit will have:
    1. Timing belt
    2. Upper tensioner pulley
    3. Lower tensioner pulley
    4. Hydraulic tensioner​
    Some kits don't come with the hydraulic tensioner (as I found out and had to run out to the local part store and pick one up)...
    Good luck and have fun!
  7. Jan 29, 2016 at 1:11 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Foglight mod. Photobucket undergoing maintenance. Cant post pics..
  8. Jan 29, 2016 at 1:49 PM
    prorider0
    prorider0 New Member
    98 tacoma sr5
    Hi all, I'm a new tacoma owner and new to the forum. I bought a 98 sr5 about 3 weeks ago. She had a little mis and misfire codes for cal 1,2 &3 so I changed the plugs and wires which solved that so far. I have a feeling there's a little more to it as the #2 spark plug had no electrode left and was a platinum plug when the rest were matching nkg. This gives me the hint the previous owner had issues with this cylinder.
    Anyway, today I cleaned and lubed my hood release mechanism because the hoods been hard to open. I was planning on cleaning the mass airflow sensor to see if that helps my mpg (consistently 15mpg mostly highway). This plan is delayed as I realized my intake tubing is mostly held together with electrical tape. I'm going to hit up the salvage yard tomorrow and try to find a stock intake to replace the crap filter, and tape "cold air intake" attempt on the truck.
    ClevSix likes this.
  9. Jan 29, 2016 at 1:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Welcome to TW! :) Post some pics of the new truck
  10. Jan 29, 2016 at 2:29 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    You sir are correct. It's the same way I did it to the 03 motor I just put in.
  11. Jan 29, 2016 at 2:45 PM
    95 taco
    95 taco Battle Born
    Does anyone happen to know the hex key size for the timing belt tensioner pulley?
  12. Jan 29, 2016 at 2:52 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    tibblits920 and Speedytech7 like this.
  13. Jan 29, 2016 at 3:02 PM
    Speedytech7
  14. Jan 29, 2016 at 3:06 PM
    TacoVio
    Kolton
    CO/WY
    Doooo it!!!!
  15. Jan 29, 2016 at 3:08 PM
    Speedytech7
    I can't own something in that decent of condition. I'd feel bad doing anything to it, I want one that's a bit more of a beater. I have to modify my vehicles, it keeps me from being bored.
  16. Jan 29, 2016 at 3:10 PM
    TacoVio
    Kolton
    CO/WY
    Lol! Yeah that thing is super clean! Probably be just another daily if I bought it lol.
  17. Jan 29, 2016 at 3:58 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    You don't necessarily need to remove the AC if you use this tool.
  18. Jan 29, 2016 at 4:03 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    That's a cool little tool!
  19. Jan 29, 2016 at 4:06 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
  20. Jan 29, 2016 at 4:20 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    If anyone needs to do their t-belt and needs to borrow it they are more than welcome to it for the cost of shipping.
    Fernando likes this.
